Old 03-12-2006, 06:31 PM   #16 (permalink)
Critterman's Avatar
It's mounted solid to the frame, I don't see why you can't, just don't slamp the lift into it.
NOT WAITING ANY MORE!
DDM Stage III Upgrade here
Old 03-12-2006, 06:33 PM   #17 (permalink)
Ex-Miata Man's Avatar
I lifted the entire rear end by lifting under the diff with a two ton floor jack. No problem at all.
AKA xmm
DEEP with Steel/Sand leather,
88,000+ miles on the odo and still goin' strong- Silver side stripes - My wife named my car "Nittany" after Penn State, my Alma Mater
Proud Member - ICoD EHDoR&M
WPASC
Founding Member #41
"Goin' on a Turkey Run !!!"
Ex-Miata Man is offline   Reply With Quote
Old 03-13-2006, 09:22 AM   #18 (permalink)
karr1008's Avatar
Ex-miata-man.
Did you use something in between the tip of the jack's lifter and the diff. to avoid damaging the surface or you just put the jack straight on; metal to metal contact. I don't know if the diff is made of aluminum or iron?
Thanks.
______________________________________
Karr
Former Solstice Owner #4141~SOLD
Ordering Mysterious GXP-R when available.
karr1008 is offline   Reply With Quote
Old 03-15-2006, 07:50 PM   #19 (permalink)
cooper1340s's Avatar
Lifting point info/Jacking point info
I lifted mine by putting the jack under the rear end, metal to metal. No problem at all.
06 SLY, Sand&Steel, Clear Bra, DDM Stage II Supercharger, TRI-Y long tube headers, high flow CAT, Magnaflow cat back dual exhaust, painted calipers w/decals, large bore throttle body, extra horn, flash-to-pass garage door opener
cooper1340s is offline   Reply With Quote
Old 03-15-2006, 07:54 PM   #20 (permalink)
Metal to metal contact on mine also with no trouble.
AKA xmm
WPASC
Founding Member #41
Old 03-15-2006, 08:20 PM   #21 (permalink)
karr1008's Avatar
I just finished my caliper paint job. The rear was the speediest on since all I had to do is lift the car through the rear end and whoala! both wheels where up.
Thanks for the tips guys.
Karr
Old 03-16-2006, 01:53 PM   #22 (permalink)
Critterman's Avatar
Anyone found a single lift point on the front yet?
Old 03-16-2006, 05:46 PM   #23 (permalink)
I was afraid to try so I used the two just behind the front wheels.
AKA xmm
WPASC
Founding Member #41
Old 03-20-2006, 08:47 PM   #24 (permalink)
Chet-O's Avatar
That's where I saw the same, on a picture of the Sol on a lift, before being raised.
Chet-O is offline   Reply With Quote
Old 04-09-2006, 09:18 PM   #25 (permalink)
Little Nipper's Avatar
I received some information on Jacking and lifting my Solstice from my dealer.
They had to look this up on line (GM Techinical Services).
http://users.rcn.com/daniel.thompson...20Page%201.pdf
http://users.rcn.com/daniel.thompson...20Page%202.pdf
The lift pads are made by SPX Kent-Moore for GM.
I bought two from my dealer, but I am trying to get two direct from the SPX Kent-Moore.
These pads are steel with a rubber cushion that goes against the frame.
They also have a small chain and tag attached warning to remove the lift pads from the car before driving.
Envious Green, No XM/On-Star/Monsoon. With LSD, ABS, AC, Steel and Sand.
Picked up March 07, 2006....What A Ride!
Little Nipper is offline   Reply With Quote
Old 04-10-2006, 01:39 AM   #26 (permalink)
voncion22's Avatar
Originally Posted by PURE_Fun
Be very careful with the placement of the jack stands, I put one near the lifting point and when I released the jack to lower the car settled on the jack stand and kept going. I now have a nice indent, that metal is super thin! I wound up painting my calipers one at a time with 3 coats, but did not take that much time, each coat dries in about 15 minutes. I also ordered the special jack pad insert that has the same slot as in the underside of the car.
Your PURE FUN web site is great, a very classy way to show off your car. The mods that you did to your car are smooth and suttle, I was also thinking about removing the badges how hard was it, and if you're still serious about those rally stripes I've got a vendor in mind for mine. PM me if you would like the info. Again nice work!
voncion22 is offline   Reply With Quote
Old 04-10-2006, 02:13 AM   #27 (permalink)
birdliver's Avatar
[quote=MN Mike]
Jacking
The C5 was the first car to use hydroformed frame rails. Hydroformed rails are quickly becoming a common platform for new cars, but not many shops are prepared to lift these vehicles. The C5 requires an adapter for regular jacks and lifts to fit the jacking points. Make your own adapters with a hockey puck (or two) with a 1 1/2" eye bolt screwed thru the center. Stick the eye bolt thru the slit in the jacking point, turn 90 degrees, place jack under adapter and jack away....if you can get the jack under the car. You may have to use ramps. The C5 is so low that most people make their own wooden ramps....rhino ramps are too steep.
Regarding the comment "rhino ramps are too steep" There is a current thread titled "ramps" which I read yesterday which makes a point of saying that rhino ramps have a 17 degree incline and work perfectly for the Solstice, who's got the right answer, I was just about to buy a set?
birdliver is offline   Reply With Quote
Old 04-21-2006, 08:49 PM   #28 (permalink)
birdliver's Avatar
above question....Anybody know?
Old 04-23-2006, 12:34 PM   #29 (permalink)
Mr5150's Avatar
I have a set of Rhino ramps that work fine on the Solstice. $36 @Autozone
Mr5150 is offline   Reply With Quote
Old 05-24-2006, 10:15 AM   #30 (permalink)
zzzybil's Avatar
i have rhino ramps
[quote=birdliver]
Originally Posted by MN Mike
Jacking
changed oil - work fine cost 28$$ wally world
