*WARNING* Double check timing sets from autoparts store. - Pontiac Solstice Forum
 4Likes
  • 2 Post By DaveOC
  • 1 Post By ExtraSour
post #1 of 11 (permalink) Old 03-16-2017, 07:21 PM Thread Starter
ExtraSour's Avatar
I have recently purchased a timing set from advance auto to replace my old one, The one they have for the 2.0 is actually for the 2.2 or the 2.4 even though the system says its fro the 2.0l turbo. I have checked advance, and autozone. The cam sprockets in these sets are wrong. just thought i would warn everyone.
2007 Solstice GXP
Trifecta Tuned
Custom Welded 3 inch Exhaust
SOLO Performance 3 inch Catless DP
K04R Turbo upgrade
ExtraSour is offline
post #2 of 11 (permalink) Old 03-16-2017, 08:32 PM
AKA SolWhat?
DaveOC's Avatar
Thanks for the warning.
raygun and ExtraSour like this.
1st 1K - #741
DaveOC is offline
post #3 of 11 (permalink) Old 03-16-2017, 08:55 PM
blackbirdracing's Avatar
FYI the LA gear timing sets from Advance auto parts are junk.
I suggest the use of only OEM AC DELCO
Or CLOYES brands.
Cloyes makes the oem set for GM.
Cheapest place is rockauto.com
Mods... LDK short block P werks tune, P werks CAI/ turbo inlet pipe, P werks hot & cold side piping, P werks rear suspension brace, Pwerks Valve springs, Pwerks intercooler, Pwerks phonelic spacers, Pwerks Hf cat, GM 3bar map sensors, Pwerks cross drilled / slotted rotors, Hawk HPS pads, Pwerks stainless steel break lines, Solo Street race exhaust, street edition headlights, DDM 6000K hids.
blackbirdracing is offline
post #4 of 11 (permalink) Old 03-16-2017, 09:46 PM Thread Starter
ExtraSour's Avatar
Or CLOYES brands.
I am returning the ones i bought and have a set coming from cloyes tomorrow
blackbirdracing likes this.
2007 Solstice GXP
Trifecta Tuned
K04R Turbo upgrade
post #5 of 11 (permalink) Old 03-17-2017, 05:27 AM
chickenwire's Avatar
Good to know - hopefully I never have to worry about it! (crosses fingers)
chickenwire is offline
post #6 of 11 (permalink) Old 03-17-2017, 05:44 AM
Thanks for the warning....thus the reason I suggested DDMWorks or PAW for the parts!! I DO NOT deal with aftermarket companies when it comes to vital, hard to replace parts.
I learned my lesson with my intake manifold on my Mustang. Autozone....took 3 intakes to get me one that wasn't cracked and spewing antifreeze. The guy that did it for me literally took the part back the 2nd time and told them that if it didn't work, he was charging them labor.
post #7 of 11 (permalink) Old 03-17-2017, 05:46 AM
Rockauto can't be beat for pricing from what I've seen.
They carry alot of OEM parts as well
But of course buying from one of our vendors means you'll always get tested right part.
You just can't beat thier experience and knowledge.
post #8 of 11 (permalink) Old 03-17-2017, 01:13 PM
I've had enough part failures - alternator, PS pump, cam actuators, etc. - that I now only buy OEM unless I'm looking for a performance upgrade.
And, if you look, you can find great deals on OEM parts. I got an OEM brake booster + master cylinder (with the reservoir and the big-ass pancake bladder) for $50 shipped, new-in-box. Which is weird since a lot of places are selling just the master cylinder for $140.
Shrug.
Blue-ish 2006 2.4, Werks stage 1 turbo, GMPP cat-back, TCE Wilwood 6 piston front brakes, 4-piston rears , Stainless brake lines, slotted and drilled rotors, DDM braces, BR Racing coilovers, Spec aluminum flywheel, Spec stage 2 clutch, Werks aluminum radiator, DDM oil catch can, Autometer boost, water and AFR gauges, RKSport hood, Morimoto FX-R HID headlights, GReddy Profec boost controller @ 13PSI, custom A-pillar gauge pod.
In progress: custom fiberglass trunk lid.
Currently on engine #4!
post #9 of 11 (permalink) Old 03-17-2017, 05:17 PM Thread Starter
ExtraSour's Avatar
Yeah these cam sprockets were just that, the sprockets with no actuator on them. I returned that set and ordered some from dorman
2007 Solstice GXP
Trifecta Tuned
K04R Turbo upgrade
post #10 of 11 (permalink) Old 03-17-2017, 05:50 PM
Did you miss the part where we all said cloyes or AC delco?
Good luck with the dorman
post #11 of 11 (permalink) Old 03-18-2017, 01:46 PM Thread Starter
ExtraSour's Avatar
It was honestly a time crunch, I couldnt have my car down forever so i had to go with what was available, otherwise i would have ordered one of the other brands.
2007 Solstice GXP
Trifecta Tuned
K04R Turbo upgrade
