Differential drain plug washer - Pontiac Solstice Forum
Old 01-28-2013, 03:31 PM   #1 (permalink)
Does anybody have a part number for the washer that seals the differential drain and fill plugs? The dealer has no number, only the number for the entire plug assy. Also, how much torque is applied to those plugs when installed? Thanks.
upswept is offline   Reply With Quote
Old 01-28-2013, 03:35 PM   #2 (permalink)
Try looking it up on parts.nalleygmc.com (you'll need to enter your car model info first, but then bookmark the resulting page for later reference).
For example, here's my bookmark: 2008 Pontiac Solstice TURBO 2 DR CONVERTIBLE Parts
Enter "differential" in the 'Keyword' search field, and browse the 'Matching Assemblies' section, brings up this: http://parts.nalleygmc.com/showAssem...g=differential. Maybe you can find your part there, though I dont see a separate washer.
Old 01-29-2013, 06:38 AM   #3 (permalink)
idkfa's Avatar
Hey, that's a great resource. Thanks!
2006 Deep: GT2871r LE5
Old 01-29-2013, 10:33 AM   #4 (permalink)
Yes, a good resource. But, washers are not available by themselves. I don't want the entire plugs, just the washers.
Old 01-29-2013, 12:20 PM   #5 (permalink)
So there's your answer then. But the plug's not that expensive and you're only doing it once every 5 years maybe, right?
You'll probably find it's a captured washer anyway. Otherwise, try taking the plug to a decent autoparts place and see if they have a copper washer to fit.
Old 01-29-2013, 12:39 PM   #6 (permalink)
I've changed the fluid in my diff a couple times and have never replaced any washer or plug. I've never had a problem with it.
I've also never changed a oil drain plug washer on any vehicle and have never had a problem with that either.
Im rocking a GTX because the EFR sucks
vroompsh is offline   Reply With Quote
Old 02-02-2013, 11:44 AM   #7 (permalink)
jwvess00's Avatar
Hi there!
I didn't replace the washers on my Solstice, and it was fine. Just watch for leaks.
I have had to replace oil drain plug gaskets. Either they just disintegrate over time (plastic/rubber), or someone previous to my ownership decided to see how tight they could install the drain plug and ruined it.
My Subaru has crush washers on the drain plugs (engine, transmission, and I think both differentials but I don't remember for sure). These are replaced at every change. They're about $1 from the Subaru dealer, and if you buy an oil filter there (which is just as cheap as the auto parts chain stores), they just trot one out at the same time.
Jay Vessels
jwvess00 is offline   Reply With Quote
