Solstice 08 double din navigation install help! - Pontiac Solstice Forum
Old 12-06-2012, 03:23 AM   #1 (permalink)
im new here and have some questions. Please help. did a lot of research and even called metra and schoche, but didnt get a definitive answer.
I have a 08 2.4 Liter with on-star, bluetooth, without Monsoon. I want to keep the turn signal, warning chimes and everything including on-star(even I never used it before) and bluetooth. What harnesses do I need to purchase for the radio and for turn signals, chimes etc.?
Also, where can i get the perfect fit adapter for the front speakers replacements (I am trying to avoid splicing or soldering any wires). crutchfield had the rear speaker (3.5inch) harness that was just connect and plug.
junghoon33 is offline   Reply With Quote
Old 12-06-2012, 11:03 AM   #2 (permalink)
chickenwire's Avatar
Welcome jung! I don't have any first hand experience with your concerns. There is a search feature on the forum toward the top of each page in a dark gray block with pull-down menus. The "google search" tends to work much better than the standard site search. I used it to yield the following results:
Pontiac Solstice Forum | Solstice Pics | Photos - Search Results for double din nav installation
Hopefully that can get you some leads on solutions.
Old 12-06-2012, 11:29 AM   #3 (permalink)
Go to PAC, or Metra (they are the manufacturers of many of these wiring harnesses and modules needed to retain features such as turn signals, and onstar). Enter your make/model/year, and it will tell you exactly what you need to have what features you want.
Just a tip, even though Metra says their all in one unit works and does all features, they lie and it was confirmed with a technical support rep whom said "we have never been able to make all features available on your car" my response "so why does it explicitly say in your material and application database that it does?" their's, "our apologies, we do our best with keeping applications accurate, but we make mistakes". I could not get some of the features to work, and in the end had to use 2 separate modules/harnesses. But it's not a big deal, most cars with features like on-star, steering wheel buttons, etc, need 2.
Old 12-06-2012, 12:49 PM   #4 (permalink)
lil goat's Avatar
Like he said, I have double din in mine with all the bells and whistles
Wester's Garage tune
RMR Style Bar.
HKS Coilovers
JL Audio 10" sub
Old 12-08-2012, 01:52 PM   #5 (permalink)
Where can I get the harness for the front speakers to avoid splicing the wires??????
Old 12-09-2012, 08:29 AM   #6 (permalink)
Sly Bob's Avatar
Go to Crutchfield.com and put in you information.
You'll need something like the Metra GMOS-LAN-03 GM Factory Integration Adapter
Metra GMOS-LAN-03 GM Factory Integration Adapter Lets you install a new stereo in select 2006-up GM vehicles while retaining OnStar and factory warning chimes at Crutchfield.com
Delivered on May 27, 2008
Sly Bob is offline   Reply With Quote
Old 12-09-2012, 04:29 PM   #7 (permalink)
i found out about the GMOS, but i was asking about FRONT DOOR SPEAKERS. Harness to hook up new aftermarket front door speakers without cutting or splicing the factory speaker wires from the car.
