Old 11-28-2007, 02:03 PM
   New fluid leak in rear
Hi,
Checked some of many threads and postings about rear diff problems including the leak. I just discovered a new leak from the rear of my wife's '07 Solstice (base model) over the noon hour.
The oily substance is dripping off the left side of the rear stabilizer bar and muffler. It appears the oil is dripping down on to the bar and muffler from an approx. 3/8-1/2" diameter black hose that is pretty stiff. This hose is routed well above the muffler and I near the gas tank. The fluid is definitely not gas, but a darker oily fluid. I cannot see the source of the leak, but it appears the tube is not punctured. What is strange is that I do not see any evidence so far of oil dripping from the bottom of the rear diff (have the LSD).
The pinion seal and vent tube were replaced about 3,000 miles ago last Spring.
Any ideas?
Thanks
gmowner8 is offline
Old 11-28-2007, 02:06 PM
smartin's Avatar
Probably the pinion seal again. Take it to the dealer and have them look at it. Good luck.
Deep, Ebony
O Sol O Mio
smartin is offline
Old 11-28-2007, 02:15 PM
Critterman's Avatar
Sounds to me like they installed the extended relief valve (rubber house w/valve at the end). I would take it in and have it checked.
NOT WAITING ANY MORE!
Critterman is online now
Old 11-28-2007, 02:21 PM
Thanks for the responses. If it was a little bit of a leak, I would think the vent tube was doing its job. But there is enough oil on the bottom of the muffler and stabilizer bar (multiple spots pooling then dripping) to indicate that the volume of fluid escaping/leaking is not normal. Definitely heading to the dealer.
Sincerely,
gmowner8
gmowner8 is offline
Old 11-28-2007, 02:45 PM
Berserk303's Avatar
Send a message via AIM to Berserk303
I had so many differential issues that I requested GM t o extend my warranty. Guess what? They did! So if you keep having problems with your differential request a warranty extension on the rear diff only. Chances are they will honor your request. If the dealer says no go over their head and call GM directly.
Hope it helps.
Clearimage Shorty Headers.....Kappasphere Cold Air Intake.....Performance AutoWerks ECM Flash and Hi-Flo Cat.....Solo Performance SQR-2 Center Dual Tip Cat-Back Exhaust.....Norm's Fiberglass Painted Rear Fascia.....
Dyno numbers at the wheels:
HP: 162
Torque: 157
Gains of over 20hp!!!
Berserk303 is offline
Old 11-28-2007, 02:52 PM
lil goat's Avatar
Did you buy a Solstice? The differential leak is a feature, it seems most have had or will have an issue.
Red Bull Drift Team 2008
Solo Mach and High Flow Cat
Wester's Garage RACE tune II
JPM custom shifter.
Barney Juice with Militec-1
DDM Works PINK Breastplate
lil goat is offline
Old 11-28-2007, 03:12 PM
smartin's Avatar
Hope it helps.
Good advice!
Deep, Ebony
O Sol O Mio
smartin is offline
Old 11-28-2007, 07:58 PM
   source of rear end leak found
Thought I would check my wife's Solstice once again tonight when I could elevate inspect the rear end of the car.
The source of fluid was the vent tube, from the end valve that is tied up behind the gas tank. Fluid had sprayed (looked like blotches) over parts of the car's underside and rear valance plus trickled down the tube to leak onto the stabilizer, chassis crossmember and muffler. As of tonight, the fluid overflow has stopped.
What caught me off guard earlier, when I noticed the fresh oil spot on the driveway, was what I perceived to be the size of the leak. The oil spot was multiple times the size of a quarter. Also, there were numerous fluid droplets forming on the stabilizer, crossmember and muffler.
I guess a lot more fluid can escape the vent tube valve than I ever imagined normal or possible.
Also surprising is that this never happened before since replacement of the pinion seal and installation of the vent tube modification last Spring. This is my wife's daily driver and in previous months had been driven harder and longer in very hot weather compared to the recent past. Today was a typical eight mile trip (2/3 at interstate speeds) to and from work a couple times in 32 degree weather. Why diff fluid never flowed out the vent tube before today is beyond me.
Thanks again for your responses.
gmowner8
gmowner8 is offline
