Old 05-18-2006, 11:20 AM
   A new problem? [rear window TSB]
SOL369's Avatar
Send a message via AIM to SOL369
I was driving the car today and noticed that the rear window was not as sturdy as when I first got the car. (sturdy as in not attached to the ragtop all the way around the window ) Used to have trouble shutting the door due to interior pressure, but not anymore! I checked the seam around the window and found that the entire top of the window where it should be glued onto the ragtop is loose. (not attached) I can't even find a trace of glue and was wondering if this is normal. I've posted some pictures. It's not just one section, it's the entire top of the window. Doesn't seem right. Anyone have this problem?
Rather glue it myself than take it to the dealer!
VIN# 108470 - SLY w/ Ebony Leather
Power | Convenience | Premium | LSD | A/C | Antilock
SOL369 is offline
Old 05-18-2006, 11:36 AM
glider rider's Avatar
I just checked and it is attached to the ragtop all the way around the window, it does not lift up at all.
SLY '07 GXP with Ebony leather w/Red Stitching | XM/Monsoon | 6CD changer |Chromed Rims|VIN 4979 Lives in Vega$ and loves the topless weather
glider rider is online now
Old 05-18-2006, 12:32 PM
SOL369's Avatar
Thanks. I thought it was messed up. Back to the dealer May try to epoxy it myself.....can't be too hard.
SOL369 is offline
Old 06-02-2006, 09:02 AM
SOL369's Avatar
Just got back from the dealer and they have a service bulletin #1772397 regarding rear glass separating from the convertible top. They are going to rebond the glass to the top sometime next week, when the glass guy can get to the shop. FYI
SOL369 is offline
Old 06-02-2006, 09:20 AM
   Service Bulletin Thread
Cool Cruiser's Avatar
Is the service bulletin thread up to date?
Cool, two-tone leather, everything except XM
Cool Cruiser is offline
Old 06-02-2006, 09:40 AM
SOL369's Avatar
I have no idea if it's up to date. Maybe Small Dealer can get a copy posted. I have the paper copy of Document ID #1772397 from the dealer. My window is half in and half out but I don't see it when the top is in the trunk
SOL369 is offline
Old 06-02-2006, 10:38 AM
Liam1694u's Avatar
All of these things that keep popping up are the reason i felt it worth it to wait for an 07 model. Most of these kinks should be worked out for my car
of course I'm gettting an 07 GXP, so it will have all sorts of its own first run problems. But at least some of the core structural and non-engine related mechanical problems should be worked out.
Fuel for the Soul
Mysterious 07' GXP (waiting not-so patiently)
Liam1694u is offline
Old 06-02-2006, 10:49 AM
FredinVa's Avatar
You think!!
SOL369's is (my guess) the first with this problem. Not bad, one of over 17,000. It was probably a Monday and the glue guy on line sniffed instead of applying!!!!
fred
Aggressive/ebony - Loaded (all but Onstar, polished)
Vin: 9289
RK Sport Magnaflow duals w/GXP rear fascia
$500 Deposit 1-27-06, Delivered 2-3-06
Objects in my rearview mirror, keep getting smaller and smaller, really quick!!
"Be Careful out there", Sgt. Phil Esterhaus, HSB
FredinVa is offline
Old 06-02-2006, 10:58 AM
mceb's Avatar
If someone get get the text of that TSB I'll add to our list of TSBs, thanks.
2006 VIN #30, first 1000 series, black exterior, sand/steel interior
mceb is offline
Old 06-02-2006, 11:13 AM
SOL369's Avatar
I have it saved as a PDF. How do I get it to you?
SOL369 is offline
Old 06-02-2006, 12:22 PM
mceb's Avatar
From SOL369, here is the PDF for rear glass issue (TSB 1772397)
Added original post with PDF to TSB thread pinned to top of forum:
List of GM Tech/Service Bulletins [TSBs]
mceb is offline
Old 06-08-2006, 12:12 PM
SOL369's Avatar
Just got my Sol back from the dealer and the rear window has been glued in. Looks like new....Hope this holds.
SOL369 is offline
Old 06-08-2006, 02:31 PM
lil goat's Avatar
The Sols are still basically hand built, it is far more effected by human intervention or lack of it than most cars on the road. Robots don't get hangovers, but I like the having a hand built car. I have a CVO Harley it was never on the assembly line and it has it's own quirks no two are exactly the same, just like the Solstice, so far my troubles have been minor, and I drive it like I stole it. ( I am going to check my window when I get off work, thanks for the update )
Red Bull Drift Team 2008
Solo Mach and High Flow Cat
Wester's Garage RACE tune II
JPM custom shifter.
Barney Juice with Militec-1
DDM Works PINK Breastplate
lil goat is offline
Old 08-29-2006, 03:19 AM
Send a message via Yahoo to Stevie
The reason you didn't find a trace of glue where the glass has separated from the fabric is because the manufacturer does not use glue to seal the glass to the fabric..well at least not the type of glue you are thinking of. The glass does get a coating of an adhesive called a "primer". It's a very thin coating that is transparent and dries within a few minutes. The vinyl part of the fabric also gets a coating of this adhesive. Both are allowed to dry before they get bonded together. The glass and fabric is heat sealed together. Oh I don't mean they are thrown into an oven. The process is called "dielectric radio-frequency heat sealing"...they get zapped with lots of kilowatts of R.F. energy (at 27 MHz) while being modestly compressed between two dies with about 50 psi of pressure applied.
Anyway, what you had was definately a defective heat sealing job, whether it was because of the person applying the adhesive or because the heat sealing machine didn't apply enough heat, it should have never left the factory.
I am rather surprised that GM is issuing a bulletin to use a glue to repair such a large separation...what's next?... issuing a bulletin to use JB Weld on cylinder heads???
Stevie is offline
Old 08-29-2006, 10:49 AM
So the VFO on the CB was off that day? Or maybe there wasnt enough cable after the Linear.
