I'm coming up on my 100k mile service and I expect a lot of other daily drivers are too. I want to recap some of the research I've been doing and get some confirmation that I'm moving in the correct direction.
This is all for an '07 GXP.
So what is called for in the 100k mile service?
Flush and fill manual transmission fluid
Based on my research, the premium synthetic brands (Redline, Mobile1, Royal Purple) work better in our tranny than the OEM stuff. It takes 3 qts of 75w90 gear oil and I plan to bring Mobile1 Synthetic 75W-90 Gear Oil with me to the dealer and have them use it instead of the OEM oil.
Based on this thread: http://www.solsticeforum.com/forum/f12/changing-transmission-fluid-think-twice-45071/
Anyone have a problem with Mobil1 in a manual transmission application? Remember, not talking about engine oil.
Flush and fill rear differential
This one is a little tough. It takes the same 75w90 oil as the transmission but requires a slip-enhancing LSD additive. It takes 1.25 qts of 75w90 gear oil and I plan to purchase the LSD additive from a local GM part supplier and bring the Mobile1 Synthetic 75W-90 Gear Oil to the dealer and have them use it.
I've heard that some Redline products already have the additive in there. I can't tell from browsing online which 75w90 gear oil might have the additive. Any insights here? Would that be any better than using Mobil1 with the additive?
Change air filter
Easiest possible DIY. Already have a K&N in there, like pretty much everyone else, I guess.
Cleaning throttle body, fuel injectors, cylinder heads
The dealership is charging me close to $400 for this service, mostly because they can't simply run a fuel additive through it, but have to disassemble some pieces of it. They are using BG products for the cleaning.
I voiced my skepticism that this service was actually needed, but the service guy was very knowledgeable about the Solstice and said that from '07 on, the Solstice does not have a fuel filter! I couldn't believe it, but I checked the forums and sure enough: http://www.solsticeforum.com/forum/f12/fuel-filter-where-45043/
So he explained that cleaning this assembly is important because some sediment and micro-debris will dirty things up a bit. I'm inclined to agree and have them do the full cleaning. Thoughts?
Change spark plugs
Yep, doing this.
Change engine oil
Doesn't need it. Gotta love the long life of Mobil1 synthetic!
Check brake and steering fluid, replacing if necessary
Of course, will let them check this as well.
What are you guys thoughts? I'm especially interested in making sure I get it right as far as the tranny/diff fluids and confirming that the fuel system cleaning is a good investment. Thanks!
- Flush and fill manual transmission fluid
- Flush and fill rear differential fluid
- Change air filter
- Cleaning throttle body, fuel injectors, cylinder heads
- Change spark plugs
- Change engine oil
- Check brake and steering fluid, replacing if necessary
Change air filter
Change spark plugs
Yep, doing this.
Change engine oil
