Old 09-24-2007, 02:37 PM
   Low Coolant Light
Sol-Seeker's Avatar
Originally Posted by sol79 View Post
The low coolant light shouldn't be coming on even during hard cornering. I'd check it out.
Here's the deal. The car went in this morning, sure enough they said I need a new Coolant Level Switch. Which they can't get for two days.
So I told the fellow to put her back together again, I'm taking her to the States tonight, going to check my engine temp manually, and I won't push the drive. He said that the switch won't imipede the coolant from working, there isn't a leak. Then I'll get the new switch put in after I'm back.
Thanks for making me go get this checked out!!!
Lorraine
Sly "Sol-Seeker", Fully Loaded
Just cracked 30,000 km's, purchased May 2006
[font="Arial Black"][font="Comic Sans MS"][color="DarkOrchid"][font="Fixedsys"][font="Impact"]
Mods:
One passenger drink holder
Water Cooler Sensor with c/w tank
Contemplated Mods:
Tinted windows (do myself or just $$$ to get done???)
Ask body shop best way to remove scrape from back end
Sol-Seeker is offline
Old 09-24-2007, 03:27 PM
solli4me's Avatar
Sounds like the answer to the problem Sol-Seeker.
Amelia Clunkenquiet - she's cool and she's CAR.
My All American, Coast 2 Coast, Rt. 66 pics. 22 states, 9,000 miles in 4 weeks. http://www.solsticeforum.com/forum/f...ad-trip-20928/
Founder - KAPPAS for the Cause
Founding Member - MASC/MASSC
Founding Member - NASSOA
TEAM SOLSTICE 2008
Team Solstice! Folding@home Team
JOIN MASC/MASSC: mylyte@gmail.com
What to do? Great minds have not been able to solve the problem of politics.
solli4me is offline
Old 10-02-2007, 09:46 AM
   Car's Fixed....
Sol-Seeker's Avatar
Well apparently the coolant level switch is attached as a complete unit with the coolant tank, so yesterday Sol-seeker went in and had the complete unit changed, under full warranty.
Now I don't have to worry about the coolant light coming on....you others may want to get yours checked - you may need your tank & switch replaced too.
Reminder, my coolant light was coming on when I was going right around long corners.
Good luck!
Lorraine
Mods:
Contemplated Mods:
Old 01-06-2008, 01:45 PM
   Coolant lick
SamGuy24's Avatar
a few weeks ago i noticed i had coolant light on so i checked the antifreez and it was low so i added more GM coolant a little more then i should have more then half so a few days later i get the same thing and it was low again, so i see the is a lick somehwere in the middle of the engine under the car so i wonder what that is dealer told me to keep an eye on it for few days then come back that's what i will do i am going back there to test it see where the lick is This american car just keeps on braking It's nice car but damnn how many times do i have to go back to a dealer????frustrated
SamGuy24 is offline
Old 01-06-2008, 01:51 PM
MyNewSolstice's Avatar
Send a message via Yahoo to MyNewSolstice
I had same symptoms and it was water pump an a relay...I'll dig the exact specifics out in a bit but one question when you look in the engine compartment can you see fluid towards the front of the engine on the passenger side?
Vin 2896 Deep
MyNewSolstice is offline
Old 01-06-2008, 03:19 PM
SamGuy24's Avatar
amm i don't really see any fluids on the passenger side it's dry the only lick i see is under the engine in the middle and it's deffenatly coolant that's licking it's orange
SamGuy24 is offline
Old 01-06-2008, 09:27 PM
Go-N Def's Avatar
Be careful what you lick, anti-freeze is poisonous!
Pics on MySpace
Go-N Def is offline
Old 01-07-2008, 12:07 PM
You need to get underneath it to try and really see where it's dripping. Don't look at the ground, look in the engine compartment. Fluids will ride down all sorts of things to create pools nowhere near the problem.
If you don't have antifreeze in your oil, check caps, hoses, and finally the water pump.
GXPmach is offline
Old 01-11-2008, 11:23 AM
RWSimmons's Avatar
Yeah. "Licking" antifreeze can make a person really sick... or dead!
REAL sports cars don't have Back Seats or Automatic Transmissions.
VIN 3919 - Deep, Steel/Sand Leather, AC, Power pkg, Premium pkg, Convenience pkg, Polished Wheels, Anti-lock Brakes, Limited Slip, Floor Mats.
RWSimmons is offline
Old 01-11-2008, 01:51 PM
It's a good idea not to let the dex-cool level get too low. There are also good flush kits available to clean out the engine of any build-up. Personally I'm not a fan of the stuff. There is evidence the stuff reacts in air at high temperature to make a nice sludge, so don't let that level get too low.
If you're having a leak, I'd definately start with the radiator cap. Common problem, and not just on the Solstice. Let's face it, it's a spring, they wear out.
GXPmach is offline
Old 07-23-2008, 02:23 PM
Wow.....I am a little suprised but kind of glad at the same time to see this many Solstice owners with the same problem.
I actually purchased my 2007 Soli new in Sept of 2006. Last summer was the first time my coolant light blinked at me. I added a small amount of pre-mixed Dexi-cool and did not have another issue until like 3 days ago. It started popping off and on again and I have been adding coolant every day now since. I have to add it in the mornings before I head out to work and usually again before I leave the office to go home. While it is a simple enough task it is just down right annoying. I see no wet spots under the car after being parked so I do not think it's a leak, but I can get a distinct smell of anti-freeze when the temp reaches over 200.
Taking it in next week and let the dealer see what he can find, although I may try the cap replacement and see if that helps.
Thanks for info peeps!!!!
Polly
Sunny_P is offline
