For the data consolidation and collection regarding the high temp/overheating issue, Please copy and paste these below questions to a new post and answer as briefly as possible.
Also, Please answer these questions only to minimize the difficulty of weeding through non-pertinant information while trying to consolidate the data. If you have been watching your temp on the DIC and have not noticed this spike Please answer questions 1 and 2 only. N/A the rest. Please only post once unless the problem does occur after you have answered no and identify that it has changed.
Thank you. I will try to keep this updated as best and as often as I can until I feel the need has reached it's intent.
COPY FROM BELOW THIS LINE.........................
Q.1. 2.0 or 2.4 Liter model? = A.)
Q.2. Have you had the high temps issue? (over 230 or higher) = A.)
Q.3. Highest temp you saw on the DIC (normaly/during the occurance? = A.)
Q.4. Did it fully over heat or just go back to normal? = A.)
Q.5. Has the occurance happened more than once (# of times recall seeing)? = A.)
Q.6. Have you been successful with a dealership in getting it fixed? = A.)
Q.7. What did they replace? = A.)
Q.8. Has it happened since? (if Q.6 & Q.7 are NO, answer N/A) = A.)
COPY TO ABOVE THIS LINE.........................
CONSOLIDATION
Q.1. TOTAL 2.0L - 15
TOTAL 2.4L - 1
Q.2. TOTAL YES - 16
TOTAL NO - 25
TOTAL NOT SURE -
Q.3. HIGHEST TEMP OF ALL - 272
AVERAGE HIGH TEMP SEEN- 258
Q.4. # FULLY OVERHEATED - 3
# DID NOT OVERHEAT - 12
Q.5. MOST TIMES SEEN - 20 plus
Q.6. YES - FORUM ID -
kwayne
shabby
walsh.travis
MEGAS
pj-33
nasos
Ihanks
NO - NUMBER - 8
Q.7. MOST COMMON REPLACED ITEM - Thermostat
OTHER - Coolant Temp Sensor, head gasket
Q.8. RE-OCCURANCE AFTER REPLACEMENT ITEM?
TOTAL YES - 2
TOTAL NO - 4
Q.2. Have you had the high temps issue? (over 230 or higher) = 240+
Q.3. Highest temp you saw on the DIC (normaly/during the occurance? = 240+
Q.4. Did it fully over heat or just go back to normal? = ??? 240+ was the highest. Overheat would be over 260. I shut it down in the garage. The fan were going strong when I left it. The next day I could not duplicate the problem.
Q.5. Has the occurance happened more than once ? No
Q.6. Have you been successful with a dealership in getting it fixed? No, I drove there the next day and found they had closed the dealership (after 20 or 30 years of business!)
Q.1. 2.0 or 2.4 Liter model? = A.)2.0
Q.2. Have you had the high temps issue? (over 230 or higher) = A.)YES
Q.3. Highest temp you saw on the DIC (normaly/during the occurance? = A.)255
Q.4. Did it fully over heat or just go back to normal? = A.)FULLY OVERHEAT&BACK TO NORMAL
Q.5. Has the occurance happened more than once (# of times recall seeing)? = A.)YES abt 10TIMES
Q.6. Have you been successful with a dealership in getting it fixed? = A.)YES
Q.7. What did they replace? = A.)THERMOSTAT & ENGINE COOLANT TEMP SENSOR
Q.8. Has it happened since? (if Q.6 & Q.7 are NO, answer N/A) = A.)NO
Q.2. Have you had the high temps issue? (over 230 or higher) = A.) yes but never seen higher than 243.. yet
Q.3. Highest temp you saw on the DIC (normaly/during the occurance? = A.) 243
Q.4. Did it fully over heat or just go back to normal? = A.) no CEL, cooled back down after a few minutes... only happens when near freezing temp outside and during warmup.. once warmed up and t-stat starts working it doesnt overheat... suspect t-stat sticking maybe from dex-cool residue.
Q.5. Has the occurance happened more than once (# of times recall seeing)? = A.) a bunch... about 7-10 maybe more that I have not noticed.... noticed low coolant from boiling, coolant dripping out of reservor
Q.6. Have you been successful with a dealership in getting it fixed? = A.) no
Q.7. What did they replace? = A.) na
Q.8. Has it happened since? (if Q.6 & Q.7 are NO, answer N/A) = A.) na
Reason: same senerio as Shabby
Q.2. Have you had the high temps issue? (over 230 or higher) = YES
Q.3. Highest temp you saw on the DIC (normaly/during the occurance? = 251
Q.4. Did it fully over heat or just go back to normal? = Back to normal
Q.5. Has the occurance happened more than once (# of times recall seeing)? = 10
Q.6. Have you been successful with a dealership in getting it fixed? = YES
Q.7. What did they replace? = Thermostat
Q.8. Has it happened since? (if Q.6 & Q.7 are NO, answer N/A) = No - but if I have the heat on 100% or nearly, it runs a good 10-20 degrees hotter than if the heat is at 50% or less.
