Old 04-08-2008, 09:39 AM
Critterman's Avatar
Compression,
At the speed limit it is 10 hours to the shop from Washington DC. It is about the same from DC to Toronto at the speed limit.
NOT WAITING ANY MORE!
Critterman is offline
Old 04-08-2008, 09:46 AM
compression's Avatar
That is a pretty big drive.... hmmmmm.... I dont know if I could last that long by myself. Also I dont think I would want to take the risk of getting pulled over and car problems.
Performance Auto and Sound
Compression Performance
compression is offline
Old 04-08-2008, 10:02 AM
ClearBraInstall's Avatar
Originally Posted by Dave@ddmworks View Post
Yeap, it is off. We have a couple tricks up our sleeves we are working on for fueling, watch for that. Right now the car is running strong and smooth, we will get a dyno this week.
From everything I have read, the factory fuel pump is not capable of delivering enough fuel pressure to support higher boost pressures.
Curious to see how you guys pull that one off. Also why the decision to move the intake so close to the engine? I see you built a shroud, but there is no opening in the hood to bring in air at that point, so I see an increase in ambient intake temps as it's closer to the engine and behind the radiator. (just some observations)
Mods
  • Dynoed at 450HP
  • Hahn High Flow CAT
  • Eibach Sportline Springs
  • SSBC Big Brake Kit
  • Konig Privat 19" Wheels
  • Custom Two Tone Paint
  • Razzi Wing
ClearBraInstall is offline
Old 04-08-2008, 11:00 AM
Supporting Tuner
Dave@ddmworks's Avatar
We put the filter there as it is the same spot where we put it for the supercharger, and there is a good amount of air that comes up from around the front shrouds and feed the other intakes on the market in front of the radiator. With the shroud that we put around the filter that cold air is also fed into the filter on our setup. The IAT's are just a couple degrees above ambient, the same as other intakes that are totally in front of the radiator. Although with our set-up we do not have to worry about putting extra bends in the intake to fit the intake tube between the radiator and the hood, it also makes filter removal for cleaning easier and prevents water from getting into the intake when opening the hood, it works really well!
WWW.DDMworks.com
Dave@DDMWorks.com
Dave@ddmworks is online now
Old 04-08-2008, 11:52 AM
1KULSOL's Avatar
Send a message via Yahoo to 1KULSOL
I made a mistake ... per Google Earth its 1393 miles from Toronto to Piedmont ... 15 hours and 3 minutes by their calculation ... a long drive .... it just depends on how badly you want your car to run right ... and if you had someone to share the driving ... it would be a lot easier.
DDMWorks Supercharger kit #11 - STAGE II - DDMWorks 3 guage pod with PLX gauges (boost/afr/oil temp)- Koni Sport shocks f/r-DDM ProBeam-DDM upgraded brake kit(drilled/slotted rotors-ss brake lines-ceramic pads)-DDMWorks 4-1 long tube headers and hiflow converter-JPM padded center console-DDMWorks Backbone (in RED)-SOLO SQR-2 dual center exhaust-Norms Painted (SLY) rear valence-Kazera KZ-L wheels w/Bridgestone RE760 Sport tires (255/45/18)Waiting on Stage III and the STB (Shock Tower Brace)
1KULSOL is offline
Old 04-08-2008, 01:30 PM
carlintexas's Avatar
Randy drove mine 1,000 miles - Muenster, Texas to Piedmont. Didn't seem like a bad drive to me! If I had to make the trip I would stop for the night in Jackson, Ms.
Yup, 1,400 miles would be - one really good looking companion & stopping for the night half way there!
I still think it's worth the trip - either driving the car or having it on a trailer!
Here's an option - DDM will be at the SE meet in August in Lexington, Kentucky - meet them there and hand over the keys!
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
DDM Custom Turbo System
3" Magnaflow cat-free
Riken Raptor's 255/45/18
carlintexas is offline
Old 04-08-2008, 01:32 PM
Critterman's Avatar
I monitor ambient and AIT on my dashhawk. My filter is in the same place. I have seen temps as high as 50 degrees above ambient in stop and go traffic. Within 1/2 mile or so it is back down to anywhere from ambient to 2 degrees above.
Old 04-08-2008, 01:58 PM
I imagine any placement under the hood - at a complete stop - is going to be mighty hot & no way to get around it.
I believe the DDM placement is as far (or farther) away from the big heat source (the turbo) as the original CAI location was.
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
Old 04-08-2008, 02:57 PM
Critterman's Avatar
It is basically in the same place as my GMPP CAI was except facing in the other direction. I saw the same if not higher temps in traffic with the stock shroud.
Old 04-08-2008, 03:17 PM
idkfa's Avatar
that is a thing of beauty!
True artisans.
idkfa is offline
Old 04-09-2008, 05:27 AM
nighttripper's Avatar
I checked google earth and from Ingersoll Ontario it is about 1351km about 14 hrs and 47 min. About 1000 miles
2007 Sky, Midnight Blue, May 18 2006. #1303 - MODS- KS Wind Screen, Magnaflow Quad Tips 2.5 C/B Exhaust, SMS Header, Redline Rear Valance,PCMforless Retune, M1 Wheels, Falken 452 tires......next Boost????
nighttripper is offline
Old 04-10-2008, 10:23 PM
   Just returned from DDM, Piedmont, SC
What a great trip!
I need to do a complete trip report! But as a quick summary:
Arrived at DDM & was met by Booger (the fierce guard dog). If you don't pet him pretty soon he barks at you!
Walked in the shop and met Ivy. Dave had a phone in his ear so Ivy gave me the tour! From the executive offices - to R&D and fabrication - to inventory and order processing - to the test and installation section.
Two 'Cool' Solstices in the house, mine and Randy's. Popped the hoods and both look similarly different (if you know what I mean).
In comes Randy - big grin on his face. Let's go for a ride he says! We take them out one at a time, mine first! Now let me say that mine has the boost turned down to about 8 lbs, so..... based on previous dyno runs, whp should be north of 240whp, especially with the larger DDM Intercooler. The Vector ECM is out and the car has the DDM stage II tune. The car ran good, no pings, no burps, no stutters, no codes!
Next we went out in Randy's stage II S/C. OH - MAMA! What a difference. Now the stage II S/C only dyno's at around 235whp so the horsepower is about the same! The difference is the immediate power with the S/C vs waiting for the turbo to spool up on mine. Now I could have revved mine to 4k and launched it, but Randy didn't do his.
Now I understand how the stage II S/C guys keep talking about running 0 to 60 in 4.6 or 4.7. I'm thinking a stage II turbo (or I or whatever you want to call it) would be hard pressed to break under 5.0. So for the street (red light to red light) IMO - the S/C rules. I believe the S/C would beat mine in the 1/8th mile also. Now I gotta believe the turbo would come alive and do well in the 1/4.
In Randy's car, from zero, first you smell tire rubber, then you smell clutch, then it hooks up and it goes like a rocket! He's installing a Spec stage II+ this week - so all you stage II owners, get your wallets out - it's clutch time!
After randy and I finished playing we went back to the shop and the shop closed at 6pm (rather than the midnight it normally does) so I could have the pleasure of taking them out to dinner.
So here we are in beautiful downtown Greenville (and it really is), getting ready to take a walk to the restaurant.
Here we are, post dinner at a restaurant that, according to the waiter, was selected by Wine Spectator as having the fourth best wine selection & cellar in the country. That's what he said! We passed on the $1,600 bottle of Château St. Michelle - but we did select a 1998 Alexander Valley Cabernet with a little tannin kick to it. We sniffed, we swirled, we sipped then requested dacanting - as if we knew what we were doing.
The one on the left is the brains of the bunch!
Food was good - wine was good - company was the best! We ended the night around 11pm. Dave and I met at 9am this morning (Dave brought the Starbucks - grandes - caramel macchiato for him mocha for me). We talked about my car, what's been done, what's going to be done - great stuff! Around 9:30 I bailed out and headed for the airport.
Thank you Ivy, Dave & Randy - for the great hospitality!
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
Old 04-10-2008, 10:46 PM
Jackknife's Avatar
Boy, it sure looks like a great time...wish I had been a fly on the wall, the car talk must
have been great!
I am very interested in your side-by-side impressions of an equally powered turbo vs. a S/C
car. That two cars with comparable numbers are so different says volumes about competing
theories of forced induction.
It's great that DDM so successfully reconfigured your car, you must be very pleased.
Jackknife
FE3 sway bar ... Car. Cust. Rests and Pockets
Blacked-out Grills ... Debadged
DDM Pro-Beam and back brace
Jackknife is offline
Old 04-11-2008, 08:41 AM
