Old 07-14-2008, 06:35 PM
   DDMWorks Coil Covers
Randy@ddmworks's Avatar
DDMWorks is proud to release our Coil Covers for your Kappa engine.
The DDMWorks Coil Cover will fit both the 2.4 (LE5) and the turbo 2.0 (LNF) motors. This gives you a very attractive and functional piece to add once you remove the plastic engine cover. Whether you have removed your cover for our S/C kit or just to show off your engine a little better, the DDMWorks Coil Cover comes with Stainless steel hardware to attach directly to the Cam/Valve cover.
This piece hides the valley between the intake and exhaust cams where the spark plugs and ignition coils set. It will cover up most of the unsightly wires and gives your engine top a very smooth look. Also, by removing the plastic factory engine cover with all the foam insulation, you'll let your engine heat escape better from the top of the head, by allowing airflow over the Cam/Valve cover.
The DDMWorks Coil Cover comes standard with a Stainless Steel finish and Stainless Steel hardware for $69.95,
but can be upgraded to one of our in-house powdercoat colors for an additional fee.
Also available is our Cam/Valve Cover Powerdercoating service also avialable in the colors below, please visit DDMWorks for more info
Single Stage Colors(additional $10)
Black
Chrome
Gloss Red
Blue
White
Drk Yellow
Gold
Premium Dual Stage Colors(additional $20)
Starlight Red
Black Cherry Metallic
Translucent Gold
www.DDMWorks.com
Randy@ddmworks is online now
Old 07-14-2008, 07:17 PM
lil goat's Avatar
OK I want one for a GXP, but I need color samples, do I want Gloss Red or Starlight Red.
Red Bull Drift Team 2008
Solo Mach and High Flow Cat
Wester's Garage RACE tune II
JPM custom shifter.
Barney Juice with Militec-1
DDM Works PINK Breastplate
lil goat is online now
Old 07-14-2008, 07:36 PM
Starlight Red
Gloss red
www.DDMWorks.com
Old 07-15-2008, 07:15 AM
lil goat's Avatar
Thanks Randy! I think the Gloss Red, and now what color to do the valve cover decisions decisions. I will be so glad to get rid of the plastic engine cover!
JPM custom shifter.
Old 07-15-2008, 08:52 AM
Supercharged !
DA 1234's Avatar
Make a Red Coil Cover for me. Thanks.
DDM Supercharger #2
DDM Stage II Intercooler
DDM Pro-Beam
JPM Shifter
Clear Image Long Tube Header
Flow-Thru Cat
B&B Dual Exhuast Muffler
Eibach Lowering Springs
SSB Brakes Front & Back
BF Goodrich G-Force 255/45 Tires
DA 1234 is offline
