Old 04-17-2008, 06:11 PM
   Deck Lid Misalignment
Send a message via Yahoo to sol_lover
Has anyone noticed that the deck lid is higher on one side than the other? I just noticed that the side behind the driver is about 1/4" higher than the rear section at the back end. The passenger side of the deck is flush. I've never stored anything in the "trunk" so I'm not sure if was always like this and I never noticed (not likely) or if something is out of alignment.
Thanks
Computers Rock. My Solstice Rolls! She's called Shadow. Mysterious with Premium package, smoker's, 6 CD & mp3, Monsoon, ONStar, XM, etc.
sol_lover is offline
Old 04-17-2008, 06:29 PM
Dark Tech's Avatar
If you are going to the Plant tour in Delaware, they will align your deck lid for you. Normally that is caused when improperly closing the trunk. There is a possibility that you have received the car like this.
The best way to prevent it from flexing more is by closing it where the humps start behind the drivers side or the passengers side seat. To best describe it, the frame is the strongest place on the trunk. Commonly kappa owners will use the silver ring where the top clips in on the trunk lid.
Dark Tech
Owner of Mysterious GXP, Son of DeepBlueGXP, Electronic Technician.
Waste gate mod, Gm certified cold air intake, garage door opener install, magnaflow exhaust, painted brake calipers with GXP lettering, wind restrictor, debadged, Front license plate hide away holder, JPM center council w/shadow, custom license plate reads "DRKTECH, Dejon spring. Norms Fiberglass Dual out valance with defusers.
Dark Tech is offline
Old 04-17-2008, 06:37 PM
Dark Tech
I've always made a point to close it using one of the humps but thanks for the affirmation.
BTW, been off of the forum for a while - when is the Delaware tour?
Old 04-17-2008, 06:49 PM
Dark Tech's Avatar
MECCA II - The Waiver [Plant Tour May 9, 2008]
If you still want to go PM JustMike for a waiver. They are not turning anybody away.
Old 05-16-2008, 04:49 PM
Chet-O's Avatar
Thanks
My GXP has the same problem, which the service department could not figure out. I noticed a GXP in the dealer's lot that was the same. Since I pointed that out to the service department, they wrote on the repair order that I was satisfied. I was not.
My 06 Solstice lid was perfect all around!
Chet-O is offline
Old 05-16-2008, 05:00 PM
Mine is off on the passenger side, taking it in next week when I get my friggin door handle replaced.
EndiSky is online now
Old 05-16-2008, 05:03 PM
MomsSol's Avatar
What I *thought* was a misaligned trunk was actually a misaligned LATCH.
The wonderful FIX-IT guys at the TLC tent at MECCA fixed it right up!
NASSOA(TM)
MomsSol is offline
Old 05-16-2008, 06:12 PM
Now just send some of those guys out here to SoCal, if the dealer can't fix it the first time then I will be forced to go to Mecca next year!
Old 05-16-2008, 10:15 PM
I close mine using the tiedowns for the factory luggage rack. It works great. They are connected directly to the structure inside the trunk.
Old 05-21-2008, 08:06 AM
Kurt's Avatar
Does anyone know where the adjustment for the rear deck lid is at?
Kurt is offline
