I need advise, can I install a base model front fascia on an 07 GXP model? This car now has an ugly aftermarket unit with cheap expanded metal grille inserts. Please advise, this car still has the fog lights hidden behind the fascia.
Larry Rice
Several owners have installed GXP front bumper covers on NA cars but I don't remember anyone going the other way
They are basically interchangeable but the foam energy absorber is different. It needs to be trimmed on an NAtofit a GXP cover. I'm not sure if it will need to be trimmed or not
Of course the other difference is the lack ov brake cooling inlets on the NA bumper
If you like that look better, go for it. Just expect you may need to do some extra effort to install it
Your "ugly" front bumper cover, might be a really nice aftermarket bumper. Norm makes custom bumper covers for our vehicles. Furhtermore an NA bumper first will not have brake ducting for your front brakes. Second it will not have grill work for your IC. Your IC needs cool air or you it will not work and just be pushing super heated air back into your motor. I would not recommend an NA bumer cover on a GXP. I don't know where you live, but if you live in a warmer climate, this might even cause your car to overheat because of the hot air you'll be pushing into the motor.
Post a picture of your bumper here. You might find someone with a stock gxp bumper that would want to trade straight up or even have them give you a little cash on top
Thanks to you all for good advice. I will stay with the GXP front fascia. I will send pictures as soon as I figure out how this is done. The bumper cover is an RK Sports unit. The fascia needs to be sanded, primed, and repainted. The paintwork was not properly prepared, it is peeling at the edges. There are some scratches along the bottom. Any interest?
Related Threads
Pontiac Solstice Forum
1.4M posts
38.2K members
Since 2003
