Old 11-14-2005, 06:05 AM
   How to dim the airbag light
2KWK4U's Avatar
COTTON!
That's right, I used cotton to knock down the glare from the airbag indicator. Slysol has already posted a how-to for completely disabling the airbag light here. I didn't want mine to go away completely, though. I will have children in my car, so I will want to know the status of the passenger air bag from time to time. I just don't want it SHOUTING at me all day and night.
So while I was tearing into my dashboard last night I decided to look into how I could turn down the intensity a bit. It was easier than I thought it would be, once I put some thought into it.
I'm not sure if you can take the whole indicator assembly out without removing the IP trim piece. To be honest, I didn't check. If you want to try, be my guest. The bolts have 7mm heads on them. If you do have to remove the IP trim piece, be careful. It's not easy. I posted a little info on how to do that here.
Once you get the assembly out of the IP trim piece, the little printed cover pops off easily, it is just thin, soft plastic. I first experimented with coloring the backside with a sharpie, then ink, then acrylic paint. I couldn't get good-looking results with any of those methods. Then it occurred to me to stuff the little cavities that the LEDs are in with something translucent. I tried tearing two little pieces off of a cotton ball and shoving those in there. BINGO! Now the words "OFF" and "ON" are no brighter than the phrase "PASSENGER AIR BAG" when lit. The only thing I'm not sure of is if they will be visible during the day. I'll post again if there are any problems with this "mod."
how-dim-airbag-light-airbag_light3.jpg  how-dim-airbag-light-airbag_light2.jpg  how-dim-airbag-light-airbag_light.jpg
I've never met a Solstice I wouldn't autopsy.
'08 GXP #105359 - Bought and stored 10 months before I move back from Germany!
2KWK4U is offline
Old 11-14-2005, 06:09 AM
2KWK4U's Avatar
I considered giving the hi-beam indicator the same treatment, but I'm not sure I want to bother with pulling the needles off of the gauge cluster to get to it.
Apologies to gizmo2004, I forgot to look into making the low fuel light BRIGHTER!
2KWK4U is offline
Old 11-14-2005, 07:22 AM
Andrew Jackson's Avatar
I found a pair of Air Force Wings
Put one right over it .Stuck it on with 2 face tape
Looks like it belongs.
Andrew Jackson is offline
Old 11-14-2005, 11:31 AM
2KWK4U's Avatar
Well, there's a simple solution! My Air Force wings are going in the rear window. As soon as I can find a new-style logo sticker that I like.
2KWK4U is offline
Old 11-14-2005, 11:36 AM
stang's Avatar
What would it take to move the airbag indicator to below the stereo? Did it look like it could be done?
stang is offline
Old 11-14-2005, 12:30 PM
2KWK4U's Avatar
I finally answered ya in the other thread.
But since this thread is about the light, it bears repeating. It wouldn't be easy.
Originally Posted by 2KWK4U
I'm going to say "maybe." Anything is possible, but I don't know how easy it would be. In "dash3.jpg" (above) you can see that you would probably have to cut a web out of the dash carcass to put it there. Also you'll have to extend the wire harness, and fabricate a way to get the flat panel to fit the curved part of the IP trim (see IPtrim3.jpg).
I considered it briefly, because I thought the hole left behind from the airbag light unit would be a nice fit for a radar detector remote display. I might just eliminate the airbag light panel all together, though. Alot of GM cars put it in the rearview mirror. If I can find a self-dimming rearview mirror with map lights, compass, temp display, and passenger airbag light in a salvage yard, then I'll grab it and free up the space for my V1 remote display.
2KWK4U is offline
Old 11-14-2005, 01:10 PM
SF Celebrity?
dori-san's Avatar
Send a message via AIM to dori-san
Do you think, since the face comes off so easily, it would be possible to pop it off and back on without even removing it from the dash? That way people could dim the lights and not even have to take the gauge bezel apart and everything.
#17313 | Scarlett! | AC | ABS | LSD | Pwr | Conv | Single MP3 | Monsoon! | All but lost...
dori-san is offline
Old 11-14-2005, 01:40 PM
Bonzo's Avatar
Appears to me like the entire thing is screwed on from the back, so popping it off wouldn't be possible. I hope I'm wrong and you're right!!
Nov 1 06, 11000+ mls, Carrier Unit Replaced due to constant Leak and Whine
Wife got 10/27/05
Car Del. 10/25/05
Invoice and VIN# 10/7/05
Built as of 9/24/05
GM Picked Up 8/9/05
First 4 Month Allo.
Bonzo is offline
Old 11-14-2005, 01:56 PM
2KWK4U's Avatar
Hmmm... possible, but I don't want to be the first to try it.
2KWK4U is offline
Old 11-16-2005, 07:22 PM
SlySol's Avatar
I think there's a small ridge all the way around that black face that would prevent it from coming out through the hole in the dash ... it's only about a millimeter or so, but I think it would make it next to impossible to remove that way without gouging the dash up. You can see the little recessed ridge around it in the second pic. Not saying it's impossible, but like 2KWK said, I don't think I'd try it.
SlySol is offline
Old 11-16-2005, 07:32 PM
Ex-Miata Man's Avatar
Have you guys ever heard Click and Clack on Car Talk? They are on NPR radio every Saturday morning. They have a call in car question program. They say the best thing to do with an indicator light that bothers you is to cover it with black elctrical tape. I think I'll just put up with the light as is, I've never been too good with electrical tape. Now if it were duct tape...... Just kiddin'
AKA xmm
DEEP with Steel/Sand leather,
72,200+ miles on the odo - Silver side stripes - My wife named my car "Nittany" after Penn State, my Alma Mater
Proud Member - ICoD EHDoR&M
WPASC
Founding Member #41
"It's Going To Be A Girl......plus one more on the way!!!"
Ex-Miata Man is offline
Old 11-16-2005, 08:15 PM
ralph_on_me's Avatar
I think I'm gonna cover the light with.... my bluetooth car kit remote. It's gotta go somewhere, and that small panel would be a perfect place for me to run the wire through!
Angelina - #4468
Aggressive, living in Arlington Texas.
Adoption date: 11/30/05
ralph_on_me is offline
Old 11-16-2005, 08:58 PM
The Orange One™
Fortimir's Avatar
Send a message via ICQ to Fortimir Send a message via AIM to Fortimir Send a message via MSN to Fortimir Send a message via Yahoo to Fortimir
I would love to see aftermarket come out with a replacement panel that is either blank, or is a remote screen for a radar detector. That would be really neat.
Not an owner any longer.
They call me The Orange One™
Fortimir Design
R&R Music Central
The Best iPod Solution for your Solstice
Fortimir's current screenshot
Fortimir is offline
Old 11-16-2005, 11:20 PM
solli4me's Avatar
Have you guys ever heard Click and Clack on Car Talk? They are on NPR radio every Saturday morning. They have a call in car question program. They say the best thing to do with an indicator light that bothers you is to cover it with black elctrical tape. - Ex-Miata Man
I listen to those two Boston screwballs every Saturday and I heard that show too. I had to laugh since an obsessive carnut friend of mine mentioned black electrical tape also as the 1st choice, when I presented the dilema to him. I have to hand it to 2KWK4U, though. He's pretty darn impressive with his desire to see how things work. He must be male.
Amelia Clunkenquiet - she's cool and she's CAR.
My All American, Coast 2 Coast, Rt. 66 pics. 22 states, 9,000 miles in 4 weeks. http://www.solsticeforum.com/forum/f...ad-trip-20928/
Founder - KAPPAS for the Cause
Founding Member - MASC/MASSC
Founding Member - NASSOA
TEAM SOLSTICE 2008
Team Solstice! Folding@home Team
Join MASSC! mylyte@gmail.com
solli4me is offline
Old 11-17-2005, 06:48 AM
