Go Back   Pontiac Solstice Forum > Supporting Vendors > KappaSphere
Old 04-16-2009, 01:27 PM   #1 (permalink)
kappasphere's Avatar
Hawk Brake Pads Now On Sale!!!
YES EVERYONE. THESE PADS ARE NOW ONLY $190 FOR THE FRONTS AND $160 FOR THE REARS. THESE PRICES ARE GOOD WHILE SUPPLIES LAST!
We now have THE Hot Set-up For Track! The DTC-70 compound in the front with the DTC60 in the rear is the combination used by winning teams at Nationals. If you are tracking your Solstice or Sky, this combination will give you the proper brake bias for great lap times.
DTC-70 Key Features:
  • 400-1600deg F; 204-871deg C
  • High Temp & Torque
  • Provides superior pad & disc wear
  • Excellent torque control
  • Excellent modulation & release characteristics
  • Designed for high deceleration rates
DTC-60 Key Features:
Please visit our site or call us to order!
www.kappasphere.com
Bill Forelli
Marketing Coordinator
951-296-6762x206
www.kappasphere.com
bill@kappasphere.com
kappasphere is offline   Reply With Quote
Old 04-16-2009, 11:28 PM   #2 (permalink)
2KWK4U's Avatar
Abel,
How well are these pads suited for the daily drivers that track and/or autoX their cars from time to time? Should these be considered "track only" pads?
My Mods (for now)
Old 04-17-2009, 09:30 AM   #3 (permalink)
Originally Posted by 2KWK4U View Post
Abel,
We dont recommend them for daily driving. If your going to install them and drive your car to the course or track than you will be fine. However you should pop them out once your done with your track/autox day. They require a significant amount of heat for proper function. Its hard to achieve that heat with daily driving.
Bill Forelli
951-296-6762x206
www.kappasphere.com
Old 04-17-2009, 01:17 PM   #4 (permalink)
2KWK4U's Avatar
Thanks for your honest answer. I appreciate your candor. Would you recommend going one step further and getting seperate rotors to go with these pads?
In other words, would one have to worry about bedding in and pad glazing issues if they were to swap pads back and forth for track days?
My Mods (for now)
Old 04-17-2009, 05:04 PM   #5 (permalink)
You can use your same rotors as long as they are not badly worn or damaged. As for glazing, it doesnt require much to remove the glaze from the on pad to the next. Hawk brake pads come with bedding instructions on the box and following this when swaping pads can help eliminate the glaze of the previous pad.
Bill Forelli
951-296-6762x206
www.kappasphere.com
