Old 05-13-2006, 11:14 PM
   Rear tire rubbing? [TSB on issue enclosed]
Has anyone else had problems with a rear tire rubbing the front of the wheel well?
Today, with only about 400 miles on my car, as I downshifted and was passing another car there was a horribly frightening noise from somewhere around the rear end. I got off the gas, the noise stopped, and to my surprise, there were absolutely no further symptoms. I thought the rear end must have gone out or something equally awful must have happened, but the car drove fine. Upon inspection, I saw that the tire had rubbed a hole in the plastic wheel well in front of the tire. I heard it rub several more times on the way home when the suspension was compressed.
I will definetly be visiting the dealer, but was wondering if this had happened to anyone else and what caused the problem.
Thanks.
Aggressive with Sand & Steel interior and chrome wheels. All options except OnStar. Delivered April 22, 2006.
Tommy In Texas is offline
Old 05-13-2006, 11:17 PM
Devoking's Avatar
I have seen earlier posts about Shocks leaking, check to see if you have a bum one.
Volley - ICOD GOTHIC................"Pontiac Pure Excitement".........
website link -
NASSOA - Officially recognized by GM
Founding Member #69
Devoking is offline
Old 05-14-2006, 11:12 AM
I can't find it or I went blind looking for it.
There is a thread on here from me about fixing this yourself. You can also go to the Sky board and locate the rubbing threads there and how GM/Saturn (ripped off), came up with a quick fix.
Sorry that I wasn't reading right. This info from me would be for the rear wheel wells.
tweety is offline
Old 05-14-2006, 02:01 PM
Small Dealer's Avatar
There was a technical service bulletin issued to dealerships early last fall about this condition. There has also been an update to factory build to install a retainer to keep the liner back away from the tire. (Of course this assumes that your car doesn't have an alignment issue, just the clearance issue.) Here is the latest version, with fix and picture:
Originally Posted by GM TSB(edited by Small Dealer)
Subject: Rubbing Noise From Rear of Vehicle (Install Retainers to Wheel Liner)
Condition
Some customers may comment on a rubbing noise from the rear of the vehicle.
Cause
This condition may be caused by the inner wheel liner making contact with the tire .
Correction
Install new retainers in the left and right inner wheel liner following the procedure below.
1) Remove the rear tire and wheel.
2) Make a measurement from the corner 90 mm (3 ˝ in). The second measurement will be to measure up 40 mm (1 ˝ in). Refer to the illustration.
3) Drill a hole through the plastic wheel liner and the sheet metal using a 6 mm (15/64 in) drill bit.
4) Drill the hole larger in the plastic liner using a 8 mm (19/64 in) drill bit to eliminate contact with the retainer.
5) Apply SuperLubeŽ with PTFE to the end of the retainer and install the new retainer. You must push firmly on the retainer to fully seat it.
6) Install the wheel and tire.
INFORMATION POSTED ON SITE
Small Dealer is offline
Old 05-14-2006, 04:22 PM
I think I may have that. Haven't noticed it for the first 5K. Pulling out of a parking space (only to the right), there was a rubbing sound. Could only duplicate at very slow speeds with the wheel fully deflected to the right. See a couple rub marks on the well.
JaxSolMates.com - JaxSols Yahoo! Group - Join JaxSols eMail List (for info about North Florida rides and meets)
ScottJSmith is offline
Old 05-14-2006, 06:09 PM
   Thanks to Small Dealer
Small Dealer, thanks a lot for the information. I will take a copy to my dealership. Knowledge is power.
Old 05-14-2006, 06:54 PM
Actually save your self one trip. Call them and have them order the correct recommended retainers and new liners (you say yours has worn through). Then when the parts are in, you can go in and drop the car off.
Old 05-15-2006, 08:55 AM
mceb's Avatar
Thanks to member Ckerch for the document, I've attached PDF version to small dealer's post
Copy of small dealer post has been added to service bulletin list here:
List of GM Tech/Service Bulletins [TSBs]
2006 VIN #30, first 1000 series, black exterior, sand/steel interior
mceb is offline
