The OP states that the engine makes a noise when he turns the key. That suggests power supply issue. If the clutch safety switch was not working, it shouldn't make any noise at all, just dead key.
I'm going with TS on this one: Check the battery and terminals. Just get a new battery and put it in. At least you will eliminate that variable for sure.
It sounds like a weak battery issue to me too. Of course you should also check the cables from the battery, if a ground wire is not good it will give the same symptom as a weak battery.
I suspect the battery fixed it as the member joined January 2013 ans hasn't posted here since the 17th. would have nice to get an update though.
Delivered on May 27, 2008
Mods: lose the chicklets, VentureShield, Dual horns, AfterShock spoiler, Weathershield cover, Lil Chromies, Red calipers with black Solstice stickers, Opel GT antenna and Solo GXP-RCD exhaust with Solo hi-flow cat!
Battery problems are VERY weird with these cars. Many posts on this where people report that electrics all work but car won't start, and a replacement battery 'fixed' it.
Had the same issues as OP but with an auto GXP. Same basic symptoms, including the "lock light" icon. Didn't even bother with a key relearn since my battery was 6 years old and would no longer take a charge. But it stumped me that I couldn't jump start. Finally did the fender removal with help of a couple of YouTube videos. Swapped out the battery and everything was golden again*! Did not even have to do a key relearn. So I think that is a red herring symptom.
Nice thing was my battery terminals showed no signs of corrosion whatsoever. I'm sure that's partly because I garage it most of the time and usually avoid driving in the rain if I can. Also, I still only have about 19K on it. But after not driving for a few months it was like getting a brand new car again!
[*Well, I do have to replace a taillight. But I already got the bulb and another YouTube video and it looks pretty straightforward. And it's ragtop weather in So Cal once again!]
Rich, you're killing me here. Talking "ragtop weather" when we've received 10 inches of snow in SW Michigan in the last 24 hours (and 6-8 more on the way.) Had the garage door open going out to my truck this morning and saw snow blow in onto the Solstice. First time (I believe) it's ever had snow on it!
I dare say that although the lights are on and somebody is home, I don't expect there was any forward (or rearward) motion to be had in that Wisconsin Sol!
Ninjas hide in plain sight. I don't believe I have a car that can blend into its surroundings. Some people are the same way. We are suited.
