Perhaps the information I found by going to scdyne's homepage has some import.
SCdyne Rotrex Supercharger System
Rotrex Supercharger based systems
100% dyno tuned calibrations (EFILive)
Boost pressures beyond 20 psi
Compressor efficiency equal to that of a Turbo
Self contained oiling and cooling system
Compact packaging of less than 0.6 cu ft
Complete bolt-on solutions
DIY bolt-on starter kits possible
The Rotrex centrifugal supercharger is the next generation of centrifugal supercharger using a planetary friction drive system to produce turbo like performance with a supercharger like throttle response. No games, no gimmicks just a better design for a drive system that has higher drive ratios, lower power consumption and uses turbo compressor components.
NASSOA Founding Member
