Go Back   Pontiac Solstice Forum > Supporting Vendors > Solo Performance
LinkBack (4) Thread Tools Rate Thread Display Modes
Old 02-28-2007, 09:41 AM   #16 (permalink)
razar's Avatar
Are there any soundclips yet of the MACH with the hi-flow cat??
Aggressive GXP, black top, black leather with red stitching, acoustic headliner, AC, sport metallic pedals, monsoon audio, single disc stereo(no XM), onstar, chrome wheels, Aisin 5-speed manual. $27,980.23
razar is offline   Reply With Quote
Old 02-28-2007, 05:00 PM   #17 (permalink)
shabby's Avatar
I drove with the mach and hiflow cat but we dont have any clips. Its not much louder then with just the mach system and sounds almost identical, and definetly quieter then the street/race setups.
Old 03-01-2007, 01:58 PM   #18 (permalink)
IBDRINKEN's Avatar
I am having mine installed on saturday with the hi flow cat and will try to post sound clips.
13.5@101.90
2.5" Stubby Black Antenna
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
Infinity Kappa Speakers
DDM Probeam
DDM Race Backbone( Not Installed)
DDM Black Coilcover
JPM Center Console
JPM Shifter
Custom Kicker System By JPM
MBRP Heat Shield
Dejon Intercooler
IBDRINKEN is offline   Reply With Quote
Old 03-01-2007, 10:45 PM   #19 (permalink)
DCLocal's Avatar
Send a message via AIM to DCLocal Send a message via Skype™ to DCLocal
Is the hi-flow cat available now? I thought it was still being tested and not available until mid-March… I haven't heard anything from Jeff.
"Mac Daddy" DELIVERED!
Sly/Ebony with the works...
My GXP Photo Gallery
DCLocal is offline   Reply With Quote
Old 03-01-2007, 10:50 PM   #20 (permalink)
IBDRINKEN's Avatar
<----I am one of the test dummys, I mean subjects
13.5@101.90
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
DDM Probeam
DDM Black Coilcover
JPM Center Console
JPM Shifter
MBRP Heat Shield
Dejon Intercooler
Old 03-02-2007, 06:19 PM   #21 (permalink)
shabby's Avatar
Well im no dummy but my mach exhaust + hiflow cat is installed, and man does it ever sound good. The higher the rpm the better it sounds, i seem to be shifting a lot higher now
Its quiet when you want it and loud when you floor it, just like i hoped. The guys at solo performance did a remarkable job, thanks a lot!
Here are some pics of the finished product
Old 03-03-2007, 11:11 AM   #22 (permalink)
DCLocal's Avatar
Thank you for the replies and the pictures, it looks awesome! I’d love to hear some sound clips. Have you encountered any ill side effects or check engine codes with the new cat?
I’d also like to see pictures of the exhaust tips from the rear at a slight angle. I really like the stock GXP tips, they look great and I like how the cut is angled slightly down and to the side. (If that makes sense)
Old 03-07-2007, 09:19 PM   #23 (permalink)
shabby's Avatar
Dont have any sound clips with the cat on, but it sounds similar like in the vid in the first post. Cruising at 80mph and its pretty quiet.
Check engine light came on, p0420 cat efficiency below threshold. Basically the cat flows too much
There seem to be some fixes for this though, we'll try them out eventually.
Here's a pic of the tip, i know what you mean about the angled stock tips. But when looking from above this is barely noticable, or maybe you can ask Jeff from solo to turn them a bit for you.
Old 03-08-2007, 10:31 AM   #24 (permalink)
GOINGSOLO's Avatar
Cat Update. I believe we will have a fix as early as next week for the engine light. A very good electrical mechanic friend says he will be able to splice a small circuit board next to the computer and this signal will "fake out" the computer and turn off the engine light. The information that I have now for this fix is that any qualified mechanic can do it in under 1 hour ( it's not that hard ) also the price for the parts will be under $100.00 We are also pursuing a "true" fix but with the sensitive nature of GM's O2's this may take some time.
I'm on holidays till the 17th of March. My partner Dave will answer any PM's, questions, orders, etc. For anyone with install questions please call Zoro-Mississauga at 905-897-6833.
Thanks Jeff.
GOINGSOLO is offline   Reply With Quote
Old 04-22-2007, 08:08 PM   #25 (permalink)
GOINGSOLO's Avatar
Hi. Just thought I'd share some Mach pics. For those of you waiting for the Mach kit and Cat I think we are still a few weeks out on the cat. Quick cat update - We were able to get the engine light off by moving the O2 bung closer to the cat and also using an extender. This was tested for over 300 miles and no light!! During this time we had a rash of these cats coming back to our shop ( installed on non GXP cars 6 months to a year ago ) with the whole stainless coil moving up and down. Upon looking into this further we decided to go with another cat manufacturer. This manufacturer cans the coil differently and will not come loose. The cat is longer and therefore we are starting the process over to try and get the O2 sensor closer to its original position. With the different length cat all the positioning we did before will change. Many of you are waiting for the cat to be fixed before you want the Mach kit. Since it may be a while just PM me if you want the catback and we will ship the cat separately when its ready. As a side note when I went to the cat plant to talk to them about how they construct the cat etc. I noticed a lot of Solstice and GXP posters up. Turns out that this company makes the metal housing for the Sol and GXP motor mounts. We are currently testing a new cat and hope to conclude this process soon. Thanks.
Old 04-23-2007, 12:12 AM   #26 (permalink)
MeanSol's Avatar
Great News
If the new cat is longer, will it change the way the catback system fits?
By the way, I have the mach setup installed and it sounds/performs wonderful. It was well worth the wait!
Thanks!
MeanSol
Team Solstice
MEAN GXP with the works, minus smoker, pedals, XM, Big Brother, and Onions
Current AAT topless outing record -10 degrees F at an average speed of 70mph for a total of 61 miles!
MeanSol is offline   Reply With Quote
Old 04-23-2007, 06:55 AM   #27 (permalink)
GOINGSOLO's Avatar
The start and end point of the new cat is exactly the same but the body is about 2" longer. It's very tight to fit it into the small area but can be done. Glad you like your kit MeanSol. Thanks.
Old 05-04-2007, 07:34 AM   #28 (permalink)
GOINGSOLO's Avatar
Hi to all. Thought I would give you a cat update. We have the cat we want to use and the fix for the engine light all worked out. The new cat has been on Shabby's car now for about 2 weeks with no problems. In talking to the manufacturer of the cat bodies we have been discussing that they construct the funnels after the stainless coil a bit differently. This will make for a much nicer fit and be a lot more ascetically pleasing. Another benefit is that they will be easier to construct and have more tolerance room where they fit. The last few weeks have been a little frustrating. The manufacturer has agreed that the changed funnel design is the way to go. Thats the good news. The bad news is that manufacturing processes don't change for them overnight. Tooling, jigs, drawings,etc. have to be made so that they can have the production process down pat when they start to build. For those of you that either have or have seen our cat's these new ones will be far superior. This cat project has been a struggle from the beginning. The end is very near and the product will finally perform, look and fit fantastic. Thanks for your patience to those of you that are waiting. At the risk of inserting my foot in my mouth our best guess at when our first batch will be ready is around May 18... Thanks.
Old 05-04-2007, 01:10 PM   #29 (permalink)
Okay, please forgive me if this is an elementary or otherwise silly question, but can the cat be installed later? I adore the sound of the exhaust, but I'm not quite ready to make the leap to switching out the stock cat... can that be done at a later date with the exhaust already installed, or does it become more difficult at that point?
Also, I have a Sky R/L... I'm assuming this exhaust will work on the car, but better to ask and possibly look stupid than have a beautiful exhaust I can't use, right?
plausibledenial is offline   Reply With Quote
Old 05-04-2007, 08:03 PM   #30 (permalink)
GOINGSOLO's Avatar
Hi PB. The cat can be done later without any problems whatsoever. Our cat is a direct fit replacement so there is no issues with doing it after the exhaust install. Our kit does fit the RL but IMHO the round tips don't suit the square openings. We have done a few RL's at our store and we reused the stock tips. We have tried a lot of different tips and some are acceptable but we haven't found any that match the car as well as the originals. It would be possible to sell the kit without any tips, then you could get a shop to weld your's on. Another possibility would be to cut off and ship us your tips and then we could use them for your kit... Hope this helps and thanks for your interest.
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f103/solo-gxp-mach-exhaust-kit-28438/
Posted By For Type Date
My Solo Performance Story - Solstice GXP Owners Forums This thread Refback 04-08-2008 05:09 PM
Hello Everyone ........08 GXP Exhaust Question - Solstice GXP Owners Forums This thread Refback 02-28-2008 09:13 AM
beecee's 2008 Pontiac Solstice on CarDomain - Page 2 This thread Refback 02-25-2008 11:07 AM
YouTube - solstice gxp exhaust 3 This thread Refback 02-16-2008 08:50 PM
