Go Back   Pontiac Solstice Forum > Supporting Vendors > Solo Performance
Old 09-15-2007, 01:28 PM   #1 (permalink)
GOINGSOLO's Avatar
Lights Out For Solo Cats
SOLO PERFORMANCE GXP & NA CATS ARE READY!
Our GXP CATS are tested and ready to go! As many of you know its been a long road to manufacturing a cat for the GXP that doesn’t trigger the engine light. After months of consulting with engineers, trial and error and frustration we are glad to announce that we have our GXP CAT ready for sale. After 23 years in the exhaust business I have to say that this project (the SOLO GXP CAT) has been the toughest by far. From switching manufactures… I won’t bore you with all of it.
We made a special exhaust (stacked) for the GM Design Centre in Warren, MI and even they were impressed that we were able to keep the engine light off without using a SIM. GM’s “Done up” GXP will be unveiled at this years SEMA show in Las Vegas, it has our Cat and Exhaust on it.
I would like to sincerely thank Shabby for his unending patience and help during this process. I was beginning to break out in cold sweats if I saw a PM from him.”Oh no not the light again!” Thanks Shabby for being so accommodating.
GXP CAT PICS...
GOINGSOLO is offline   Reply With Quote
Old 09-15-2007, 01:36 PM   #2 (permalink)
GOINGSOLO's Avatar
THE FIX...
The Right Cat…
Most CAT manufactures of the stainless coil cat use a 3 or 3 ½” coil. Many of these manufactures have problems with the stainless coil detaching from the sides. Many don’t use Cerium, a necessary ingredient in helping to reduce oxygen levels in the cat and help keep the light off. We ultimately went to a manufacturer that makes a full 5 inch stainless coil. It’s 66% more catalyst than most manufactures. Fortunately, this reduces emissions to proper levels. Unfortunately, these extra 2 inches come at a price. Each individual coil after being wound is tack welded. The finished coil is secured to the sides and can’t come loose. This process also comes at a price. This cat body is priced at well over two times the cost of our original manufacturer. Another added benefit of this 5” cat is that it is not overly loud. One forum member said it was close to O.E. Quiet.
O2 Relocation….
On our 3” front pipe for the GXP the rear 02 sensor must be relocated and extended out of the direct path of the exhaust. The rear 02 only monitors oxygen levels and with free flow cats, the exhaust doesn’t stay in the cat long enough to get the necessary amount burned off. Manipulating the position of the rear O2 and extending it solves this problem. All necessary hydrocarbon and NOX gasses are burned off. The extra oxygen that slides by is in no way harmful to the environment or anything else. No 02 wire extensions are needed as to 02 placement is only about 2 ½ “ from the original location.
GXP CAT PICS...
Old 09-15-2007, 01:43 PM   #3 (permalink)
GOINGSOLO's Avatar
GXP CAT SPECS:
1. Full 3” stainless steel mandrel bent cat
2. Stainless steel laser cut flanges
3. Specially made metal gaskets from turbo to cat included
4. O2 extender included
5. All hardware included
PRE-SALE PRICE................... $275.00 (First 25 units sold)
FORUM DISCOUNTED PRICE.. $319.00
LIST PRICE.......................... $425.00
SHIPPING............................. $ 30.00
(Shipping of course would be free if you were purchasing an exhaust kit at the same time)
NA CAT SPECS – Uses the same 5” cat body no O2 relocations is necessary for the NA cats.
1. Stainless steel coil cat
3. Specially made gaskets for both ends
PRE-SALE PRICE....................$240.00 (First 25 units sold)
FORUM DISCOUNTED PRICE....$289.00
LIST PRICE............................$390.00
SHIPPING...............................$ 30.00
For all orders please do one of the following:
1. PM GOINGSOLO
2. Email soloperformance@cogeco.ca
3. Call Jeff at 905-703-1557
4. Call Zoro Muffler at 905-897-6833
Note: Please check with your dealer about any warranty issues etc.
Thanks so much!
Jeff
NA CAT PICS...
O2 EXTENDER...
GXP GASKET...
Old 09-16-2007, 12:10 AM   #4 (permalink)
brian63304's Avatar
Ummm... what can I say. As being one of the first to prototype this CAT. I am very proud!! This is a great product. Same goes for the exhaust I bought from SOLO. I get more power from my GXP then I use too. I get pushed back in my seat every time I hit the gas. I have also experienced an increase in MPG.
Thanks for all your efforts in keeping my SOL and other SOLs happy!
1200 miles on the new CAT and very happy,
Brian
GXP: 1G2MG3527Y110634 Built 9/1/06
Recieved 9/27/06
Her Name is: Victoria
"AGGRESSIVE" (Officer McKrabbyass is going to give you a ticket while you are at a dead stop Red) with everything except Onstar.
brian63304 is offline   Reply With Quote
Old 09-16-2007, 06:04 AM   #5 (permalink)
JewJenk's Avatar
Send a message via AIM to JewJenk
The cat for the N/A, is this a direct fit/bolt on, or do I need to cut a pipe down.
If you find yourself in a fair fight,,,, then your tactics suck..
Don't get mad, get even....
JewJenk is offline   Reply With Quote
Old 09-16-2007, 09:45 AM   #6 (permalink)
Antonio's Avatar
Send a message via AIM to Antonio
ditto for the gxp/redline. Does it link to stock exhausts systems and other exhausts, or only yours?
I'm very interested in this product. Any idea of hp increase, if any? Possible to have a dyno done
Antonio is offline   Reply With Quote
Old 09-16-2007, 04:50 PM   #7 (permalink)
shabby's Avatar
These are direct bolt on's, i think Jeff even said the stock exhaust will bolt up to the gxp cat.
Old 09-16-2007, 10:33 PM   #8 (permalink)
GOINGSOLO's Avatar
Hi. These cats are built as a direct fit converter. They bolt on just like a stock cat would, even down to the proper bottom flange holes for the hanger bracket. The cats fit the GXP/Redline and the Solstice/Sky.
GXP-CAT
One thing we did with the GXP cat was to make the outlet a full 3" ball. We made sure that this ball fit the stock exhaust as well as ours. The original GXP cat that we dyno'd had a 15 HP ( at the flywheel ) increase. The new design is more free flow. The shape of the mandrel bent pipe has less bend and the outlet is a full 3" instead of our original 2 1/2. This should add HP. One thing that might take some of that gain away is the extra 2 inches of catalyst coil. All of the test vehicles ( five ) had our 3" front pipe on. We know that with any 3" front pipe the rear O2 bung must be moved slightly and extended. We haven't tested the cat with a 2 1/2" front pipe. From all of our tests and knowledge that we have gained my suspicion is that we would have to extend the rear O2 but not move it.
N/A CAT
We dyno'd the N/A cat a long time ago. It came in at 7 extra HP. Reports from customers have said that they get better mileage even when driving it harder. They have also said the rev's come a lot quicker.
Thanks.
Old 09-16-2007, 10:38 PM   #9 (permalink)
Antonio's Avatar
sweet, finally a high flow cat that doesn't throw codes to hook up to my magnaflow. Sounds great. Give me 24 hrs to decide and jump on that presale....heh heh. any idea how many orders have come through already so i know how quickly to jump on this?
Also.......what time frame are we looking at for first shipments to go out?
Old 09-16-2007, 11:35 PM   #10 (permalink)
Excelsior's Avatar
Man, oh-man. Should I grab this now or wait for the whole thing at once when I toss the Hahn Stage 3 in next year?
Previous #14 Owner / Current 08 GXP
Deep | LOADED | #14 Photo Album
My mods - updated 6/17/08
CNY Kappa Club Event Calendar
Excelsior is offline   Reply With Quote
Old 09-17-2007, 10:43 AM   #11 (permalink)
GOINGSOLO's Avatar
We have the cats built and ready to ship. DHL on average takes 3-4 days to deliver almost anywhere. As for doing mods all at once or is steps - most of the time it's recommended to do the mods one by one. This has several advantages. It spreads out the payments. It allows you to see the total effect of the one mod. It may change the noise level and you are better able to know when to stop doing mods that make the car louder. Lots of mods at once should only be done when you know that it is exactly what you want. Possibly your buddy has the same set up and you like it etc. We still have a lot of pre-sales left. Thanks.
Old 09-17-2007, 11:58 AM   #12 (permalink)
spiky3480's Avatar
PM sent with shipping information...thanks again Jeff.
SOLO Performance
goingsolo2@hotmail.com
2007 Mysterious GXP
INTRUDER Modifications
TEAM SOLSTICE 2009
TEAM SAVE THE TA-TA'S
Exhaust Sound Clips
Old 09-17-2007, 01:31 PM   #13 (permalink)
jag767's Avatar
Send a message via AIM to jag767 Send a message via MSN to jag767
caouldnt let ube the only one steve besides, i have to be louder than u
2007 Mysterious Solstice gxp... solo center exhaust no muffler, solo high flow cat, fujita intake, fujita intercooler pipes, 5% tint, custom engine cover, custom fuse box cover, Hahn intercooler, and norm's fenders, rear diffuser, and westes's hot tune.
jag767 is offline   Reply With Quote
Old 09-17-2007, 02:00 PM   #14 (permalink)
spiky3480's Avatar
LOL why am I not surprised
SOLO Performance
2007 Mysterious GXP
TEAM SOLSTICE 2009
Exhaust Sound Clips
Old 09-17-2007, 02:18 PM   #15 (permalink)
I was told mine has shipped, should be installed Thursday so you guys aren't alone.
Let's get SLIDEWAYS!
Solo Mach and No Cat
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
DDM Works PINK Breastplate
HKS Coilovers
