Fantasy Tranny Swap - Pontiac Solstice Forum
Old 08-19-2012, 01:26 PM   #1 (permalink)
Carpe Diem's Avatar
Fantasy Tranny Swap
There's been some discussion on the forum about how some would desire paddle shifters as an aftermarket item for our Sols. As far as I know, nothing has ever come of it.
My wife drives a Mercedes E350, with an auto tranny of course. No paddle shifter, but the tranny has the usual P, R, N and D. While in D, you can push the shirt knob to the right in be in D (full 6-speed automatic). But each time you pull it to the left, it drops down one gear and stays in that gear. So, by starting with 6 clicks to the left, flicking it to the right once whenever I want to up shift, it's kinda like a manual one-paddle shifting tranny. When she drives it, it stays in D, but when I drive it, I like to play in the gears, down shifting, just playing and 'being in control'.
So, now and then I wonder what it might be like to swap the 5-speed stick for a 6-speed faux-paddle shifting Mercedes tranny. Who knows, maybe the stock Sol auto tranny has this capability. I don't know. There might be other more easily adapted swaps other than the Mercedes, but I don't that either. But it's kinda fun to think about.
Carpe Diem
'Mysti' - '08 Mysterious 5-spd GXP, Custom HP tune, Hahn I/C, K&N filter, DDM ProBeam & Backbone, splash guards, Z0K Sway bars, poly bushings & BC Coilovers, Magnaflow catback, Solo hi-flo cat..
Old 08-20-2012, 07:21 AM   #2 (permalink)
glake89's Avatar
Some Pontiac and Cadillacs of the same era used the same transmission (5 sp auto) with that sport shift function. It is controlled by a switch mechanism on the shifter assy. and the TCM. Should be an easy conversion as parts are all GM.
glake89 is offline   Reply With Quote
Old 08-20-2012, 06:17 PM   #3 (permalink)
GS Stage 1's Avatar
Didn't one of the forum members successfully install paddle shifters on the stock auto? Seems like it was someone in Japan?
Old 08-20-2012, 06:20 PM   #4 (permalink)
John_Salgado's Avatar
Paddle shift with auto-transmission
korea
heres the vid Daum tv? - ????? - ???
SOLD
NOW 2013 Dodge Dart 1.4T 6-spd
Mods:
White hurst shift knob
Custom Rims size 18x8 and a 1/8th spacer in the front to clear the caliper
Blacked out grilles
Debadged
Blacked out arrows
Audio:
Some jvc radio thing
with single din storage
Kappasphere parts:
Kappa springs
Kappa luggage rack
On the way:
Home made WR
Front lip splitter
Tinted windows 5%
Backbone
Rebar
TURBO INCOMING
John_Salgado is offline   Reply With Quote
Old 02-17-2013, 04:07 PM   #5 (permalink)
6L90E 6-Speed Automatic
The 6L90E is a GM hydramatic transmision with Driver Shift Control (DSC). DSC allows the driver to manually shift gears, similar to a manual transmission. When the shift selector lever is moved to the DSC position, the driver may manually select upshifts or downshifts.
Wade's garage lists this as an option when doing V8 or V6 engine swaps. Not sure if it could be done with the stock 2.4 or 2.0 turbo.
Cypress is offline   Reply With Quote
Old 02-17-2013, 04:20 PM   #6 (permalink)
chickenwire's Avatar
I dunno. The title of the thread is just kinda creepy.
Old 02-17-2013, 04:50 PM   #7 (permalink)
worksafe?
Yep. I was a little worried to open this at work.
Old 02-17-2013, 05:46 PM   #8 (permalink)
SOLSTICE-D's Avatar
My wifes kia forte has paddle shifters and I got to say its a pretty cool feature, but i have to have a clutch just seems weird without it.
2006*COOL*SOLSTICE
POWDER COATED RIMS
C.F INTERIOR
STEREO: ALPINE SPS-610C, PRECISION POWER 8"
DEBADGED
A.E.M: COLD AIR INTAKE
MAGNAFLOW: DUAL EXHAUST
GXP PARTS: FRONT BUMPER, FULL FE3 SUSPENSION
EIBACH SPRINGS: SPORT LINE
KAPPASPHERE: REBAR
DDMWORKS: RACE BACK BONE
ASAP.DIGITAL.IMAGING: SLOTTED BACK UP LIGHTS,SIDEMARKERS,THRID BRAKE LIGHT,TURN SIGNAL/FOG LIGHT COVERS,TRANSFORMER OVERLAYS
SOLSTICE-D is offline   Reply With Quote
Old 02-17-2013, 07:59 PM   #9 (permalink)
1 LIL NDN's Avatar
shifter
My turbo PT has what Chrysler calls an Auto-stick . It has P R N D & AS. You apply brake peddle and pull to AS mode . As long as its in that you just tap shifter from left to right and it does control the RPM's through the gears . If my sol was an auto I would think about that Option , It works easier than having to push the clutch in . Just saying
1 LIL NDN (Find me and the Chief onThe Kappa Performance Forum any time)
1 LIL NDN is online now   Reply With Quote
Old 02-18-2013, 03:13 PM   #10 (permalink)
BAM!!! I was HOPING someone said this first...
Investo-Coupe is offline   Reply With Quote
Old 02-20-2013, 09:57 PM   #11 (permalink)
Qoute
Asked Wades and autowerks, both said could be done, but would be expensive. $6k to $7k. Guess it would require some custom parts to connect up, and the wiring and programming.
