Looking for a coupe now? - Page 10 - Pontiac Solstice Forum
Go Back   Pontiac Solstice Forum > General Solstice Discussion > Solstice Coupe Discussion
Old 02-22-2013, 09:40 AM   #136 (permalink)
King-Oka's Avatar
As has been said by others, crank the seat up using the height adjustment and that should solve the visibility issues.
I have two convertibles and have spent time in a coupe. With the top up in the convertibles and any time in the coupe, they feel very small inside. Mostly it’s the encroachment of the top that makes the car feel cramped to me. Even with the top off the coupe it takes a long time in the car to get away from the feeling that you are inside a small car.
With the top down on the convertible, the car opens up and feels wonderful. This is my first convertible and I love it. It changes my whole day when I can put the top down and enjoy the wide open view of the world around you. It’s as close as you are going to get to the feeling of total freedom when riding a motorcycle.
There are a number of things to look for that have been identified over the years. I am reposting them here for your ease of use. Feel free to ask any questions.
Get a GM record pulled to verify the in service date and warranty remaining. If the PT warranty is still good and the inspection gives it a clean bill of health, then the one at the dealer is a good option. Get them to kick in another few hundred in discounts and some free oil changes.
Another reason you want to start with the local car is because the Sky and Sol are highly susceptible to damage when lifted improperly. The front fenders crack frequently due to road vibration and are easily crushed if lifted with a floor jack. If there is damage you want to identify it before sale and with a dealer you can push to get them to repair the damage as part of the sale. There are basically no available right side factory fenders anymore and few left side fenders. They are repairable and there are aftermarket replacements available from DDM but you need to know if the fenders are cracked as this can be up to a $1k swinger on the retail price.
You also want to take a good look at the bottom front. Because of the configuration of the car nearly every new owner rams them into curbs one to several times and they get damaged. At the very least there will be scrapes on the bottom of the bumper cover that you can use to get a lower price or commitment to repair from a dealer that you probably will not get from a private party seller.
You also want to take a hard look at the top. More than a few cars have had problems with the folding mechanism that has damaged the canvas where it folds over the windows and / or damage to the canvas when it rubs against an improperly adjusted side window. The top is also susceptible to damage from the hold down feet mounted on the trunk lid. The rubber feet come off, fail or even twist allowing direct contact between the mounting structure and the top canvas while the top is in the trunk. I have seen more than one car that has holes in the top due to this. The canvas is $1600 plus installation which at a dealer can run into several hundred dollars. And to the best of my knowledge while there are plenty of replacement canvas parts available, there are no more top assemblies in stock.
You want to visually inspect the cup holders. The front one is notorious for failing and they cost upwards of $100 for replacement parts plus installation labor. The rear one between the seats is much more robust however they can and do get so full of dust and dirt that they will no longer deploy. If treated well they are fine but you do not know till you try to pull the things out.
Another area that I recommend you inspect is the center console. If the previous drivers did like me and leaned on them hard while driving and used them as a support while getting in and out of the car, they all will crack right down the center. I have had mine replaced under the warranty but you are probably out of warranty. The cover is easy to replace but again is in the range of $100 for a replacement part from GM. There are several threads that cover reinforcing below the cover so it will not crack again and DDM has a replacement that is much stonger and includes two cup holders but again that is in the same cost plus shipping and you get to install it.
If you are by chance looking at a 2008 RL, one factor is the production run for the first 6 or 8 months deleted the electronic vacuum pump that provided motive force for the brakes immediately after start up. The issue presents itself on some cars as high brake pedal force required and / or pulsing of the brake pedal for the first few seconds to the first couple of minutes upon cold start after sitting for an extended period or at high altitude. The issue is that the turbo car does not generate much vacuum (its boosted) and as a result once the vacume accumulator leaks down, there is no vacuum for the power brakes when you start. And when you start the factory tune, it is set to heat up the catalytic converter and not optimized for creating vacuum. There was a big safety investigation made and a lot of people had problems with this about mid-way through 2008 calendar year. My wife's car falls in this group and about once or twice a year we get the symptoms but it works fine through it and within about 30 seconds there is normal brake feel. The factory has a software update that if asked they will install on cars with this complaint and in extreme cases there is a retro fit kit that adds back on the electronic vacuum pump. But again, you cannot tell if the car you are looking at falls into this group or not unless you physically check for the pumps presence on the left side of the engine block, and unless you drive the car from a cold start. If you are buying from a dealer you could make the software update part of the deal and get a promise to do the pump retro fit under warranty because GM normally pays for it.
You want to cycle the driver’s seat up and down because a lot of cars have never had their electric adjusters cycled and they need to be freed up and lubricated before they work correctly. In fact, I did a test last year and out of 40 cars and 80 drivers only 5 knew that the driver’s seat went up and down with the switch! Servicing the seat is no big deal but it will be half an hour of labor and some parts allowance so its in the $100 range. If you buy from a dealer you are much more likely to have this addressed as part of the deal than if you buy from a private party. And if you do not have access to the car its difficult to verify operation.
Many, maybe most of the key fobs for 2006 through 2008 at least have a known manufacturing problem. The metal tab / connector that holds the battery in place has a cold solder joint. The fob starts to work intermittently and eventually stops working. If you are good with a solder iron you can easily fix it as many of us have done, but if not, then the dealer will charge you around $100 for a replacement fob and programming it with the car. Potentially times two. If you have access to the fobs, you can pop them open and inspect the condition of the at risk part and know if you are good to go or not. If not, again you are much more likely to get the fob replaced as part of the deal by a dealer.
The door sills have an aluminum insert that is glued to the plastic part. Unfortunately as a result of the attachment method and the difference in coefficient of thermal expansion between the aluminum trim insert and the plastic door sills, the aluminum part will almost always bow up around .25 inches in the middle during cold weather. In some instances drivers will drag their heels across the door sills and can catch the trim plate and bend the crap out of it. They are relatively cheap - around $25 plus labor to install, but if you find it after the fact then it’s your $25 and not the sellers.
Is that all you got ? IS THAT ALL YOU GOT??????
Old 02-22-2013, 04:37 PM   #137 (permalink)
Ruby NA 9K miles on Ebay. !7.9K or offer. Tempted to replace my deceased Deep coupe
Pontiac : Solstice 2dr Cpe in Pontiac | eBay Motors
Regards,
Jim
2009 Coupe #135 Base, Deep(deceased)
2002 Thunderbird, T-bird Blue
1986 Bertone X1/9 - Black
1977 Triumph Bonneville Jubilee
1982 Triumph Royal
1974 Triumph Trident
jsantoro is offline   Reply With Quote
Old 02-26-2013, 04:57 AM   #138 (permalink)
ChopTop's Avatar
Listed as vert but pictures show coupe.
2009 Pontiac Solstice You'll Love Gas Consumption Almost New
Same vehicle ($24,500)
BuyN.com - cars - 2009 2009 Pontiac Solstice GXP
ChopTop (formerly LowLife & LowLife1/Original join date 11/05)
Index of owner mods (Post 54)
http://www.solsticeforum.com/forum/f...45/index4.html
ChopTop is offline   Reply With Quote
Old 02-26-2013, 09:31 AM   #139 (permalink)
mahermusic's Avatar
Originally Posted by Shadofax View Post
Here you go, 2010 coupe(s) on ebay, check that price (love the merlot, but that's way too much $$):
Edit: just as an FYI, that merlot manual trans vin shows up as the VERY LAST Solstice coupe ever produced.....would love to have that.
Actually, this 2010 coupe was built in the middle of the year... intermingled within the 2009's... WELL before the last Solstices left the line.
There's another post somewhere here in regards to the last coupe (which, I believe was the 2nd-to-last vehicle off the assembly line in Wilmington... #1152, and was a 2009 MY), and the last vehicle of all... a 2009 convert. (Was it grey or silver? I don't remember... if someone remembers that post, can you provide a link to it?)
'09 "Mean" Yellow Pontiac Solstice GXP Coupe #634
mahermusic is offline   Reply With Quote
Old 02-26-2013, 10:08 AM   #140 (permalink)
wspohn's Avatar
Yeah, I'm sure people will be making that mistake (no doubt intentionally if they are the one selling the car) until the end of time. These cars aren't all that special - it was simply a case of taking some 2009 sample cars and trying out some ideas they had for the next model year, assuming that there was going to be a next model year - new colours etc.
And you can't even go for the last serial number necessarily being the last coupe - take a quick look at the factory records. The last serial number is listed as leaving the factory on Aug. 7, 2009. That wasn't the last car by any means to leave the factory (there were a ton of others noted as leaving that day, a small clutch left on Aug. 20 - 949, 978 etc., but others were as late as Sept 9 - #1131, 1087, etc, )
Face it, they aren't unique if the just happened to roll out of the doors last, but that doesn't stop people from paying more for the 'Last One'. The numerologists will opt for the last/highest serial numbers, the simple minded will go for the 2010 'because they HAVE to be last, right (even though they weren't, but they are dazzled by that year number and don't look any further) and the discerning collector may find out what the actual serial number of the very last coupe to roll through the doors was.
Anyone know what the last one out the door was?
And then of course you have to go through the same process for the last Sky, Solstice convert and Daewoo (well, that last one might not have as much interest to collectors) to roll out of the factory.
1958 MGA Twin Cam (race car)
1965 Jensen CV8
1969 MGC roadster
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
Old 02-26-2013, 11:01 AM   #141 (permalink)
mahermusic's Avatar
I'm pretty sure the last coupe off the ASSEMBLY LINE was #1152... but, as you said, there are a myriad of reasons why it wouldn't be the last one to leave the factory/lot/etc.
I'll have more time in a bit... I'll try and dig up the post that talks about the final Solstices coming off the assembly line. There were photos of the line in that post as well...
Old 02-26-2013, 11:10 AM   #142 (permalink)
that's the one I drove a couple weekends ago.
Originally Posted by ChopTop View Post
This is the one I drove a couple weeks ago. They dropped the price again.
Cypress is offline   Reply With Quote
Old 02-26-2013, 02:58 PM   #143 (permalink)
mahermusic's Avatar
OK, here's what I've found:
(Danger of taking 30-45 minutes away from your other chores by reading through the following links.... you've been warned!)
Here's the official "goodbye" thread from the Wilmington, DE plant closing, the day the last Kappas came off the line, July 27, 2009.
Look for:
Post #2 for the final Kappa ever off the assembly line ('09 silver Roadster)
Post #3 for the VIN of the last Kappa 1G2MN35B69Y108138
Post #25 for GREAT pix of coupes on the assembly line
MECCA - The Goodbye - The Pictures
Also, take a look here for more excellent pix:
Picasa Web Albums - grrllthmpsn - Boxwood Plant...
Could this be my coupe?
Never saw a yellow coupe with BLUE STRIPES before! (I wonder which one of the 37 "mean" coupes made is this?):
Lastly,
I submit for your approval that the following are the last three Kappas in line. We know third from the end was a Wicked Coupe, and that Coupe #1151 was a Wicked:
(BTW - these last pix were all taken second within each other on the assembly line)
This next pic shows the photographer standing next to the last Solstice, the silver convertible mentioned above. If you look in front of it, you can see the very last coupe that came off the assembly line, an Aggressive (red) Coupe:
I believe this to be Coupe #1152 - which was Aggressive.
Great stuff!!!
Old 02-27-2013, 05:09 AM   #144 (permalink)
ChopTop's Avatar
WS, you can count me as simply minded (even if the 10s were produced before the last of the 09s) due to the VIN technically identifying the 12 produced as 2010s.
Thanks for keeping this thread going folks, after all the primary point is to help those interested in acquiring a coupe if they want one.
Barrett-Jackson 2011: First and last 2010 Pontiac Solstice on the block *UPDATE: W/Video
Old 02-27-2013, 07:19 AM   #145 (permalink)
wspohn's Avatar
(Great stuff!!!
Indeed, great research!
1965 Jensen CV8
1969 MGC roadster
Bill in BC
Old 02-27-2013, 07:11 PM   #146 (permalink)
The way production works is next year cars begin test building while current year cars are in production. They test the procedures that way. The 2010 cars that were built as test units.
rob the elder is online now   Reply With Quote
Old 02-28-2013, 05:03 AM   #147 (permalink)
ChopTop's Avatar
BLK, Auto, 2.4, $22,900, Reno, TX.
2009 PONTIAC SOLSTICE COUPE
Note: some posting may (or include) be duplicates.
Old 03-08-2013, 08:39 AM   #148 (permalink)
ChopTop's Avatar
cross-posting
2.4/5spd/Grey
2009 Pontiac Solstice Coupe
Old 03-08-2013, 08:51 AM   #149 (permalink)
Originally Posted by Investo-Coupe View Post
Rob, PLEASE try and be a tad more detailed next time. Your short posts help no one.
LOL
I will try to do better next time . ..
Actually I have answered some questions so many times that I just save off the text and paste it into the thread where appropriate.
But you knew that!
Old 03-13-2013, 03:41 AM   #150 (permalink)
sirwm's Avatar
found this listing on Craig's List
2009 Pontiac solstice GXP Turbo Coupe
wr
Mean 2007 N/A 2.4
2007 Solstice ordered on 8/24/06 - Picked up on 12/12/06 - Totaled on 6/12/10
Looking for another Solstice 6/13/10...
Mean 2008 GXP
Acquired 6/21/10 with 1275 miles on it - Summer Solstice !
sirwm is offline   Reply With Quote
