Old 06-15-2009, 06:06 PM   #1 (permalink)
backbone questions
Dave,
Please answer my emails....only trying to give you some business!
I'm the guy who asked.......
Does the exhaust system have to be lowered to install backbone?
Is it advisable to mount factory unit over your backbone?
Is there a torque guideline?
Is it advisable to use locktite?
Thanks,
Charlie
palum is offline   Reply With Quote
Old 06-15-2009, 07:12 PM   #2 (permalink)
Heliosky77's Avatar
Originally Posted by palum View Post
Dave,
Thanks,
Charlie
I'm not Dave, but i can answer some of your questions.
1. Stock exhaust system does not need to be lowered to install the backbone, but it does make it easier IMO.
2. The backbone is a replacement of the stock plate. I would not mount it over the backbone although some others have.
3. There is a post on the forum that says 12 ft-lbs is the correct torque.
4. Yes. Use blue loctite.
Use the search and you'll find a few threads answering the questions you've asked.
"Amelia"
'07 - 2.4L Sunburst Yellow
DDM Stage II S/C
RPi GT Exhaust
BlackCat Custom Gauges
VDi doors
Black calipers
Spoiler
Tinted Windows
Stubby "B" Antenna
Lil Chromies
www.discounttiredirect.com
Heliosky77 is offline   Reply With Quote
Old 06-16-2009, 12:50 AM   #3 (permalink)
Randy@ddmworks's Avatar
Dave,
Thanks,
Charlie
Charlie,
Dave has not been around a computer very much the last several days. he's been working in the shop 18+ hours every day, trying to meet deadlines on three car due before leaving to go to Denver
Helio answered the questions fairly well...although i don't use lock tite....it wouldn't hurt
www.DDMWorks.com
Randy@ddmworks is online now   Reply With Quote
Old 06-16-2009, 11:14 PM   #4 (permalink)
Sol-Mates's Avatar
I absolutely had to unhook the muffler on the drivers side (both hangers). The stock plate wasn't even close to having enough clearance to slide out. I have a 2008 GXP with the stock exhaust.
My torque wrench only goes down to 20 lbs so I just tightened the bolts... Should be fine.
John's- 2008 Sly GXP Manual Transmission- Loaded- Ebony interior w/red stitching
Tracy's- 2008 Mean GXP Automatic Transmission- Loaded- Ebony interior w/white stitching
MODS:
None
Sol-Mates is offline   Reply With Quote
Old 06-17-2009, 07:23 AM   #5 (permalink)
We've had every sort of torque used on the backbone. They all work, from the spec'd 12lb/ft to 55 lb/ft to zing'd with the impact gun.
www.DDMWorks.com
Old 06-17-2009, 10:47 AM   #6 (permalink)
Heliosky77's Avatar
I torqued mine down a 1/4 turn past finger tight.
"Amelia"
DDM Stage II S/C
RPi GT Exhaust
VDi doors
Black calipers
Spoiler
Tinted Windows
Stubby "B" Antenna
Lil Chromies
Old 06-17-2009, 07:34 PM   #7 (permalink)
Backbone
Randy,
Thank you and helio for the information requested regarding backbone installation. Did not realize Dave works all those hours. I am glad for you guys that business is good in a bad economy......just take a little time to smell the roses. Will be ordering my backbone.
Thanks,
Charlie P.
Old 06-26-2009, 06:22 PM   #8 (permalink)
SkyPilot's Avatar
Dave,
Thanks,
Charlie
I've put two in so far, one on my Sky RL and a second on my buddy's GXP. So here's my responses to your 4 questions:
1) In both cases I had to lower the exhaust, you'll also need to be able to move it from side to side to get the the front left most bolt. (Maybe the single 2.4 exhaust is different)
2) Correct, toss the piece of jellyfish out in the trach.
3) 12ft#'s is not nearly enough. I'd go to at least 25. 12 is barely past finger tight, but you choose.
4) Blue loctite!
2008 Sunburst Yellow Redline Sky
SkyPilot is offline   Reply With Quote
Old 06-26-2009, 09:08 PM   #9 (permalink)
King-Oka's Avatar
Mine went in no problem without touching the exhaust - N/A Exhaust must be easier. 11newton metres is the actual GM spec ( I read it on one of these forums) which is around 15 inch pounds I think. Not much. Didn't use any loctite. Must remember to check the bolts soon.
See King-Oka's mod page here
http://www.solsticeforum.com/forum/f...tml#post887582
Old 06-26-2009, 09:27 PM   #10 (permalink)
jwvess00's Avatar
Hi there!
On my 2.4, dropping the exhaust meant removing the two nuts that hold the pipe to the manifold, and letting it drop down. Very easy -- just be careful of the O2 harness. It's not a difficult job. I installed mine with my car on jackstands in my garage.
Jay Vessels
jwvess00 is offline   Reply With Quote
