Old 07-04-2009, 09:48 PM   #16 (permalink)
Envious06's Avatar
Wow!!! Thats what turbo heat does to manifolds, although I think yours was a quality defect. Anyway, I'm a welder and there is no way the greatest welder could put a lasting repair on that. Nor is JB Weld or any other miracle juice other than a new manifold gonna set you straight. I'd be all over the dealer on that one. Good luck..
Envious06 is offline   Reply With Quote
Old 07-04-2009, 09:56 PM   #17 (permalink)
Small Dealer's Avatar
Think the idea will be to stay away from the defect tag. Since that would make it a warranty item. WHich would make it no longer covered by the expired 36 month or 36,000 mile warranty.
The idea is to tie it into the cat replacement and hope to get coverage consideration from GM/Pontiac.
As a 2006 it is not a turbo.
INFORMATION POSTED ON SITE
Old 07-04-2009, 10:10 PM   #18 (permalink)
Envious06's Avatar
My bad...I looked at the pic and thought that was a turbo behind it. After all, it is the 4th and all. I'm bored but home and not of sound mind...
Old 07-10-2009, 02:12 PM   #19 (permalink)
Send a message via AIM to Swendor
So I called Pontiac's 800# and he said the manifold MAY be under warranty. They have to first determine if the crack is a defect or the result of the catalytic repair causing. I called the local dealership and was told to bring it in on next Thursday because that's when their regional boss or somebody important will be there. Here's hoping. I'll keep you posted...
#1077 Aggressive w/all except XM Onstar Leather
Swendor is offline   Reply With Quote
Old 07-10-2009, 02:52 PM   #20 (permalink)
SOLSTICE-D's Avatar
I Had the same problem with my cat at about 30K then the headers at 60K or so. Just went SOLO and not going back!!!! We'll untill i have to get a SMOG CHECK! LOL!
2006*COOL*SOLSTICE
POWDER COATED RIMS
C.F INTERIOR
DEBADGED
A.E.M: COLD AIR INTAKE
GXP PARTS: DUAL EXHAUST, FE3 SUSPENION
SOLO-PERFORMAANCE:HIGHFLOW CAT, SHORTY HEADER
KAPPASPHERE: REBAR
DDMWORKS: RACE BACK BONE
ASAP.DIGITAL.IMAGING: SLOTTED BACK UP LIGHTS,SIDEMARKERS,THRID BRAKE LIGHT,TURN SIGNAL/FOG LIGHT COVERS,TRANSFORMER OVERLAYS,TEAM SOLSTICE T-SHIRTS
Save the Kappa!
SOLSTICE-D is offline   Reply With Quote
Old 09-04-2009, 05:49 PM   #21 (permalink)
So here's the deal: Of course the dealership said the catalytic repair had nothing to do with the crack and therefore won't fix it. Maybe is just because I didn't have it fixed there and they don't want to take responsibility. So, I ended up putting the cold weld around the crack and its been holding up pretty well for about 1k miles. It's just temporary, it'll get fixed soon.
Old 09-04-2009, 05:59 PM   #22 (permalink)
pjsquire's Avatar
Send a message via AIM to pjsquire
Take up druid on the offer!
08 GXP Aggressive Auto – Acquired August 15th, 07
MKC - Michigan Kappa Club
pjsquire is offline   Reply With Quote
