Old 03-16-2005, 06:18 AM   #1 (permalink)
Luc
Luc's Avatar
Convertible Care
I've never owned a convertible before. Aside from the regular car maintenance, does a convertible need additional care?
Luc is offline   Reply With Quote
Old 03-16-2005, 06:25 AM   #2 (permalink)
achieftain's Avatar
Avoid, if you can, all birds. Don't let the droppings sit too long (of course good info for painted surface, too) Becaus it is cloth it is not 100% impervious to outside elements. Acid rain will also affect it. Use less soap on top than you use on rest of car and leave top up and latched until it is completely dry. You don't want it to shrink as it dries. Cloth shouldn't shrinnk as musch as vinyl, but why take a chance. I know there are seam protector liquids available for tents but I don't know if application of that on seams of vert top would help or not.
Pontiac 1926-2010
"We hardly knew 'ya"
Old 03-16-2005, 06:35 AM   #3 (permalink)
Luc
Luc's Avatar
Excellent! That's exactly the type of information I was hoping to get.
Old 03-16-2005, 06:48 AM   #4 (permalink)
wing's Avatar
Get 303 Aerospace protectant and spray the top it will help prevent fading.
wing is offline   Reply With Quote
Old 03-16-2005, 06:52 AM   #5 (permalink)
mceb's Avatar
http://www.properautocare.com/vinyl---convertible.html
http://www.autopia-carcare.com/exter...-top-care.html
Pontiac RIP 1926-2009
Old 03-16-2005, 08:25 AM   #6 (permalink)
Mod Emeritus
Also, keep it clean. Especially if you are putting it up and down a lot. If its dirty when your operating it, the dirt on it will act like sandpaper and increase wear on the material.
Solstice and Sky Fan
Old 03-16-2005, 08:34 AM   #7 (permalink)
SolsticeMan's Avatar
I've heard that the newer teflon sprays might be a good thing to use on cloth to prevent staining and improve rain shedding - though CAUTION: this is just what I've heard, I don't know if they recommend using stainguard on exterior sun-exposed surfaces.
If anyone knows if this is right or wrong, just thought I'd throw this in.
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
Old 03-16-2005, 08:42 AM   #8 (permalink)
Per Diem Administrator
brentil's Avatar
I'll have to get me some of that 303 Cloth protector stuff. Sounds good.
Save the Kappa!
NASSOA (TM)
Old 03-16-2005, 08:55 AM   #9 (permalink)
brentil's Avatar
It sounds like the 303 High Tech Fabric Guard is a stainguard. They say it's ok to use for in the sun, but just like waxing your car you're not supposed to apply it in the sun or hot area since it can cause discoloration. But after it's cured it should be fine.
Save the Kappa!
NASSOA (TM)
Old 03-16-2005, 10:49 AM   #10 (permalink)
Ex-Miata Man's Avatar
The good thing about the Solstice is the cover for the top. My Miata has a tonneau which is a real pain to carry along with you and to install. The end result is that I tend to not install the tonneau when I am only going for a short drive. Over the four years I have owned the Miata, the underside of the black top has faded into a dark brown as a result of the sun on it when it's folded down but not covered. I'll take the trunk cover any day over the tonneau even with the reduction in trunk space.
Ex-Miata Man is offline   Reply With Quote
Old 03-16-2005, 10:53 AM   #11 (permalink)
Mod Emeritus
Just as an FYI, Jeep recommends against putting any chemicals on the top of my Wrangler because it can clog the bores in the material causing it to wear out faster (I assume from heat buildup in the material). The recommend just frequent washing with mild soap and water.
Old 03-16-2005, 06:03 PM   #12 (permalink)
NytLyt's Avatar
Be very careful with spraying on a Scotchguard like chemical without knowing for certain how it affects the material with UV exposure. A while back, GM had offered Scothguard on their cloth seats. They discontinued it partially because the seats tended to fade noticably faster than untreated seats. This may be even worse on the top with constant exposure (for those without garages!). The sprays may be better nowadays, just suggesting you do some research before you spray.
Honest... I ran out of gas. I, I had a flat tire. I didn't have enough money for cab fare. My tux didn't come back from the cleaners. An old friend came in from out of town. Someone stole my car. There was an earthquake. A terrible flood. Locusts. IT WASN'T MY FAULT, I SWEAR TO GOD
NytLyt is offline   Reply With Quote
Old 03-16-2005, 06:16 PM   #13 (permalink)
RODEO's Avatar
search these forums, the have a lot of care tips for cloth, vinyl, and general car care.
http://forum.miata.net/ubb/ultimatebb.php
http://mazda-speed.com/forum2/index.php
might as well use the resource, eh!
RODEO is offline   Reply With Quote
Old 03-17-2005, 06:34 AM   #14 (permalink)
Luc
Luc's Avatar
Are convertibles generally ok in car washes or should I stay away from them?
Old 03-17-2005, 07:39 AM   #15 (permalink)
chenslee's Avatar
I've never owned a 'vert either, and top care scares the crapola out of me. It's 2005 and instead of rocketing around in hovercars, we're still putting canvas tops on environment destroying hydrocarbon burning death traps. Cool, yes; logical, no. My take on raggtop care? By the time the top begins to visibly deteriorate and lose function (about 45 min. after the warranty runs out), a hardtop will be available and you will be ready for a change anyway.
..Then again, I could be (f)lying.
chenslee is offline   Reply With Quote
