Go Back   Pontiac Solstice Forum > Supporting Vendors > DEJON Powerhouse
Old 10-15-2009, 09:04 PM   #1 (permalink)
DEJON-Dave's Avatar
Intercooler Comparison
I finally got the nerve to cut open my factory Intercooler and calculate the effective flow area. It has 14 tubes measuring .115 x 2.50 inches (Inside). I assume that the fins inside the tubes block 25% of the flow area. So I calculate the flow area to be .115x2.5x14x.75= 3.02 sq in. This equates to a 1.96"dia ID tube.
Likewise I measured the space between plates on our (DEJON) IC to be .262" and the length is 3.06" for 11 air passages. The flow area is .262x3.06x11x.75= 6.61sq inches. Over twice the flow area of the factory IC. This equates to a 2.90"ID tube
QUESTION: with the factory IC flow area being 26" long, does the factory Intercooler effectively throttle the air flow at high rpm instead of the Throttle body?
See pic attached
Founding Member #6
DEJON-Dave is offline   Reply With Quote
