Axle Clunk/Chatter Noise on Turns - Pontiac Solstice Forum
Old 04-03-2010, 08:45 AM   #1 (permalink)
Small Dealer's Avatar
Here is some updated information out this week for owners to think about with the good weather returning for Spring maintenance.
Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid)
Models: 2003-2010 Cadillac CTS (Including V-Series and Export)
2004-2009 Cadillac SRX (Including Export)
2005-2010 Cadillac STS (Including V-Series and Export)
2006-2008 Pontiac Solstice
2007-2008 Saturn SKY
Condition
Some customers may comment on a clunk and/or chatter type noise from the rear of the vehicle while making turns.
This condition may be worse on vehicles built prior to the 2008 model year. Carbon-faced clutch plates were introduced into production in the 2008 model year and have decreased the likelihood of the clutch plate chatter.
Cause
This condition may be caused by slip/stick of the posi-traction clutch plates due to insufficient limited-slip axle additive. As plates slip and stick, a jumping or jerking feel occurs accompanied by a clunk noise.
Correction
Important: DO NOT remove the differential cover. It is not necessary to flush the old fluid from the differential.
Drain and refill the rear differential with new fluid, GM P/N 88862624. Refer to the Axle Lubricant Change procedure in SI.
This new fluid includes a friction modifier already added with a different formulation that last longer and does not break down overtime.
Lubrication Specifications Quantity
Without Differential Oil Cooler
1.10 L / 1.16 qt
With Differential Oil Cooler
1.41 L / 1.50 qt
Parts Information
88862624 (US -1 qt)
88862625 (Canada - 1 L)
DEXRON® LS Gear Oil
INFORMATION POSTED ON SITE
Old 04-03-2010, 05:58 PM   #2 (permalink)
WintR's Avatar
Thanks, SD. Good to know. I'm keeping a copy in my Solstice data, just in case.
Mods: Kappasphere CAI, Clear Image Shorty Header, second horn, visor decals, mudflaps, tonneau cover, brake light flasher, trailer hitch, 'lil Chromies, trunk monkey, retune, DDMWorks backbone, GMPP Suspension, wood grain dash, Solo Quiet cat-back exhaust, deleted:Solo high-flow cat
WintR is offline   Reply With Quote
Old 04-15-2010, 07:16 PM   #3 (permalink)
thanks Small Dealer
I have been changing the diff fluid every 20,000 km to keep the
groaning to a minimum
changed to the new fluid and the groan totally disappeared
lightning rod is offline   Reply With Quote
Old 04-15-2010, 09:30 PM   #4 (permalink)
shreve1's Avatar
I just had my diff replaced last week. They rebuilt it last year due to clutch pack ware. Then the past month it was whinning like mad. Took it in and they removed my diff. Once they broke it down they found the pinion and ring was shot. So they decided to replace it with a complete new diff. Now it smooth and quiet.
8" kicker sub with Pioneer Amp + Components
Saturn Sky Door panel Swap
DC Sports strut bar
Drilled and Slotted Rotors
Werks cooler
Werks HI Flow cat
Trifeca Tune
Sprint Booster Adjustable
DDMWorks Trunk & Hood Led Lights
DDMWorks Coated Valve Cover
DDMWorks Oil Catch Can
DDMWorks Coil Cover
DDMWorks Tubes
DDMWorks Inline fuel
K&N C.A.I.
Custom backup camera install
Kazera KZ-D Wheels
Nexen 3000 tires
Spoiler from The spoiler company
shreve1 is offline   Reply With Quote
Old 04-17-2010, 08:27 AM   #5 (permalink)
Originally Posted by lightning rod
I have been changing the diff fluid every 20,000 km to keep the groaning to a minimum, changed to the new fluid and the groan totally disappeared.
Thanks for the input.
Old 04-17-2010, 08:57 AM   #6 (permalink)
Originally Posted by lightning rod View Post
thanks Small Dealer
My clutch packs were replaced under warranty and I haven't had any problems since. Is replacing the fluid every 20,000 km (12,400 miles) necessary?
GaryH is offline   Reply With Quote
Old 04-17-2010, 11:28 AM   #7 (permalink)
Gary ;
probably not. I took the car to the dealer and they said some groaning was normal. The groaning wasn't always there, just on the really hot days.
The dealer just wanted to change the fluid.
Changing the fluid (original part number) regularly seemed to help.
There was very little clutch material on the magnet of the drain plug.
My brother-in law (mechanic - shop teacher now) suggested to change to a
different fluid since that helps sometimes.
Well I guess GM figured out a better fluid.
The new fluid is like magic. Not even a hint of groan.
I never got this when changing the old part number fluid.
I'll let you guys know in 10,000 km if the new fluid is holding up.
Ross
Old 04-17-2010, 02:49 PM   #8 (permalink)
jimbo's Avatar
Thanks. You are an indispensable resource.
2008 Solstice GXP Roadster
I've been humped
Kappasphere AX wheels
DDMWorks extreme backbone
GMPP Stage 2
Splash Guards
Black bezel headlamps
23,777 fun miles
You don't need a trunk to haul ass...
Official car of SCCA Touring 2 Champion Don Knowles.
jimbo is offline   Reply With Quote
Old 05-11-2010, 06:59 AM   #9 (permalink)
69telecaster's Avatar
I've been doing a bunch of reading on this site about the rear end and the lubricant(s). Mine doesn't chatter on low-speed turns, but it whines at speeds over 55. PO had the diff. changed, under warranty, some time ago.
I'm thinking I want to change the fluid, but now there's questions about the fluid. I asked the dealer parts desk about #88862624, and was told they'd have to special order it...very rare, possibly old number. He showed me bottles of the lube they use: a GM and a Mobil1 product. Both said "synthetic" and "LS". I looked at the display at a local parts store, and saw Royal Purple and Valvoline bottles with similar designations.
I assume the #89021677, #12378261, and additive #01052358, mentioned in another thread (Feb. & Jun. '08), are the "old" fluids.
I guess I want to know what is currently recommended by GM, and are Mobil1, Royal Purple, and Valvoline acceptable substitutes. Also, what is the recommended change interval?
Thanx.
cm
69telecaster is offline   Reply With Quote
Old 05-11-2010, 11:22 AM   #10 (permalink)
NormSky's Avatar
69, I don't GM recommends any other differential fluid. There fluids which meet or exceed their requirements. Personally run Royal Purple(with LSD modifier all ready in it) 85-140 in my 2005 CTS-V and only have a. Slight whimpering. I run RP 75w90 in the Sky.
Norm
07 Sky Hahn Boosted- 44 mpg - 40 mpg with air conditioning on.
NormSky is offline   Reply With Quote
Old 05-11-2010, 01:42 PM   #11 (permalink)
jeffgtx's Avatar
Is the above procedure as documented by Gm a warranty service or do you have to pay?
I started getting the clunk. Thought the fire extinguisher was loose in the trunk. Took it out. Thought the exhaust was loose.
Glad to stumble on this.
Jeffgtx's Shades Of Gray Pontiac Armada
jeffgtx is offline   Reply With Quote
Old 05-12-2010, 06:57 AM   #12 (permalink)
Norm
Thanks, Norm.
I know others who swear by Royal Purple products, so I'll give it a try.
How often do you change yours?
Old 05-12-2010, 08:03 AM   #13 (permalink)
NormSky's Avatar
Use whatever and just follow manufacturer maintence schedule. Unless you use your car for track duty. The drain plug is magnetic and will fill up with metal particles as it's a heavier car using the same diff. I'd personally change it, it can be a messy job, inspect the drain plug for metal particle/sludge. If you have 1/4" or more of build up on the drain plug, change it again in 10-15,000 miles. While your under there might as well change the transmission fluid as well if it's a manual. Might even see a bump in mpg.
Norm
Old 05-13-2010, 05:37 AM   #14 (permalink)
My owners manual maintenance schedule doesn't say anything about the rear end or manual trans. fluids, out to 150,000 mi. Of course, it says that if anything goes wrong to take it to the dealer...heh, heh.
