I have a 2007 Solstice and I need to replace the right front Bearing Hub Assembly. I can't seem to find any DIY tips on this site. I am hoping someone can give me a link on this job.
From what I could find elsewhere, it seems straight forward, but I would appreciate hearing from anybody who has done the job themselves.
I do have some specific questions:
1. What size is the front spindle ? (I will need to buy a socket.)
2. What is the torque spec for the spindle ?
3. I think the hub bearing assembly bolts torque to 85FtLbs. Confirm ?
Thanks to anyone who can offer some advice.
Reason: spelling
I have a 2007 and had to have mine front right replaced two weeks ago. Have about 52,000 miles on the car. Does anybody know of a problem with the hubs?
Alan
2009 Brazen (Orange Metallic) Coupe - Fujita Cold Air Intake
2007 Mean Yellow GXP Solstice - Superchips Performance Tune, Fujita Cold Air Intake, Kappa Intercooler Pipes, SOLO Performance GXP Mach Performance Exhaust & High Flow Cat, yellow top radiator hose, chrome turbo cover, Ebony Leather with Yellow Stitching and Yellow Logo
Since I started this string I decided I should post a message about the job I completed.
It was fairly straight forward, but I did run into a few minor issues.
First, I had a hard time getting the small torx screw out of the rotor. I tried using a small Allen Key, but it didn't budge, and I started to strip the inside of the screw head. I decided to make a quick run to Harbor Freight and pick up a set of Torx bits. That did the job.
Next, after I removed the screw, I couldn't get the rotor off the hub. The rotor was still in good shape so I didn't want to bang on it too hard. I tried to apply some rust-solvent, but it still did not budge. But then it hit me !! What was I doing ???
I decided to just take off the old hub assembly with the rotor still attached. Once I did that, I placed wood blocks (4x4) on the floor, and laid the rotor flat on them with the hub assembly towards the floor. Then I took a malet and gently tapped the lugs on the hub assembly until it at detached from the rotor. It worked great ! Reassembly with the new hub was no problem.
I would like to point out that I purchased a non-OEM hub assembly from Car Parts Warehouse for about $110. They claim it is equivalent to the OEM part, and it's about a third of the price. I know I am taking my chances, but so far, so good. With the new hub assembly, my vibration problem has been eliminated, and I probably saved about $500-$600 doing the job myself.
Yeah, you can't fudge a torx bit, glad you stopped in time
You should be pretty safe with the replacement part, it's good to know that's available (I bought one used for about $60 for the same reason (the retail price)). I might go that route instead.
I hope this helps someone else.
Thanks for all your input.
Well at least the "wheel bearing" part is contained in that hub that is bolted on by the 3 bolts. On many cars where the wheel bearing is pressed into the hub, you'd need a shop press, which most home mechanics do not have. I bought a small shop press with a few press cups when I started doing transmission rebuilds years ago, and haven't had to pay a shop to press in/out a bearing in a long time now. Was pretty cheap too.
I called and they said that they are a "house brand" I still am curious who makes them, in that I am fairly certain that they don't make their own parts, and that carpartswarehouse.com has the exact same deal. I'm sure if I were to dig around some more, I could find more resellers with the same part, but whatever the case, it sounds like a good deal. or at least a good price.
Was doing a brake job on my 2007 GXP and noticed that the left hub assmbly need to be replaced. The dealer replaced the right one two weeks ago and charged me $514.49 for the hub not including labor. Boy did I get ripped off.
Alan
