P0480 and PO691 fan circuit codes - Pontiac Solstice Forum
post #1 of 12 (permalink) Old 06-18-2010, 06:08 PM Thread Starter
Anyone had a problem with these. My 08' GXP started having these codes intermittent. Then the fan quit completely. Upon inspection I found the control circuit in the ECU is blown. Apparently the cooling fan on the GXP is controlled by a PWM(Pulse Width Modulation) ground circuit in the ECU. Cant even cheat it because the fan has a seperate ECU mounted on the back of it. GM has a bulletin on these codes but refers to a blown 60A fan fuse and says its due to improper jump starting....BS...the car has never been jump started... Im pissed , what a hassle...any ideas from you GM techs or engineers?...Jim
PASSIONRE is offline
post #2 of 12 (permalink) Old 06-18-2010, 06:32 PM
Hey jim. Just had a sky member go through this. Give the thread below a quick look and see if you have anymore questions.
Cooling/Radiator Fan Codes... - Saturn Sky Forums: Saturn Sky Forum
edit: Just because a bulletin says that one method of causing it is jump starting doesn't mean that's the be all and end all of why it happens. IIRC in this case there were a lot of people hooking up to the fan connections to jump start their cars and well that doesn't go so well through the 60A fuse.
-INFO2X
2009 Sky RL 5 Spd
I am a GM engineer, my comments are my own. I'm not responsible for your actions.
info2x is offline
post #3 of 12 (permalink) Old 07-05-2010, 11:13 AM Thread Starter
Thanks for the information although I still have a problem. The wiring diagrams I have access to(ALLDATA), do not show the control circuit(white wire) running through the fusebox....can you give me any info concerning sub connections it might be connected to in the fuse box? I've replaced the fan assy with controller, ECU, I have power, ground, and Ive checked continuity from ecu to controller on the white wire, and checked for that circuit being grounded to ground with the ecu and fan assy disconnected...all results good. Both ecu's kick up po691 and po480 everytime there is a fan command, and fans are inoperative under any circumstance...Jim
post #4 of 12 (permalink) Old 07-06-2010, 09:46 PM
Don't have the info on me right now, I'll pull it up ASAP. Hopefully by the end of the week.
-INFO2X
2009 Sky RL 5 Spd
info2x is offline
post #5 of 12 (permalink) Old 07-06-2010, 11:47 PM Thread Starter
Well, I found it! after determining that I had power, ground,a new fan, new ecu...and NO function at all, we have the Brazen Beast with cold AC and fans once again. What?........ power, ground, new components...what else is there? How about the ability to carry current! Im sitting eating breakfast and my son asks me if I have a voltage meter to check his boat battery. I reply "wont do you any good to check voltage, it wont tell you if the battery can sustain a load".... then it hit me, "added resistance". Sure enough, the main power wire(red) to the fans has 20ohms resistance. After inspection, it appears the factory has coated the end of the wire at the engine fusebox with some kind of adhesive to seal the insulation to the wire. Only problem is, is that the terminal was coated as well......BAD CONNECTION. I cant believe it ever worked at all. Plenty of voltage, NO current carrying capability! Ive been stumped by this before,,,but its been a while...back to basics. Maybe a TSB in order? thanks for the help....Jim
post #6 of 12 (permalink) Old 07-07-2010, 01:05 AM
I jump started my car after I had been working on installing an auto-dimming mirror with compass and thermometer. I followed the instructions in the owner's manual, and saw the fuse for the cooling fan blow before my eyes.
I know a local Solstice that was overheating, turned out it was because his fuse blew, again because he had jump started his car. Not sure if he did it "properly", but it seems jumping these cars can be hazardous on this fuse. I carry one in the car at all times now.
Carbon Sky is offline
post #7 of 12 (permalink) Old 07-07-2010, 05:04 PM
The troubleshooting guide mentions checking resistance. IIRC they look for less than 1 ohm resistance, so your 20 ohms is way out of wack.
Good job at figuring it out
-INFO2X
2009 Sky RL 5 Spd
info2x is offline
post #8 of 12 (permalink) Old 04-12-2015, 09:28 AM
I have a 2009 Solstice GXP automatic with just under 11K miles on it. I had not used it over the winter and went to start it yesterday. Dead battery. Like Carbon Sky, I jump started it. Started right up. I thought everything was fine and took it for a non-eventful spin. Upon parking I noticed the check engine light was on. Attached my code reader and the code PO691 came up. From what I have read I must have jump started it incorrectly. Now I am here at the forum and see I am not alone. So I figured like Carbon Sky I would simply replace the pre mentioned 60amp fuse and henceforth likewise carry extras. Problem is, I don't know where this fuse is. Further upon accessing the under hood fuse box, ANY fuse that has anything to do with a fan (#1,8,24,40,50) is designated as (empty) in the manual and is respectively absent in the fuse box (?!). I could find no further information as to how to solve this and so I am resigning myself to bringing the vehicle to my mechanic. $ch-ching.. If I am overlooking a simple fuse replacement I would greatly appreciate any help as to where this fuse might be. Thanks
drchucksgas is offline
post #9 of 12 (permalink) Old 04-12-2015, 09:47 AM
SolNut's Avatar
Check the fuses in the passenger footwell
eCar
SolNut is offline
post #10 of 12 (permalink) Old 04-12-2015, 10:16 AM
Thank you SolNut. I just checked the manual and see no fuses with a fan designation in the passenger footwell fuse box. Might you know which fuses to check or should I simply check them all? Much appreciated.
post #11 of 12 (permalink) Old 04-12-2015, 12:30 PM
SolNut's Avatar
I looked in my 2009 Service Book and the fuse layout for a 2009 GXP automatic on Pg. 11-191 shows that the Engine Cooling Fan (60A) is located in Position #1
eCar
SolNut is offline
post #12 of 12 (permalink) Old 05-13-2015, 02:47 PM
It seems that the manual was a bit different than the actual lay out. When I popped the cover for the fuse box it showed the 60A fuse but Position #1 was on the other side.
There it was right under my nose! Replaced the fuse and deleted the code. Fans work again, check engine light gone. Back in business!!
