Old 02-27-2005, 08:40 PM
   Ground Clearance
jandouglass's Avatar
Does anyone have a figure on min. ground clearance?
jandouglass is offline
Old 02-27-2005, 08:53 PM
achieftain's Avatar
Reported by insiders to be lower than the new Corvette C6.
achieftain is offline
Old 02-27-2005, 09:40 PM
Administrator
brentil's Avatar
GM has at pretty much said at all the Solstice showings at car shows that the Solstice has the lowest ground clearance of all the cars GM has in production. So figure it's at least one atomic molecule shorter then a Corvette.
brentil is offline
Old 02-28-2005, 08:46 AM
Administrator
SolsticeMan's Avatar
What IS the ground clearance of the 'Vette?
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
SolsticeMan is offline
Old 02-28-2005, 09:30 AM
achieftain's Avatar
We thought you knew, Bob, er solsticeman. GM is silent on the actual number and none of the road tests give a number, although one reference saya "minimal ground clearance contributes to low drag coefficient" So I guess the Solstice g.c. is "less than minimal?"
Old 02-28-2005, 09:47 AM
chenslee's Avatar
If they were worried about drag, they should have made it a coupe. I mean, the windsheild abruptly stopping isn't exactly aerodynamic. This reminds me of the first S2k's with the plastic rear windows. Honda's excuse was "weight savings" over a glass window. If they were concerned about weight savings, they would have done a manual top rather than powered.
..Then again, I could be (f)lying.
chenslee is offline
Old 02-28-2005, 10:46 AM
slowandlow's Avatar
ground clearance what is that i droped my alero over 2 in it will scrape once in a while but not that bad.
slowandlow is offline
Old 02-28-2005, 11:50 AM
Administrator
slowandlow,
how tall can an object (like a log) between the wheels be and your alero still get over it?
Old 02-28-2005, 11:52 AM
Administrator
brentil's Avatar
2005 C6 Corvette
Ground Clearance: 5.00 in | 127 mm. | 0.1 m.
brentil is offline
Old 02-28-2005, 01:41 PM
The Orange One™
Fortimir's Avatar
Send a message via ICQ to Fortimir Send a message via AIM to Fortimir Send a message via MSN to Fortimir Send a message via Yahoo to Fortimir
Under FIVE inches?
Man, that's going to look intimidating on the road (expecially with Xenon lights)...
...but i'm afraid to go over raised railroad tracks.
Not an owner any longer.
They call me The Orange One™
Fortimir Design
R&R Music Central
The Best iPod Solution for your Solstice
Fortimir's current screenshot
Fortimir is offline
Old 02-28-2005, 04:33 PM
mceb's Avatar
Here's a pic I took at Philly show of the clearance. Seems in 4-5" range?
http://www.solsticeforum.com/photopo...at=3021&page=3
You can see the scratches where they hit the underside probably going up the ramp to the truck.
2006 VIN #30, first 1000 series, black exterior, sand/steel interior
mceb is offline
Old 02-28-2005, 04:41 PM
waiting's Avatar
That's scary. There are going to be a lot of scratches in the front of cars owned by people with steep driveways or shallow curb cuts. Or those that live in apartments with speed bumps.
Brian
waiting. patiently.
waiting is offline
Old 02-28-2005, 04:44 PM
mceb's Avatar
I'm wondering if that's what that small lip is hanging off the underside...to take the hits instead of the body?
mceb is offline
Old 02-28-2005, 04:59 PM
waiting's Avatar
As I understand it, that brings air up into the radiator and helps cool the engine. I ripped mine off on a parking block and the engine seemed to get hot quicker and the fan ran more. BTW it was pretty expensive to replace. Don't destroy it.
Brian
waiting. patiently.
waiting is offline
Old 02-28-2005, 08:19 PM
Fformula88's Avatar
An approximate 5 inch ground clearance is still manageable on driveways. The tallest could scrape and you would have to be careful, but I think the Sol will be pretty good with driveways. Since the wheels are so far out to the corners, there isn't much of an overhang to drag.
The showcar may have seen excessive abuse from all the loading, traveling, and unloading to autoshows along with any other testing it has undergone.
We Build Excitement
Fformula88 is offline
Old 02-28-2005, 08:49 PM
