Got a call from my dealer today that GM has sent them an update that some AC systems may not have been charged properly causing them blow warm air every so often.
Mysterious, Ebony NA 2.4L, Monsoon, OnStar and his name is the BANDIT. Ordered 3/8/06, built 5/10, delivered 5/22/06, took home 5/30 Mods include 3M transparent Nose film, MagnaFlow Dual Exhaust and RK Rear Valence. DDM Stage 1 Supercharger installed May 23rd 2008. RK Ram Air Hood installed Nov 4,2008.
Best thing to do is have your dealership take a look at the charge level, then pull the system down, check for leaks and refill it, making sure it has 1.63lbs of refridgerant.
INFORMATION POSTED ON SITE
I called GM about 6 weeks ago and they finally called back. They say they don't know anything about it and that the "cycling" warm and cold is a "feature" of the AC system!!!
But if anything is discovered in the future, they will call.
I wonder if the noisy compressor is also a "feature" of the A/C system. I read somewhere (either on this forum or the Sky forum) that they are redesigning the compressors. I've been waiting for a replacement that has been on backorder for 2 months. Beginning to think that I won't see a new compressor until next summer...when I'll need it again.
Linda
2007 Sky - Silver Pearl
Black Leather/Black Lid
Automatic
LSD
Monsoon/Single CD
Painted Alloy Wheels
That's on my list when I take mine in for pre-winter service. My AC never worked at all this year but didn't need it so I deferred it until next service.
__________________ 2006 VIN #30, first 1000 series, black exterior, sand/steel interior
With my Pontiac Firehawk, Wide Open Throttle (WOT) turns off the A/C so more power is delivered to the wheels. Check and see if it comes on when you "floor it". If so, it's running correctly, as the engine assumes you want to kick *ss.
They checked for leaks and couldn't find any and then they evacuated the system and only recovered 1.25lbs of freon. They then refilled it with the required 1.63lbs of freon. Well, I was certain they had fixed my problem BUT when driving home I still think it was having the same problem but maybe not as frequent. I need to drive it some more to confirm. What I really want to do is hook up a light or voltmeter to the compressor clutch so I can see how often it is cycling off and on. I let you'll know what I find out.
Reason: attaching TSB
Why not just turn it on in the winter and call it a heater with a "feature" of occassionally blowing cold air.
#7981 (Arrived at dealer 11/30, pick up from dealer 12/7): Solstice GXP, manual, aggressive, darkside, ebony leather w/ red stitching, headliner, A/C, prefered package, premium package, and convenience package.
Just installed: 2-subwoofer full stereo system. Still waiting on pics.
Coming next: probably nothing unless my wife wants to get my a new exhaust (yeah right).
This car will shut down the A/C under a hard pull, doesn't have to be Wide open throttle.
NOT WAITING ANY MORE!
