Old 11-05-2009, 09:00 AM   #1 (permalink)
Falcon Wing's Avatar
Anyone removed REAR inner wheel well / fender liners? Couple questions....
If you have removed them, what all did it take?
Can you still keep your splash guards if you do?
Thanks!
Falcon Wing is online now   Reply With Quote
Old 11-05-2009, 10:08 AM   #2 (permalink)
Small Dealer's Avatar
Looks simple based on the service manual. Splash Guards may share mounting retainers, or have used other mounting methods to replace the retainers. Hope you can figure it out by looking at it.
1.) Remove the rear wheel.
2.) Rear Wheelhouse Liner Retainers #1 (Qty: 13)
3.) Rear Wheelhouse Liner Bolts #2 (Qty: 2) When reinstalling: Tighten to
10 N·m (89 lb in)
4.) Rear Wheelhouse Liner
INFORMATION POSTED ON SITE
Old 11-05-2009, 11:55 AM   #3 (permalink)
You mean you don't take them out when you detail the car?
Tread Head (DAT)
"They call 'em crunchies because that is the noise they make when you run over 'em"
Qualified in M-48A5, M-60A1
Electrical Engineer
Suramar DK Oberstkurtz, DPS Colonelkurtz, DPS Majorkurtz
NASSOA and GMR member
Old 11-05-2009, 12:33 PM   #4 (permalink)
Thanks Small Dealer!
