My standard transmision Solstice won't start - Pontiac Solstice Forum
post #1 of 41 (permalink) Old 01-15-2013, 06:13 AM Thread Starter
PontiacSolstice's Avatar
When i turn my key the engine makes a dull warring sound for a second then stops, all electrics work (stereo, power windows, lights) no warning lights stay on or anything, tried to jump start and push start it the other day, when push start after i popped the clutch it started for a second then died, happened twice, anyone know what could be the problem?
PontiacSolstice is offline
post #2 of 41 (permalink) Old 01-15-2013, 10:30 AM
Happened to me when the BCM "forgot" the key. If you have the lock light illuminated, the BCM is shutting the car off as soon as it starts.
There is a procedure for relearning the key that you can perform at home.
Basically, if you see a green padlock when the key is turned on for a few seconds, then you need to run the procedure.
Make sure your battery is fully charged.
Turn the key on (run position) with the engine OFF. Wait 11 minutes. The lock symbol should go off at about 9.5 minutes.
Turn the key off, wait 30 seconds.
Turn key on for 11 minutes as above
Turn key off, wait 30 seconds
Repeat key on for 11 minutes as above
Turn key off, wait 30 seconds.
Then the car should start and continue to run.
I uploaded a new tune to my car and in the process the BCM forgot my key unique code. The car would start, fire a couple of times and immediately shut down.
It was the security system shutting off the motor.
Carol's husband for 48 years
post #3 of 41 (permalink) Old 01-15-2013, 10:54 AM
This forum is amazing. I cannot believe the product knowledge that resides here.
wearwaker is offline
post #4 of 41 (permalink) Old 01-15-2013, 11:00 AM
I have to admit that I had no clue when it happened to me. I had to call my tech and he asked me if the lock warning light was on . .. after that I remembered a post by Small Dealer that had the procedure in it. And fortunately it worked to solve my problem.
post #5 of 41 (permalink) Old 01-15-2013, 02:39 PM Thread Starter
thank you very much i will try and if it doesnt work i shall post again
post #6 of 41 (permalink) Old 01-15-2013, 02:42 PM
A new tune caused that? Weird. I have loaded around 100 tunes to my car alone, and at least 50 on other kappas, and I've never had something like that happen. <knock on wood>
Carbon Sky is offline
post #7 of 41 (permalink) Old 01-15-2013, 04:28 PM
I personally have reloaded multiple tunes with no problems. I suspect that something strange harmed when the ECM rebooted
post #8 of 41 (permalink) Old 01-15-2013, 04:54 PM
If I am not mistaken the procedure is also listed in the owners manual.
It definitely has to be done if you change ECM's.
LatinVenom is offline
post #9 of 41 (permalink) Old 01-15-2013, 08:55 PM
Sorry to hear about the issues occurring with your Solstice. Please keep us posted on the situation. If you decide to have the dealership look at it, please let send a PM with the VIN#, your name, situation, contact information, current mileage, and name of the dealer. I hope this is resolved quickly for you.
Matt,
GM Customer Assistance
GMCustomerSvc is offline
post #10 of 41 (permalink) Old 01-15-2013, 11:26 PM Thread Starter
it didnt work sadly, know anything else that could be wrong?
post #11 of 41 (permalink) Old 01-16-2013, 07:49 AM
Did you check the battery? Could well be the battery and/or alternator (alternator is not charging, so battery is dead). No juice in the battery to start, and when jumped, no alternator to keep the engine running (and battery charged).
TomatoSoup is online now
post #12 of 41 (permalink) Old 01-16-2013, 07:53 AM
MidniteBlues's Avatar
+2 Happened to me when my battery died, car would NOT start with jumper cables either.. With me the entire electrical system died, no power any where, key got stuck in the ignition, after trying to boost the car, I got some power back on the dash, was able to remove the key, but car however would NOT start until I replaced the battery.. My battery was 6.5 years old..
We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution.
Abraham Lincoln
The Constitution is essentially an obsolete charter of negative liberties
Barack Obama
MidniteBlues is offline
post #13 of 41 (permalink) Old 01-16-2013, 10:38 AM Thread Starter
...as i said at first everything electrical still works (radio, windows and lights)
post #14 of 41 (permalink) Old 01-16-2013, 11:34 AM
Battery problems are VERY weird with these cars. Many posts on this where people report that electrics all work but car won't start, and a replacement battery 'fixed' it.
post #15 of 41 (permalink) Old 01-16-2013, 04:23 PM
The problem could be the clutch switch.
