Car bogs out - Pontiac Solstice Forum
Old 11-02-2012, 03:38 PM   #1 (permalink)
AggreSol's Avatar
Car bogs out
When my car hits almost 5k rpm my car bogs out and check engine light comes on just until I shift gears.
I was told I need spark plugs, any ideas?
Thanks!
Sent from my iPhone using Autoguide.com Free App
2006 "Aggressive" Solstice
view MY GARAGE for more details
AggreSol is offline   Reply With Quote
Old 11-02-2012, 04:08 PM   #2 (permalink)
glake89's Avatar
What DTC did you get? Start there.
been fixin' cars for 71 years
Some of what I know is from experience, some from listening or reading- most of it, I just make up
glake89 is offline   Reply With Quote
Old 11-02-2012, 04:11 PM   #3 (permalink)
AggreSol's Avatar
Dtc?
Old 11-02-2012, 07:45 PM   #4 (permalink)
Senatorius's Avatar
Check for clogged cat, are you boosting? If so don't push it cuz it might also be detonating.
2008 Pure White Solstice, Modded dash and accents,
DDMWorks Stage 2 Supercharger
White and red Leather seat covers
Gianna Wheels
VDI Door kit
RK Sport Body kit and Ram air hood
Magna Flow Dual Exhaust
Senatorius is offline   Reply With Quote
Old 11-02-2012, 09:12 PM   #5 (permalink)
WintR's Avatar
Originally Posted by D'ROCK got SOL! View Post
Dtc?
Diagnostic Trouble Code - have the code read at many auto parts stores, if you don't have a reader.
Mods: Kappasphere CAI, Clear Image Shorty Header, second horn, visor decals, mudflaps, tonneau cover, brake light flasher, trailer hitch, 'lil Chromies, trunk monkey, retune, DDMWorks backbone, GMPP Suspension, wood grain dash, Solo Quiet cat-back exhaust, deleted:Solo high-flow cat
WintR is offline   Reply With Quote
Old 11-03-2012, 06:27 AM   #6 (permalink)
AggreSol's Avatar
No boosting, but I will update soon with the codes
Old 11-03-2012, 08:14 AM   #7 (permalink)
chickenwire's Avatar
Sounds like a clogged cat. I know a guy who has one for when you get frustrated 'cause you can't get one through GM!
Old 11-03-2012, 01:50 PM   #8 (permalink)
AggreSol's Avatar
It through my check engine light on but it went off this morning so i couldn't scan it when I cranked up. I was planning on buying a high flow cat from solo if that's the problem
Old 11-03-2012, 02:29 PM   #9 (permalink)
Sly Bob's Avatar
Did you scan it even though the light wasn't on? Just 'cause the light is off doesn't mean a code isn't stored.
Delivered on May 27, 2008
Sly Bob is offline   Reply With Quote
Old 11-03-2012, 03:19 PM   #10 (permalink)
AggreSol's Avatar
Yes and no codes are showing up or pending
Old 11-03-2012, 04:12 PM   #11 (permalink)
I've read on the forum that you can take out one of the O2 sensors (in front of the cat) to test. Make a helluva lot of sense 'cause if you eliminate the restriction you won't get the hesitation. Noisy, but a quick diagnostic.
Old 11-03-2012, 04:23 PM   #12 (permalink)
SaturnSkyDude's Avatar
Thanks!Sent from my iPhone using Autoguide.com Free App
I had a similar issue and it turned out to be one of my coil packs. My check engine light came on and indicated I had a misfire on cylinder #2. The tech switched the coil pack to #3 cylinder and drove it again. Then the misfire went to cylinder #3. I replaced the coil pack and no more problems. I have read about this problem a couple of times so it is worth looking in to. Please let us know how things turn out.
Need some spark plug help PLEASE!!
Please Support The:
Leukemia & Lymphoma Society
Drove My Redline home top down on 12/12/06
In Akron, Ohio !!
Silver Pearl / Black Leather
5 Speed
Limited-Slip Differential
Chrome Wheels
6-Disc CD Monsoon
B Series Stubby Antenna
K&N Drop In Air Filter
BSR Tuner
Enjoying another cancer free day :)
SaturnSkyDude is offline   Reply With Quote
Old 11-03-2012, 08:33 PM   #13 (permalink)
AggreSol's Avatar
I have heard this could be an issue too. Hopefully I can check it out tomorrow and fix whatever it is.
Can any of the coil packs be changed around and swapped out with each other? I might try this tomorrow and checking my cat converter too.
Old 11-05-2012, 06:18 AM   #14 (permalink)
Thanks!
I hope this is worked out quickly for you. Please PM me if you take it to a dealership to have it serviced. Keep us posted.
Matt,
GM Customer Assistance
GMCustomerSvc is offline   Reply With Quote
Old 11-05-2012, 05:59 PM   #15 (permalink)
AggreSol's Avatar
PROBLEM FIXED (permanently I hope), I checked my spark plugs and 1 wasn't screwed in enough and I had a sensor loose, I think it was an O2 sensor.
I'll update if problem isn't fixed but I took a test drive and all is well as of now!
