Since we are getting crazy about suspension mods here at Kappasphere, we ordered in a bunch of Eibach Anti-Roll Bar kits here in stock and had to put a set on our Sky to test them out.
We just installed these last week, so we are still learning more about these bars. Our first impression is WOW! Even on the softer setting, there is very little body roll around sharp turns. The car feels very predictable and sturdy. I drove up to Los Angeles this weekend which is known for very rough roads and expansion joints. The car felt rock solid the whole time. The wheels feel more planted to the road. I really enjoy the way the car feels now and can't wait to get some more grippy tires on her to really attack the corners.
Test car: 2007 Saturn Sky
Suspension Modifications: Kappasphere Lowering Springs (Eibach), reBAR, Eibach Anti-Roll Bars front and rear.
Anti-Roll Bar Installation Notes (Kit comes with instructions, but these might help you out more):
Skill level: 2 out of 5. Note: Might be hard to remove the rear sway bar without a proper lift. Everything else is just removing bolts. Helps to have a second set of hands to get the new bars in without scratching up the powder coating.
Time needed: 1 - 2 hours
First step, get yourself some coffee to get pumped about the installation you are about to begin.
Cade and I installed these bars with the Sky up on our lift. We removed the rear wheels so that we could get better view of everything going on, but you can install yours without removing the wheels. You will notice that this picture shows the new Anti-Roll bar on top of our reBAR.
Beginning with the rear sway bar, remove these two 15mm bolts on each side and make sure to save the bracket as you will be reusing this bracket with the red polyurethane bushings supplied in the kit.
Remove the end 18mm bolts on each side. You will need to hold the inside screw with a hex wrench in order to remove the bolt.
Your stock bar is now free to come out but it will take a lot of maneuvering to get it out. We unbolted the drop links and exhaust hangers to give us more room to get it out.
Here is a picture of the stock bar and the Eibach bar. The stock bar weighs in at 6.4 lbs and the new bar weighs a massive 11.1 lbs! Made of aircraft grade, high strength, cold-rolled steel. The bar has two holes on each side, the outside hole is a softer setting then the inside hold. We put our on the softer setting front and rear for testing. This seems to be the best setup for street or track. Autox or drifters might want to tighten up the rear.
Here is a picture of the rear bar installed. Make sure to lube up the bushings with the supplied lubricant.
The front bar is done very similarly, but it is much easier to remove! No need to remove the front wheels or drop links. Just remove the 4 inside bolts and 2 outside bolts and drop it out and replace with the new bar. Here is what it will look like when your done.
Want a set for your kappa car?
Price: $360 for front and rear kit!
Order here
