Old 01-03-2005, 12:56 PM   #1 (permalink)
Per Diem Administrator
brentil's Avatar
New official bit of 2.4L ECOTEC info
Chevy just officially showed the new Chevy HHR (PT Cruiser competitor) based off the Cobalt platform. There are two versions, LS and LT. The LS uses the 2.2L ECOTEC, but the 1LT and 2LT have the 2.4L VVT as an option and base. The official GM Media press release gives some information about the engine however.
Engines: Ecotec 2.2L I-4
Displacement (cu in / cc): 134 / 2189
Compression ratio: 10:1
Horsepower (hp / kw @ rpm): 140 / 104 @ 5400
Torque (lb-ft / Nm @ rpm): 150 / 207 @ 4000
Maximum engine speed (rpm): 6500
Engines: Ecotec 2.4L I-4
Displacement (cu in / cc): 145.5 / 2384
Compression ratio: 10.5:1
Horsepower (hp / kw @ rpm): 170 / 127 @ 6000
Torque (lb-ft / Nm @ rpm): 170 / 235 @ 4400
I've highlighted the information that I found fairly interesting. I've added the 2.2L non VVT ECOTEC for comparison too. Also the older Twin-Cam 2.4L engine ran at 9.5:1 compression making 150HP. Until now we didn't know the new engines compression ratio, or at what RPM the HP and Torque was available.
From this information you can see where the power increase has come from. The extra 0.2L and the 0.5:1 compression increase, plus VVT moved the ECOTEC from the 140HP/150 lb-ft to the 170HP/170 lb-ft range. However the 2.4L engine has to go higher into the revs to get this power too though.
With a stock compression ratio of 10.5:1 I'm betting we're not going to end up getting a GM Performance Parts Supercharger addon kit
Save the Kappa!
NASSOA (TM)
Old 01-03-2005, 01:24 PM   #2 (permalink)
mceb's Avatar
Good find brentil.
Pontiac RIP 1926-2009
Old 01-03-2005, 02:04 PM   #3 (permalink)
2KWK4U's Avatar
Yep, I have serious doubts about a simple bolt-on S/C kit with that kind of CR. If there's a kit at all, it would have to come with at least a thicker head gasket (but that's a band-aid) or dished pistons.
Old 01-03-2005, 02:06 PM   #4 (permalink)
Mod Emeritus
Good information! That is an awfully high compression ratio to be adding a bolt on supercharger to, but they may still have a low pressure solution in mind. What I am wondering is how that will affect a potential factory supercharger/turbocharger on the VVT engine? I know they can drop the compression down, but they will have to drop it a lot to use a decent amount of boost!
I’m also curious to see what the power band looks like. Whether most of that power shows up throughout, or whether it is a fairly peaky engine. Based on the displacement I would not expect it to be very peaky, but you never know.
Solstice and Sky Fan
Old 01-03-2005, 02:58 PM   #5 (permalink)
Any word on if they specify regular or premium gas? With that compression ratio, it could go either way.
DreamerDave is offline   Reply With Quote
Old 01-03-2005, 03:48 PM   #6 (permalink)
brentil's Avatar
Since this engine is going to become part of the econo vehicle line of GM I'm betting it's only 87 octane gas. I don't think many people would buy a 91+ octane using low end car unless it was producing a good bit more then 170HP.
Save the Kappa!
NASSOA (TM)
Old 01-03-2005, 06:01 PM   #7 (permalink)
AeroDave's Avatar
Maybe have to use Premium gas too. That would suck.
Thanks again Bob, for building my car! Envious/Ebony VIN #0051
AeroDave is offline   Reply With Quote
Old 01-03-2005, 09:42 PM   #8 (permalink)
AztekzRpurty's Avatar
Man that horsepower peak rpm and max rpm are close. Wonder where the rev limiter will be set.
Would love to see a horsepower/torque curve. I too am hoping for a flat 'stroker' profile on this engine, the opposite of the Honda S2000.
Old 01-04-2005, 04:21 AM   #9 (permalink)
cdb
cdb's Avatar
with the computer monitoring preignition you probably could use a lower grade of gas, but you wouldn't get the best performance. I'd love to see the hp/tq curve also- i'm hoping the VVT will give us good power down low without running out of breath at higher rpm
cdb is offline   Reply With Quote
Old 01-04-2005, 04:45 AM   #10 (permalink)
tcl
tcl's Avatar
Originally Posted by AztekzRpurty
....Would love to see a horsepower/torque curve. I too am hoping for a flat 'stroker' profile on this engine, the opposite of the Honda S2000.
The article below from GM says that the Ecotec makes 90% of its torque at 2400 RPM.
http://www.gm.com/automotive/gmpower...ecotec_24L.pdf
tcl is offline   Reply With Quote
Old 01-04-2005, 10:14 AM   #11 (permalink)
It also says it uses regular unleaded gas.
Old 01-04-2005, 10:33 AM   #12 (permalink)
brentil's Avatar
Woo-Hoo TCL, I had totally forgotten about that PDF. Let me go update my FAQ post with this info.
That PDF actually also gives the compression ratio as 10.6:1 too.
Save the Kappa!
NASSOA (TM)
Old 01-04-2005, 11:41 AM   #13 (permalink)
brentil's Avatar
Variable Valve Timing helps deliver 90 percent of the peak torque at as low as 2400 rpm
So in essence 153 ft-lbs is available at 2400 rpm.
That's more then what my current car produces at peak using 93 octane.
Save the Kappa!
NASSOA (TM)
Old 01-04-2005, 01:05 PM   #14 (permalink)
Mod Emeritus
Those are figures I like to see! That torque figure at 2400 RPM is better than the max torque of half of the cars I have ever owned! :nonod I think I will be happy with that! :yesnod
Old 01-04-2005, 01:06 PM   #15 (permalink)
Rickady88GT's Avatar
I need to see Dyno Specs :smile
Rickady88GT is offline   Reply With Quote
