Go Back   Pontiac Solstice Forum > Supporting Vendors > DEJON Powerhouse
Old 06-02-2008, 04:41 PM   #1 (permalink)
GhostRL's Avatar
Send a message via AIM to GhostRL
Dejon 5027 Turbo kit results... 365 rwhp!
365 rwhp with a crappy 2.5" intake and running out of fuel in the tune, there's potential for well over 375 on PUMP GAS!
One satisfied customer.
http://i304.photobucket.com/albums/n...g?t=1212442514
2007 Sky Redline FOR SALE
Dejon Turbo + HPTuned
http://www.solsticeforum.com/forum/f...79/#post885290
GhostRL is offline   Reply With Quote
Old 07-20-2009, 07:35 PM   #2 (permalink)
GhostRL's Avatar
One year update: zero major problems from the setup. Most recent tune put down 460+ at 30 psi. Had a couple minor issues - blow off valve was out of adjustment, had to change wastegate setting on turbo itself to compensate for an issue I was having with the wastegate rubbing on the shock mount. Basically I shimmed the bolt closest to the frame on the wastegate mount to push the mount 1/2" away from the turbo (and shock tower) and added a 1/2" longer bolt to the location. Works like a charm, no further issues. Also had to rotate BOV cap because the nipple was sitting on the frame. All minor stuff, still running STRONG as a daily driver, 20k+ miles
Old 07-20-2009, 07:56 PM   #3 (permalink)
blacksky's Avatar
How about posting the dyno and some pics?
blacksky is offline   Reply With Quote
