Door handle problem - Pontiac Solstice Forum
 4Likes
  • 1 Post By rob the elder
  • 2 Post By ChopTop
  • 1 Post By Treeman
post #1 of 8 (permalink) Old 07-26-2016, 12:57 PM Thread Starter
Junior Member
Door handle problem
Just this morning I went to open my driver's side door and when pulling the door handle to open the door the whole mechanism starting pulling out of the door. By whole mechanism I'm referring to the portion containing the key lock. This portion of the door handle should be anchored solidly to the door, mine is starting to pull out when I pull on the door handle. No warning this was loosening up as you would get with a bolt and nut working loose so I'm thinking a "C" clip or something similar has let loose. Am I opening a whole can of worms if I take the inside door panel off? Or is this a job best left to the dealership?
D.Klug is offline
post #2 of 8 (permalink) Old 07-26-2016, 01:11 PM
This is a well known failure. There are three 10mm bolts that secure the handle to the door. The two on the rear end of the handle are known to fail on a regular basis.
You can remove the door inner and by removing the three retention bolts remove the door handle. Many, including myself, have used JBWeld epoxy to repair the handles. I repaired one after the threads failed and the other three before they actually failed.
You can buy improved Cobalt handles on line. The newer units are reinforced structurally to help with this problem, but can fail if not reinforced with JBWeld.
If you take it to the dealer they will charge you full retail for the handle (same part number with same failure rate) plus the labor to do the install.
See many threads on this subject for more information.
Sting Ya likes this.
Carol's husband for 48 years
post #3 of 8 (permalink) Old 07-26-2016, 03:09 PM
ChopTop's Avatar
The door handle on the right is the area that bust, the door handle on the left is the reinforced version. GM used the non-reinforced handle on several models (cars listed below), and it also comes in an unfinished black version. Meaning it has several different part numbers.
I purchased some unfinished black Cobalt door handles last year and had them painted gloss black to match my car. I thought I had bought the reinforced version but did not, and per RTE suggestion used JBWeld to reinforced the handle.
Watch these videos to get an idea of how to remove and replace door handles. I'd say the most important tip is once you pull the door panel is do not let it drop. There's an inside interior door handle cable you have to be somewhat careful with. When you remove the door handle bolts either have magnetic socket inserts or do what I did after I dropping bolts a few times, I used chewing gum to help keep the bolts in the socket. Hey it worked.
https://www.youtube.com/watch?v=qkjuy1zbjNA
https://www.youtube.com/watch?v=sQWZxdLYAbI
https://albuquerque.craigslist.org/pts/5697088485.html
2006 - 2011 Buick Lucerne
2005 - 2009 Buick Allure
2006 - 2009 Pontiac Solstice
2007 - 2010 Saturn Sky
2006 - 2012 Chevrolet Impala
2005 - 2009 Buick LaCrosse
2007 - 2009 Pontiac G5
2006 - 2007 Chevrolet Monte Carlo
2005 - 2010 Chevy Cobalt
rob the elder and Sting Ya like this.
ChopTop is offline
post #4 of 8 (permalink) Old 07-27-2016, 07:05 PM
gwhunter12's Avatar
Send a message via Yahoo to gwhunter12
I remember that one.
When you remove your original handle you will see the necessity for the JB Weld in filling the area surrounding the barrel nuts. Follow procedures and all goes well,don't drop the bolts.
Completely eliminates failure of new handle. While your mixing the JB you might as well repair the center consoles cracks.
gwhunter12 is offline
post #5 of 8 (permalink) Old 04-17-2017, 08:27 PM
44thSKY's Avatar
I ran into a loose door handle, so I just have to bump this post!
The two video's listed above were invaluable to my understanding of how to remove the door panel AND what & how to fix the problem. Thanks to all contributors.
44thSKY is offline
post #6 of 8 (permalink) Old 04-17-2017, 09:38 PM
Welcome. I have had both cars door panels off multiple times and have posted oics each time on the Punisher thread
post #7 of 8 (permalink) Old 04-20-2017, 05:53 PM
44thSKY's Avatar
My coupe curbside handle was not loose at the rear of the handle, but was loose on the front of the handle. So it appeared to be a fix of just removing the door panel and putting a socket on the bolt head and tightening.
I may have missed it on the video, but I recall the video mentioning only a 7MM socket. It turned out the socket for the three bolts holding the handle were 10MM. After finding the correct socket size, it was a simple fix of just tightening the front bolt. It did, however, take about a 6 inch socket extension to reach the bolt head and tighten.
For now, the two rear handle bolts are secure, so an easy fix this time. However, a future fix may involve the JB Weld route.
44thSKY is offline
post #8 of 8 (permalink) Old 05-01-2017, 05:26 PM
Treeman's Avatar
The door handle on my 2009 broke and when I pulled it off, it looks like the Cobalt handle with the 3 reinforcing strips. So, these handles may be better but they still break. I reinforced the new and the original on the other door with epoxy. I suggest all do this when replacing their handles.
Sent from AutoGuide.com Free App
rob the elder likes this.
2009 Aggressive GXP
DDM Race Backbone, ProBeam, Coil Cover, Alignment, and Oil Catch Can
Solo Mach Shorty Exhaust
GMPP Tune
LatinVenom Front Brace
Werks Adjustable Sway Bars
Enkei Ammodo Wheels
Michelin Pilot Super Sport Summers/Pirelli 240 Sottozero Winters
Hawk HPS Brake Pads
Sound Deadener Showdown
Beach Party Central Custom Fusebox Cover
JPM Arm Rests
Lead Foot!
Treeman is offline
