Old 07-03-2009, 07:44 PM   #1 (permalink)
Send a message via AIM to Swendor
Cracked Manifold
I discovered this today after hearing my engine get progressively louder. Is there anyway to repair this or do I have to get it replaced? 2006 Aggressive, 76K mi.
#1077 Aggressive w/all except XM Onstar Leather
Swendor is offline   Reply With Quote
Old 07-03-2009, 08:12 PM   #2 (permalink)
kwtoxman's Avatar
Ouch! That is not normal at all.
If so a welder can probably do a quick fix and you can see how it holds. Not good GM quality.
GM Stage II turbo upgrade
kwtoxman is online now   Reply With Quote
Old 07-03-2009, 08:34 PM   #3 (permalink)
Hoosier GXP's Avatar
Those manifold are made from cast iron and I will venture to say you will have little luck fixing it. Might be a good time to look into a header since you are going to have to replace it. Not sure of your location but a search on Car-Part.com--Used Auto Parts Market will produce some hits for it around $50
Hoosier GXP is online now   Reply With Quote
Old 07-03-2009, 08:47 PM   #4 (permalink)
zzzybil's Avatar
gotta be replaced- - a welder might tell yuh different ? i just don't see a patch holding...
between labor and PIA factor - the odds on a repeat performance
looks like an excuse to upgrade - and be done
you win today's contest ----> " things that make yuh say " ((( ))) dam
76k miles - no mods ???.
BOOsted 2.4
42lb injectors
3" tubes front to back
10 boost
38mm tial wastegate / bov
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
HPTUNING - the hard part !!!
(tune therapy -> randy @DDM)
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
custom .08ss heatshield
YEAH I DID THAT !
Old 07-03-2009, 08:53 PM   #5 (permalink)
Thanks guys. I've seen some PERMATEX® Hi Temp. Metal Repair Compound which is specified for manifolds and supposed to be good for 2000 degrees. Could I use this as a temporary fix until I get a replacement? Are there any adverse effects that could come from letting it go too long besides the noise?
Old 07-03-2009, 09:33 PM   #6 (permalink)
druid-2's Avatar
Location: buzzard..what buzzard..do you see a buzzard..I didn't see a buzzard...or that little sparrow either- or dat squirrel
I have a stock (2.4 N/A) manifold exhaust in my garage (I went SOLO)
I'm sure we could work out a deal that wouldn't cost you too much
if interested
send me a PM
NEOKappa.com
WINTER TRAINING SCHEDULE 2009-10
2010NASSM.COM
Some people grow old before their time...I choose to die before I grow old !
Druid (Cool) MERLIN came home 11-15-05 VIN 4495
Clear bra, Stubby antenna, Kappshield, mudguards, Chrome wheels with GS-2's...CAI..SOLO SQR-2 exhaust with free flow CAT & SS header ..painted calipers and wheel centre decals. 25% tint windshield ... Vertical Chrome billet grille .. stay tuned
druid-2 is offline   Reply With Quote
Old 07-03-2009, 09:44 PM   #7 (permalink)
Small Dealer's Avatar
Sure that would be one way to jump.
Or you could wonder what outside vendor supplies the exhaust manifold to GM, or is it produced in house?
Or you could have inquired if in the almost three years they have been off the site, has the car ever been tapped in the rear? Hitting something with the front, as they have done, wouldn't do anything, but getting the exhaust system pushed forward in a rear end tap could cause something like this.
Or you could have inquired if they had any exhaust repairs performed on the car? Small possability that having something like the Cat Converter replaced could be a factor.
INFORMATION POSTED ON SITE
Old 07-03-2009, 10:04 PM   #8 (permalink)
kwtoxman's Avatar
Frankly, what I was pointing out was that thing wasn't normal GM quality for that part. IE something is not normal. SD has pointed out some possible sources. It's a start.
Old 07-03-2009, 10:32 PM   #9 (permalink)
Yeah, I said damn. I took off the heat shield expecting to tighten the bolts from the info I got from researching the forums. Then I saw the crack...
No mods, happy with it as is. But I must admit after researching this problem it's more of a possibility.
Old 07-03-2009, 10:34 PM   #10 (permalink)
No mods, no rear end taps
Old 07-03-2009, 10:35 PM   #11 (permalink)
zzzybil's Avatar
sounds like a good idea- temporary anyways - just be careful it doesn't drip/run/spill into and foul up that sensor - my neighbor swears by jbweld......... can't say i've ever had luck with it
the close proximity of the hole to the sensor would have me nervous about gooping it up - the sensor (inadvertently ) even the fumes while it cured -might be caustic - don't know what the goop is made of
i'd take the sensor out to be safe - during the repair- eliminate that risk of gettin goop on it
the hole is soooooo close to your sensor -
to guess the reading might be a lil skewed maybe maybe not ( causing it to message the ecm to call for inacurate richer or leaner fuel trims ) i always guess backasswards - so i won't guess...... but there's a hole next to a sensor sooooooooo murphy's law states -
final answer i think thats a stretch -
its just going to make noise - and blow any patch - rite back atcha
- maybe you can tell - maybe not - besides for the noise any change ? if its effecting performance
if you don't upgrade - i forgot about all the oem that are prolly gathering dust !...rite here on the forum......
druid ready wit the hookup !!- gotta love this forum
BOOsted 2.4
42lb injectors
10 boost
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
YEAH I DID THAT !
Old 07-03-2009, 11:08 PM   #12 (permalink)
zzzybil's Avatar
that woulda been a hellava tap !
tap- nope
exhaust repairs - nope
even if gm has an outside vendor supplying the exhaust manifold ( do they ? ).......
thats small consolation - and zero relief .......still reflects on the gm product......imo
yep blaming it on a cat ?? is pretty remote - we did just get a letter . is there another on manifolds comming ?
on "bad cats" - does that make him eligible for a new manifold if he can find an issue with his cat too........ lol...blame it on that.. now we gettin someplace !
humming the "alcohol song " blame it on the ca cacaca cat
just messin witcha SD........ never heard you sound like a (((( dealer )))...before
how bout a hi tech answer on if the hole next to the sensor can contribute to any other issues
BOOsted 2.4
42lb injectors
10 boost
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
YEAH I DID THAT !
Old 07-04-2009, 10:59 AM   #13 (permalink)
You know, my cat did go bad back at 50K. It was replaced under warranty at a local dealership which has since closed. I wonder if that has anything to do with it. But what recourse do I have since the dealership is no longer there?
Old 07-04-2009, 12:08 PM   #14 (permalink)
jwvess00's Avatar
Hi there!
Welding cast iron isn't the easiest thing to do. There are places that could fix it, though it won't be cheap. The offer for a used one seems like a great way to go to me, if a header isn't in your plans.
I've used some epoxy patches on manifolds before, and they work okay but they're not a permanent fix.
Jay Vessels
jwvess00 is offline   Reply With Quote
Old 07-04-2009, 09:39 PM   #15 (permalink)
Didn't "blame" the cat, was just placing an exhuast repair in play for some to think about. That and when you know the cat has been replaced at 48K on this car, and it is bolted to the manifold, it is an easier jump.
I did know.
Give it a shot. Nothing to loose. You need a new manifold anyways.
Would start with Pontiac Customer Assistance. Give it the "strange thing has happened..... Warranty work was performed in that area...... Think the failure may be related.......". See if you can lead them to helping out and recommending another local dealership. When you get to the dealership keep them on the track that Customer Assistance put you there and it may be releated to the other dealership.
