Anyone use ATF in their manual transmission? - Pontiac Solstice Forum
Closed Thread
post #1 of 60 (permalink) Old 12-08-2008, 08:42 PM Thread Starter
I'm getting a grind in 3rd gear when shifting quick. I was wondering if anyone has used ATF in a manual. I know that it comes with a heavier gear oil designed for use in a truck. I was hoping a lighter fluid might cure the grind.
jonnyGXP is offline
post #2 of 60 (permalink) Old 12-08-2008, 09:47 PM
pep
pep's Avatar
Send a message via AIM to pep
No do not use the ATF in a manual gearbox, ATF was designed for automatics won't be sufficient lubrication for a manual. You can try to find a lighter gear oil or additive like lucas oils or royal purple and replace the factory gear oil.
2008 MEAN GXP..... Mods... 3" Magnaflow dual exhaust,5 matching yellow engine caps,fuse cover stainless.
pep is offline
post #3 of 60 (permalink) Old 12-08-2008, 10:47 PM
Frank I's Avatar
Jonny GXP:
Would not recommend using ATF. The gear oil in the tranny is not truck tranny fluid. You may want to consider synthetic, Royal Purple, Redline, Lucas, etc. I have Redline in mine and it shifts smother. However, if you are getting a grind going into third gear, a change of fluid to synthetic may not do the trick.
Frank I
07 Black GXP, 5 speed
Frank I is offline
post #4 of 60 (permalink) Old 12-08-2008, 11:39 PM
silversolstice's Avatar
I've switched to Mobil 1 75w-90 after 2k miles. 2-3 has improved, but it still a little clunky from 1-2. What do you expect from a Japanese made transmission?
Miles as of July 6,104,000 miles 2016
silversolstice is offline
post #5 of 60 (permalink) Old 12-09-2008, 11:06 AM Thread Starter
There are plenty of manual transmissions that call for ATF and I have used it many times in previous cars.
jonnyGXP is offline
post #6 of 60 (permalink) Old 12-09-2008, 11:15 AM Thread Starter
Originally Posted by Frank I View Post
Jonny GXP:
Frank I
The gear oil for our transmission is 75w- 90, the same that is recommended for the Colorado
jonnyGXP is offline
post #7 of 60 (permalink) Old 12-09-2008, 12:01 PM
jonnyGXP : There are plenty of manual transmissions that call for ATF and I have used it many times in previous cars.
jonnyGXP : The gear oil for our transmission is 75w- 90, the same that is recommended for the Colorado
A gearbox dsigned for use with ATF will be damaged by using gear oil in it. A gearbox designed for gear oil will be damaged by using ATF in it. Putting in the wrong type of lube will probably cause irreparable damage and will certainly void any future warranty claims you may have.
If 2-3 is the only gear change you are having trouble with, the most likely culprit is your shifting technique. The 2-3 shift is a long throw, and if you hurry it you will cause a grind.
post #8 of 60 (permalink) Old 12-09-2008, 03:26 PM
Mod Emeritus
Gear oil and ATF oil are different. I know some folks other folks who put ATF in a gearbox calling for gear oil in some older cars, and found that the different chemcials in the ATF ate out the seals in the gearbox.
If you want a lighter fluid, go to the lightest recommended gear oil for the gearbox, in synthetic. Don't put in something it wasn't designed for, as it might cost you big money in the long run.
Solstice and Sky Fan
Fformula88 is offline
post #9 of 60 (permalink) Old 12-09-2008, 04:28 PM
typhoon's Avatar
bla bla bla...
I have shifted from 2 to 3 so fast it was in gear 50 feet behind me. No grind at all
GONE--2008 GXP 5 speed manual Brazen GMPP upgrade
2008 Cadillac SRX AWD N*
2016 GMC Sierra Denali 6.2
2012 Cadillac CTS4 3.6DI Wagon-Premium
2003 Honda ST1300
1965 Bolens tractor. w/new 13hp crate motor
2000 pair of roller blades
2008 Limer backpacking shoes
typhoon is offline
post #10 of 60 (permalink) Old 12-09-2008, 04:43 PM
errr...if you have a grinding noise in a manual gearbox and you're using he correct lube to begin with, there is no oil that's going to fix it. Whether you have the correct manual gear lube, ATF, motor oil, mineral oil or cooking oil in that manual gear box, it cannot fix the mechanical cause of the grind. Nothing in a bottle will cure the problem. It needs to be mechanically corrected
Think about it- if there's something so abnormal that you wonder about using the wrong grade lubrication in a mechanical system, shouldn't that be a warning sign that there's something actually physically wrong that needs repair?
ChrisBlair is offline
post #11 of 60 (permalink) Old 12-09-2008, 05:08 PM
I tried the royal purpel lube in my civic, after having mobil1 75-90 in it, I then experienced a slight grind going in to 3rd, I changed back to mobil1 problem corrected.
I think the RP is too thin for daily driver use, and on a side note the T 56 in my Z does have ATF in it from GM.
bee guz is offline
post #12 of 60 (permalink) Old 12-09-2008, 05:50 PM
typhoon : I have shifted from 2 to 3 so fast it was in gear 50 feet behind me. No grind at all
Shifting fast is not the same as hurrying a shift.
post #13 of 60 (permalink) Old 12-09-2008, 06:25 PM
pep
pep's Avatar
If the car came with ATF in the tranny than that's what should be used, If the solstice gearbox came with gear oil than that's what should be used, experimenting could cost you big!!!!You can play with different grades of gear oil,but using something totally not good for it, will destroy it, it's your call, my 2 cents...
pep is offline
post #14 of 60 (permalink) Old 12-09-2008, 06:34 PM
pep
pep's Avatar
True..... But not this one, and trust me I've seen manual gearboxes that had the wrong oil in it, they looked like a pile of metal sweeped into a shoebox....
pep is offline
post #15 of 60 (permalink) Old 12-09-2008, 07:02 PM
Gm's t-5 uses atf the new venture uses gm's synchromesh fluids
1stragtop is offline
Closed Thread
