leaks -water on driver side floor-help finding source - Pontiac Solstice Forum
post #1 of 12 (permalink) Old 02-14-2013, 12:23 AM Thread Starter
zzzybil's Avatar
doldrums and itching to drive (( I T ))) again - been raining here for weeks......ginourmous muddy slop hole at edge of driveway haha has kept me penned in.......
anyways YEP I GOT A LEAK - only driverside floor gets wet - .....looked at base of windshield ?? not seeing anything OBVIOUS .....
SMALL tear at top weatherstripping - ???-@ roofline obviously stuck together and tore lil nugglet upon openning - anyone know of a weather stripping goop substance /liquid gasket ??.....not sure its the source ???......but if i can find appropriate goop to seal that ???.........
ITS NOT LEAKIN AT WINDSHIELD ROOF CONNECTION - getting or draining on floor from ?????? idk where....
OTHERWISE........ANYBODY ELSE SOLVED LEAKS
or had water on driverside floor and figured it out ??????
BOOsted 2.4
42lb injectors
3" tubes front to back
10 boost
38mm tial wastegate / bov
custom i/c (BELL)
Werks radiator
aem wideband
gxp exhaust /magna flo - integrated dumptube
hi flo cat
HPTUNING -
(tune therapy -> randy @DDM)
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
custom .08ss heatshield
SPEC 2+ UNsprung
YEAH I DID THAT !
zzzybil is offline
post #2 of 12 (permalink) Old 02-14-2013, 07:07 AM
I don't know of any repair stuff for the seals (not that there isn't any, just none that I know). I would try a dollop of black silicone caulk - but make sure it's smoothed out level with the rest of the seal.
As for the leaks, there have been many threads and different fixes. Sorry I don't have links you'll have to search yourself.
post #3 of 12 (permalink) Old 02-14-2013, 10:42 PM Thread Starter
zzzybil's Avatar
thanks soup
thats a good idea - i was thinking liquid gasket - some black silicone caulk prolly much better idea....assume like for a tub or roof ?
how to do it NEATLY ...any clue on solvent for clean up....tips
my caulking memories/experience = always messy....... yeah yeah tape it off ....read the tube....
not lookin forward to this experiment ....
BOOsted 2.4
42lb injectors
10 boost
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
HPTUNING -
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
SPEC 2+ UNsprung
YEAH I DID THAT !
zzzybil is offline
post #4 of 12 (permalink) Old 02-15-2013, 07:43 AM
You can get tubes of Permatex brand black silicone in most auto parts stores - prolly Wallymart too. Yes, tape off everywhere you don't want it. Smooth it with a piece of flat plastic (an old credit card is good), then smooth again with water and a clean edge of the plastic - or even a wet finger. (Note water won't do any damage, it actually acts as a catalyst for most silicone caulk, to harden it)
PLEASE NOTE: this is just an idea. I don't know if it'll work properly or not and I take no responsibility if it doesn't!
E.g. Buy Permatex Black Silicone Adhesive Sealant 81158 at Advance Auto Parts
post #5 of 12 (permalink) Old 02-15-2013, 08:18 AM
chickenwire's Avatar
Unless I saw a seriously damaged or worn rubber seal, I would attempt the silicone also if it were my personal ride. Biggest thing I've found with caulking/sealing is to open the tip only as large as absolutely necessary and be slow and extremely patient. Use the absolute minimum amount.
A wet finger then can smooth the surface nicely.
chickenwire is offline
post #6 of 12 (permalink) Old 02-15-2013, 09:01 AM
idkfa's Avatar
Just because you mentioned it might not be the source, there's also potential for leaks around the firewall near the pedals.
Have a friend break out the hose and climb around inside until you find the stream :-D
idkfa is offline
post #7 of 12 (permalink) Old 02-15-2013, 03:52 PM
dirtyrob67's Avatar
I agree w/ idkfa.. My driver side floor gets wet as well and I tend to feel a cold air draft when I turn off the heat so its definitely coming from the firewall area. I haven't identified it either. But, will have it on jack stands at the end of the month poking around that area. As for the surrounds I usually thoroughly clean all rubber surface and apply a light coat of dielectric grease haven't had a problem so far.. If you do find the cause please share..
Good luck
Lil chromies DDM Pro Beam
RK Sports body kit KW coil overs
Hahns Hi flow cat DDM Back bone
Hahns stage IV turbo tuned by BTF
Synchronic Blow Off-Valve
Solo Performance rear valence
konig hot swap wheels
BF Goodrich TA tires
Eneregy suspension bushings
Solo Performance mach exhausts
changed diff to 3.73 ratio from gxp
dirtyrob67 is offline
post #8 of 12 (permalink) Old 02-15-2013, 11:09 PM
The seals on the car are pretty good. There have been complaints about leaks due to the side window not coming into full contact with the rubber seals. The windows are adjustable for height, and in / out angle. Also, some over the door seals, since they fold with the top have been known to stick and not fully open when the top is up. A little spray lube on the hinge point can not hurt.
I had a T top Camero when we lived in Seattle in the 70s. I used silicone sealer every winter to stop the rain coming into the car. It peeled off in the spring
Carol's husband for 48 years
post #9 of 12 (permalink) Old 02-15-2013, 11:35 PM Thread Starter
zzzybil's Avatar
brainstorming
yes now that you mention it ..... maybe i do remember a draft at my feet ?.....still too wet & cold out to play with hose or goop for that matter.
i'll certainly come back if i figure it out - let yall know....... its bound to warm up and get nice SOON.......
THANKS any all ideas welcome
BOOsted 2.4
42lb injectors
10 boost
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
HPTUNING -
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
SPEC 2+ UNsprung
YEAH I DID THAT !
zzzybil is offline
post #10 of 12 (permalink) Old 02-16-2013, 08:34 AM
1 LIL NDN's Avatar
After a rain I have found water on the outer door sill but never any on the Carpet. I use to go through a touchless car wash and the power spray came in at the front of the window but not all the time.
1 LIL NDN (Find me and the Chief onThe Kappa Performance Forum any time)
1 LIL NDN is offline
post #11 of 12 (permalink) Old 02-17-2013, 07:24 AM
g8gt09's Avatar
The best way to check for a water leak is to start at the lowest point of the car with water and gradually move up to the highest point. That way you eliminated may points of entry and can just concentrate on a few. Just because you see a probable point of entry doesnt mean that you've found the exact spot.
g8gt09 is offline
post #12 of 12 (permalink) Old 02-18-2013, 06:34 PM
GS Stage 1's Avatar
Amen Brother. If I had a dollar for every time that happened to me, I'd be a rich man by now.
GS Stage 1 is offline
