Old 02-19-2008, 08:42 AM
   How To- Shift Knob Removal
spiky3480's Avatar
This is courtesy of Sam Kelly on the forum:
Removal of AUTOMATIC shifter knob
1. Pull the chrome shifter trim bezel up around the shift knob
2) Unplug the wire harness connector from the bezel
3) Loosen the the knob attachment set screw
4) Remove the retention clip
5) Pull up on knob
A couple things to note:
-A pair of needle-nose pliers works well for pulling the clip, but be
careful not to drop the clip into vehicle once it's removed. It will
need to be reused when the knob/bezel is reassembled to the vehicle.
-The knob is a slight press fit to the lever, so it may take some effort
to remove the knob once the set screw is loosened and the clip is
removed.
--When reassembling the knob/bezel to the shifter, make sure knob is
fully seated before the set screw is tightened....if the shift knob isn't
fully seated you could have problems removing the key from the vehicle.
Enjoy!
TEAM SOLSTICE 2008
ONCE YOU GO SOLO, YOU NEVER GO BACK
2007 Mysterious GXP- "Intruder"
Member of LISSC
Exhaust System Sound Clips/Videos- N/A and GXP Models
SOLO Performance Exhaust Sound Clips
Spiky3480 Modification Page
Mods: 70
Updated 8/13/08
spiky3480 is offline
