WERKS Built Solstice Issues Need some help - Pontiac Solstice Forum
 2Likes
post #1 of 19 (permalink) Old 01-24-2017, 10:08 AM Thread Starter
Brian85's Avatar
Hello,
I'm hoping I can get some help here. I'm the owner of the Solstice that you guys built back in 06 to build your turbo kits for these cars. I know its been in a couple different hands however I'm hoping I can get a couple issues fixed on how she runs.
Runs good tell I get into boost and at about 4,000 RPM's it will studder and cut out really bad. I have checked all my clamps on the turbo, intercooler etc and everything is tight. My AFR goes crazy rich when this happens and I can only hit 5-7 psi.
As far as I know, the tuning has been messed with however I'm not sure what all was changed.
Brian85 is offline
post #2 of 19 (permalink) Old 01-24-2017, 10:38 AM
Originally Posted by Brian85 View Post
Hello,
My 06 Werks Solstice story starts off just like yours almost. I bought it used from a novice car enthusiast (he was in over his head with this car), so the history is unknown.
Under WOT near 3,500 it would mis-fire like crazy, studdering and no power. A WBO2 I added showed AFR drop to near 9:1
When I opened the PE Enrich table RPM vs. AFR command, it looked like this mountain.
The recalibrated the VE table and MAF airflows and flat-lined the PE Enrich to look like this.
317whp/329wtrq 2006 Solstice AR5 LE5 Werks Turbo Kit Meth 16.5 PSI, Kappadapt clutch hose, Kappadapt flywheel bolts, Kappadapt trans mount
Steelmesh is online now
post #3 of 19 (permalink) Old 01-24-2017, 10:53 AM Thread Starter
Brian85's Avatar
Did you ever get yours running right? What are you using to data log?
Brian85 is offline
post #4 of 19 (permalink) Old 01-24-2017, 01:52 PM
Heck yeah, runs pretty good. HP Tuners. There was an existing tune with unlocked torque management, it really just needed airflows calibrated after adjusting the PE table to one EQ ratio command across the table. VE calibration on the E67 was done using HPT V2 and some magicbox program (Bluecat?) to convert all the tables into the familiar 3D maps.
I have yet to understand HPT Virtual VE as there is no information on how to use it as of last year.
post #5 of 19 (permalink) Old 01-24-2017, 02:26 PM
King-Oka's Avatar
You guys should contact Lyndon Wester at Westers tuning in Canada. He works with HP tuners and has his own tunes as well. He's capable of anything you can throw at him. I gave him my ECM for a week and he unlocked the LS2 Edit programme and retuned my LS3 Sols, and it runs far better.
My Garage http://www.solsticeforum.com/forum/g...ehicle_id=1132
King-Oka is offline
post #6 of 19 (permalink) Old 01-25-2017, 09:10 AM
Hello,
Is this the car that has the ebay turbo on it now? Need to get that replaced with a good turbo firstly but I can certainly help try and diagnose what is going on. I need to see some data using hptuners, do you have an HPtuners interface that you can datalog the car with?
Dave Gilbert #475 Pontiac Solstice GXP Coupe NASA TTB 2012 Midwest Season Champion
Performance Autowerks, Inc.
Phone - 815-439-4547
werks is offline
post #7 of 19 (permalink) Old 01-25-2017, 09:23 AM Thread Starter
Brian85's Avatar
Yes it is. I need to replace the turbo. I have a obd2 computer cable but not one from hptuners.
Sent from my VS995 using Tapatalk
2006 Solstice - WERKS Turbo Kit -
Brian85 is offline
post #8 of 19 (permalink) Old 01-25-2017, 10:08 AM
Ok, you will want to pick up an HPtuners interface - Performance Autowerks or see if you can have someone local to you datalog it with HPTuners and then we can try and get a better idea of what is going on.
werks is offline
post #9 of 19 (permalink) Old 01-27-2017, 10:29 AM Thread Starter
Brian85's Avatar
I run a auto repair shop and I have a snap on modis ultra that I can data log with. I understand it won't log wideband but I do have the gauge. Spending $500 is kinda steep for me.
Brian85 is offline
post #10 of 19 (permalink) Old 01-28-2017, 08:12 AM
You can try and send me some data to look at using that tool. Where are you located?
werks is offline
post #11 of 19 (permalink) Old 01-28-2017, 08:35 AM Thread Starter
Brian85's Avatar
Idaho. By coeur d alene
Brian85 is offline
post #12 of 19 (permalink) Old 01-29-2017, 09:19 AM Thread Starter
Brian85's Avatar
Well I just blew a head gasket. I had a boost spike to 30 psi and before I could back out white smoke. So I'm going to be needing some new parts lol
Brian85 is offline
post #13 of 19 (permalink) Old 01-30-2017, 06:29 AM
You can't do any boosting without the proper tune. DO NOT EVER push your car if you have replaced the turbo and not changed your tune. Guess you found out the hard way....sorry.
Steelmesh likes this.
post #14 of 19 (permalink) Old 01-30-2017, 08:26 AM
Note To Self: 2.4 head gasket blows at 30 psi
Sucks Brian had to be the one to find this out
Dj_Gorash likes this.
post #15 of 19 (permalink) Old 01-30-2017, 09:00 AM
Sorry to hear man, that car should have only been running at 13-14psi max. If you need anything just let me know.
werks is offline
