Turn signal all of a sudden clicks faster.. why? - Pontiac Solstice Forum
Old 03-31-2008, 02:29 PM   #1 (permalink)
Send a message via Yahoo to InfamousX
Ok this actually happened a while ago before I sold the car but the topic had just come back up with me and some friends and I couldnt figure it out. When I signal for a left turn the signal or clicker or whatever it is inside the car that lets you know your turn signal is on, it all of a sudden "clicked at a much faster rate then normal. The right turn signal still does it at the normal rate. Anyone know why this change happened?
InfamousX is offline   Reply With Quote
Old 03-31-2008, 02:30 PM   #2 (permalink)
kwtoxman's Avatar
burnt out bulb
kw.....
07 GXP
kwtoxman is offline   Reply With Quote
Old 03-31-2008, 02:35 PM   #3 (permalink)
Originally Posted by kwtoxman View Post
burnt out bulb
kw.....
Thats interesting. Especially since at the time it happened the tail light bulb was out. After replacing I think it was right turns all the way home so I didnt notice it again lol.
Old 03-31-2008, 02:42 PM   #4 (permalink)
diamoney's Avatar
Like kw said...
A burnt out bulb causes a drop in the resistance in the circuit, so all the lamps on that relay cycle faster.
Ninjas hide in plain sight. I don't believe I have a car that can blend into its surroundings. Some people are the same way. We are suited.
#000600 Aggressive
diamoney is offline   Reply With Quote
Old 03-31-2008, 02:56 PM   #5 (permalink)
beecee's Avatar
That's really good to know!
2008 Mysterious GXP (MoMo)
My cardomain page
VIN 100541 - Drove it home 7/13/07. As of today; 3/8/13, 76,000 Miles
Daily driver.
I'm at WalMart riding the ponies, bring quarters!
beecee is offline   Reply With Quote
Old 03-31-2008, 03:34 PM   #6 (permalink)
jackl's Avatar
burnt out bulb
kw.....
or connector is off.
SSOOO Facebook Group
2006 Solstice - DDMWorks [Stage II Supercharger, Race Backbone, Powder Coated Valve Cover, Coilcover, A-Pillar Gauge Pod & Header Heat Shield Blanket], Privat Gassen wheels (8.5"F & 9.5"R) w/245/40ZR19 (F) and 255/40ZR19 (R) Hankook Ventus V12 Evo, Solo [SQR2 Exhaust & High Flow Cat], Eibach Pro springs, VDO Gauges, Razzi wing, JPM [Shifter, Centre console & Door pads], Tint*Master Tint, Kappasphere [KappaShield, KappaROO Pouches & KappaATTIC], Kuda Cell Mount
jackl is offline   Reply With Quote
Old 04-05-2008, 05:54 PM   #7 (permalink)
JGene's Avatar
If you install LED bulbs into your car, that will also cause it to click faster. Plus if the dealer checks the BCM (body control module), it'll report a burned bulb.
So high, so low, so many things to know.
VIN 8694 delivered on February 3rd, 2006. Three years later and I'm still enjoying it just as much as the day I took delivery.
DDM Stage II and Spec 2+ clutch/flywheel installed :)
JGene is offline   Reply With Quote
Old 04-05-2008, 07:16 PM   #8 (permalink)
WWI Flying Ace's Avatar
'tis a burned out bulb. I had this and got it fixed when they did my recall...no more worries.
WWI Flying Ace is offline   Reply With Quote
Old 04-06-2008, 05:56 AM   #9 (permalink)
BritSolDriver's Avatar
Originally Posted by diamoney View Post
Like kw said...
If the bulbs are in parallel, wouldn't a burnt out bulb increase the resistance?
series Rt = R1 + R2 + R3
parallel 1/Rt = 1/R1 + 1/R2 + 1/R3
BritSolDriver is offline   Reply With Quote
