GM Roadster HID kit help needed
**HELP!!**
I bought the GM Roadster HID kit for my Sky Redline....
If there is anyone else who has installed this HID headlight kit, I really need your help!
It is late, so I will call GM Roadster Club tomorrow if I have to, but I hope someone will read this and help me tonight!
The install is going fine, but on the instruction sheet, I need someone to explain to me steps 15 and 16!
"On the passenger side headlight, using a volt meter find the positive side of the plug. Now take the supplied H11 female plug and push the short pin with the barrel connector into the back of the supplied plug on the positive side and make the connection. Strip the red wire from the relay and press it into the barrel connector and crimp it."
What I don't understand is: What is the H11 female plug plugging into? It sounds like they are wanting me to strip the power wire coming from the relay and crimp it into the barrel connector which is connected to a long skinny blade looking thing, and press that blade looking thing into the H11 female plug. But, what do I plug that into? I'm not even sure that I have correctly identified the "H11 female plug".
Also, I have a volt meter, so how do I use it to determine the "positive side" of the plug??? when the plug has no power???
