Door Glass Comes in Contact with Convertible Top
Subject: Door Glass Comes in Contact with Convertible Top (Adjust Number 4 Bow)
Models:
2006-2009 Pontiac Solstice
2007-2009 Saturn SKY
2007-2009 Opel GT
2007-2009 Daewoo G2X
Condition
Some customers may comment that the door glass is coming in contact with the webbing of the convertible top in the upper rear corners.
Cause
This condition may be caused by the number 4 bow being out of adjustment.
Correction
1. If the glass looks good to the opening with no windnoise or water leaks complaints, then proceed with the number 4 bow adjustment. If the door glass is out of alignment, align or adjust the glass.
2. Use a 10 mm open end wrench to loosen the jam nut. Move the upstop counterclockwise to tighten top cover. Each turn moves the upstop 1 mm (.039 in). There is a 4-to-1 ratio between the upstop and the top of the bow (one turn moves the #4 bow 4 mm (.16 in) at the top). Two turns of the upstop should be sufficient to tighten a loose top. Refer to the illustration above.
FAN MAIL: "Unfortunately, it’s attitudes like yours that give dealers a bad reputation."
INFORMATION POSTED ON SITE
