Old 09-25-2009, 08:21 AM   #16 (permalink)
rlhammon's Avatar
Originally Posted by Randy@ddmworks View Post
The probeam is basically unchanged since it was introduced...the bracket shapes have changed a little, but thats about it. The two "versions" you see on the website are the same design, one is a top view 3D rendering originally used to show the product. The Black view is an actual photo of the bottom side of a production piece. From what our AutoX members have reported, the Probeam is legal as long as you don't use the 3 bolts that connect it to the diff crossmember, so just using the lower control arm points is legal.
Thank you for the quick and informative post... exactly why I asked. Great information.
My Mod Information Page
Old 09-25-2009, 08:35 AM   #17 (permalink)
wspohn's Avatar
Randy, how much effectiveness do you think you lose by not being able to use the middle bolts? Still worthwhile? And I got mine on after taking a chunk out of it to clear my 2009 exhaust. Very noticeable improvement even the first time I tested it (well, the second, actually - I forgot to take the ESC out of nanny mode the first time I hit a test corner). No sort of double take half way through where it unsettled for a moment before settling into a line again as I experienced before the Probeam - or at least I am assuming that was the effect of the Probeam as I also installed the Backbone at the same time.
1958 MGA Twincam (race car)
1969 MGC roadster,
1965 Jensen CV8,
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
Old 09-25-2009, 06:32 PM   #18 (permalink)
jwvess00's Avatar
Hi there!
I had to "clearance" mine for my stock '06 NA, stock exhaust. I used a grinder to cut a notch out to clear the area. Other than that it fit fine.
Jay Vessels
jwvess00 is offline   Reply With Quote
Old 09-26-2009, 12:42 PM   #19 (permalink)
Ausserdog's Avatar
My Coupe had clearance issues too. Ended up "massaging" the flange with a 3 lb. drilling hammer and used a section of railroad track for an anvil. It took a couple of trial fits and the consequent re-adjustment before it fit with a bit of clearance - 1/4" or so. So far no rubbing or rattles, so all is well.
Ausserdog
2009 GXP Coupe - Aggressive with manual trans & GMPP Tune
Hobby cars:
1971 Triumph TR6 w/ overdrive - Ex California car - NO rust
1978 MGB w/ overdrive, .030 over, Crane 270, roller rockers, ported & Moss supercharger + more - Ex daily driver
1967 MGB undergoing V8 transplant
1958 Austin Healey 100-6 BN6 (sold)
1962 Triumph TR3B
Ausserdog is offline   Reply With Quote
