New Product - WERKSracing WR-2 LNF Bolt On 450hp Turbocharger!!!
After a couple years of time investing thousands of dollars and countless man hours in developing our LNF Borg Warner EFR Turbo kits and exhaust manifolds only to have Borg Warner pull their EFR supply and resources to dedicate them to Indy Car (Non-open wheel spec) we had to do something about it!!!
We listened to what our customers wanted which was a higher flowing bolt on style of LNF tubocharger so we developed the all new WERKSracing WR-2 LNF Bolt On 450hp Turbocharger!!!
WERKSracing WR-2 on display at the 2012 CED meet -
Installed Picture -
Top view -
Product description -
This is it, The Ultimate LNF Bolt on turbo upgrade, the WERKSracing WR-2 Bolt on LNF Turbo Upgrade is here!!!
On a customer Saturn Sky Redline we made 390whp and 408ftlbs TQ on our Mustang dyno with 93 Octane fuel!
Stock appearing exhaust and compressor housings for a completely bolt on sleeper upgrade!!!
Supports up to 450hp!!!
Exhaust side Black Ceramic Coating included in price!!!
Forge Billet Aluminum adjustable bypass valve standard, can be deleted bringing price of turbocharger down an additional $160.00
Core exchange program
Incredible response
51mm leading edge technology billet aluminum compressor wheel
56.5mm exhaust turbine wheel
Internal WG actuator included
Comes complete with all necessary lines and fittings
Compressor housing powdercoating = $50.00
Pricing -
$2025.00 (With your core, Forge Bypass Valve plus shipping)
$2525.00 (Outright with Forge Bypass Valve, plus shipping)
how will this interact with my GMPP tune or will a new tune be required?
Any real life feedback on turbo lag or lack there of? I'd be curious to know how the lag is in relation to a stock turbo.
Thanks...this looks nice.
Are there a set of installation instructions, can we see a copy, I'd like to know how much work I'm getting myself into in advance.
Also wondering, with the stock turbo removed, would it be any easier to replace the cat to a freer flow cat at the same time...it's been a while since I eyeballed all the workings on the side of the motor.
your definately going to want a new tune especially if you want the power this turbo can provide. its definately recommended but the should start up and fire with your current tune in there.
the spool is slower the the stock k04 as it is esentially a "bigger" turbo but personally i think the fact that its not as peaky as stock right away is a great facter which from having a cobalt makes it more fun to drive and keeps the tires on the ground a lot easier.
installation would be just like replacing a oem turbo charger with a few minor odds and ends. we will supply a feed line and one of the water lines as the turbo re uses one of the factory lines. other then that its straight forward and imho easy on the kappas.
as for as the cat goes....if your going to do one then i would do it when you swap the turbos. it can be done before or after the fact but the catpipe needs to be removed to pull out the turbo anway. in all honesty a high flow cat or catless would benefit you. having full bolt ons would benefit you aswell with this setup so its something i would look into.
Impressive! This looks like the best true bolt on that's on the market by the numbers (price/power)
Couple of quick questions:
At what peak pressure was this dyno run?
What is the recommended max pressure of this turbo?
Does this turbo use a ball bearing center section?
2008 BRAZEN GXP - 5M Loaded Tuned to 22 PSI with HPT, AEM water/methanol injection kit - 4gph, Hahn Racecraft Intercooler. Solo street race exhaust, Catless, LE5 Throttle body 307whp on dyno dynamics - stock turbo (21 psi)
To come: BIGGER TURBO
Where is performance autowerks located? Some time in the next year or so I would like to make my way up there and have you guys do some work to my car.
