I wasn't sure where to post this so I just picked General Tech...
Does anyone know where I can get a good and CHEAP set of sports car ramps? I'm also looking at cheaper lifts or display stands but most likely will be wanting ramps. I'm specifically looking for the sports car style that are longer so they will fit under the bumper of the car easily.
Delivered on May 27, 2008
Mods: lose the chicklets, VentureShield, Dual horns, AfterShock spoiler, Weathershield cover, Lil Chromies, Red calipers with black Solstice stickers, Opel GT antenna and Solo GXP-RCD exhaust with Solo hi-flow cat!
Rhinos work great for the little car. I have used mine on everything from an F-250 to the Solstice. I think I bought mine at Walmart many years ago.
If your garage floor is slick (like mine) an old set of rubber backed floor mats will come in handy to keep the ramps from sliding out when you try to drive up on them.
I put mine under the front of the ramp, with the mat sticking out so the tire drives up on the mat first.
2007 Cool GXP, 5spd, all the bell & whistles except Skynet, I mean OnStar
PCM For Less Tune
DDM Backbone
SOLO GXP Mach
SOLD - 06/05/2010
For a cheap solution I used 2 x 10 planks stacked on top of each other and screwed together. The first one is 6 feet long, then 5', then 4', 3' and 2' with one end cut at a 45 degree angle for driving up on. On the end of the top plank I screwed in a piece of 2 x 4 perpendicular to the ramp to prevent driving off the end. I then took a 2' x 3' rubber welcome mat and cut it into 4 equal pieces and attached them to the front and rear of the bottom of each ramp. Works good, won't collapse or shoot across the floor and only cost me $40 for the pair for materials and you get a good workout hefting them around...they weigh about 40 lbs each...but like I said, it's a cheap, solid solution.
1 December 2012: O'Rielly has both the 8000 and 12000 lb Rhinos on sale right now for 39.00 I went with the 12's because they were out of the 8's. The car went right up, no problems, no scraping.
