Originally Posted by werks
After a few phone calls from some customers regarding how to install their Sprintbooster I decided to put together this little installation guideline thread to hopefully help everyone out.
Step 1) Locate the factory Drive by wire harness attached near the top of the throttle pedal assembly under the dash.
Step 2) Remove the pink locking pin from the DBW connector and unplug the connector.
Step 3) Insert the Sprintbooster module into the pedal assembly connector, it will be very hard to insert, press firmly and make sure it is fully seated and clipped in before proceeding to the next step.
Step 4) Plug in the OEM DBW harness connector into the end of the Sprintbooster module, again it will be hard to insert, make sure it is fully seated and clipped in before attempting to start vehicle. Re-insert the pink locking pin through the OEM connector.
***Failure to make sure both the Sprintbooster module and harness are fully seated could result in the throttle going to wide open position upon startup***
Step 5) Make sure car is in park or neutral with the emergency brake fully engaged before attempting to start vehicle.
Step 6) Start vehicle and begin having fun!
Have fun!
Is this the connector identified in the Service Manual as the Accelerator Pedal Position (APP) Sensor?
Regards,
Bodean
(North TX, 2007 "Cool" GXP Automatic with Escort 9500ic, Custom Wind Restrictor, K&N air filter, Hahn BSR Tune & Hahn IC, Dual Horns, Kappasphere luggage rack (when needed), Flash2Pass, MagnaFlow muffler, Alpine PDX-5 amp with Pioneer Components & Blaupunkt rear and Sony Xplode Sub, DDM ProBeam & Backbone Brace, Werks front frame brace ADR Propulsion Wheels, Solo Hi-Flow CAT, Halo Demon Eyes), Hide-Away plates, Cherry dashboard, GM Roadster Hi/Lo HID's and Fog lights
